Few Wii Questions
  • cunny
    • 4915
    Few Wii Questions
    Hi as with the release of wii firmware 4.0. I wanted to know was it possible to get the 3.4 on disc and update any wiis that way, then use the twighlight hack.
    Also for those wiis that only have modchips, is it possible to patch ntsc games so they will run on a pal system?
    Also apart from opening the wii can you tell what mod chip is installed inside the wii?
    Many Thanks
  • dell_xps
    • 2558
    Many Thanks
    1. I dont think so
    2. why waste your time patching discs ???, use Gecko, but if you must patch ntsc to pal then yes you can do it.
    3.No you will have to open it.
    • cunny
      • 4915
      So then for those on the lower firmware then you cant instal 3.4 with the better disc reading, my friend at work has wii on 2.3 and it wont read burnt discs on modchip.
      We cant identify what chip is inside hence updating the chip.
      Is there no games with 3.4 on as standard?
      • dell_xps
        • 2558
        Wii Music will update your Wii to 3.4E
        • cunny
          • 4915
          thanks dell, ur a star for this
          Are you sure as showing 3.3 on google.
          Also is there any others that could update the wii?
          • middlewingnut
            • 55
            lego batman tries to update to 3.4, but I've got starfall on so it doesn't happen. Hope that helps, as I'm not entirely sure I understand your question ;-)
            • cunny
              • 4915
              I am trying ti find a game that updates the wii system to 3.4, then i am going to instal homebrew (twighlight hack) as want 3.4 for the better disc reading.
              • dell_xps
                • 2558
                Need For Speed Underground I think it is updates to 3.4E.
                • DW190
                  You dont need a game to update or or downgrade.
                  The hack I use ups or downs to 3.2 then the softmod can be done.
                  PM me an email addy and I'll mail you the files.
                  • DW190
                    Tried to send to email address, returned undeliverable.
                    • cunny
                      • 4915
                      sent again
                      • DW190
                        The files and readme can be downloaded from the links below. There is no need to change any file names when running the hack as the files have been separated and the renaming done.
                        http://rapidshare.com/files/215716802/Wii_Downgrader_3.3-3.4.rar
                        http://rapidshare.com/files/215716803/Wii_Read_Me_File.wps
