wii sd card
  • yamar1
    • 970
    wii sd card
    can i remove the sd card and leave it out once the homebrew/soft mod zelda hack is installed? or does it need to stay in the wii?
    Faster than Faster
  • perkinini
    • 32
    its ok to take it out when it is installed as it doesnt use it
    • yamar1
      • 970
      so its installed on the wii memory then , i thought it was on the card, so in theory you can use the same card to do a second wii? and the 1st one will run ok without the card in?
      Faster than Faster
      • perkinini
        • 32
        you can use the same sd card to do multiple wii's if you want, it installes everythin to the system memory
        • yamar1
          • 970
          theres me been leaving them in,, done a couple for the family!, thanks for the advice.
          Faster than Faster
          • ChrisCris
            • Mar 2009
            • 4
            Ok, but to run some homebrew, then you'll need the sd card !!
            greetings,
            Chris
            • yamar1
              • 970
              but backup launcher starfall etc will still work ok,, basicly just to play copy games will there be any problems if theres no card in the wii?
              Faster than Faster
              • perkinini
                • 32
                no you only need the sd card in for such things as wii player ect but starfall and the other programs work as normal
