help with wii games
  • billy2
    • 1381
    #16
    thanks m8 in the end i had to change the boot.elf to boot.dol to get it to work my new sysCheck is this and at the end of all this the games still dont work toy story 3 gets stuck on startup also Boogie Superstar also gets stuck on startup maybe more will have alook tomorrow all these games worked before i put wii in the loft some mths back ???
    sysCheck v2.1.0b18 by Double_A and R2-D2199
    ...runs on IOS58 (rev 6176).
    Region: PAL
    System Menu 4.1E (v450)
    Priiloader installed
    Drive date: 2007.02.13
    Homebrew Channel 1.1.0 running on IOS58
    Hollywood v0x11
    Console ID: 103973648
    Boot2 v4
    Found 145 titles.
    Found 52 IOS on this console. 4 of them are stub.
    IOS4 (rev 65280): Stub
    IOS9 (rev 1034): No Patches
    IOS10 (rev 768): Stub
    IOS11 (rev 16174): Trucha Bug NAND Access
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS16 (rev 512): Stub
    IOS17 (rev 1032): No Patches
    IOS20 (rev 16174): Trucha Bug NAND Access
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 16174): Trucha Bug NAND Access
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 3608): No Patches
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS40 (rev 16174): Trucha Bug NAND Access
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 16174): Trucha Bug NAND Access
    IOS51 (rev 4864): Stub
    IOS52 (rev 16174): Trucha Bug NAND Access
    IOS53 (rev 5663): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 16174): Trucha Bug NAND Access
    IOS61 (rev 5662): No Patches
    IOS70 (rev 16174): Trucha Bug NAND Access
    IOS80 (rev 16174): Trucha Bug NAND Access
    IOS202[60] (rev 65535 Info: hermesrodries-v6): Trucha Bug NAND Access USB 2.0
    IOS222[38] (rev 4 Info: hermes-v4.0): Trucha Bug ES Identify NAND Access USB 2.0
    IOS223[38] (rev 4 Info: hermes-v4.0): Trucha Bug ES Identify NAND Access USB 2.0
    IOS224[57] (rev 65535 Info: hermesrodries-v6): Trucha Bug NAND Access USB 2.0
    IOS245[37] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS246[38] (rev 21008 Info: d2x-v8final): Trucha Bug ES Identify NAND Access
    IOS247[53] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS248[55] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS249[56] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS250[57] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS251[58] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS254 (rev 65281): BootMii
    BC v5
    MIOS v10
    Report generated on 2012/10/31.
    please press the little red THANKS tab
    if I helped if not press the green tab to tell me to f**Koff
    • happy_highlander
      • Aug 2010
      • 3535
      #17
      You are missing ios 236 and don't have ios 36 patched so I don't know how you managed to install d2x v8 as they should be installed into the 236 slot. Have you done a clean install of the latest version of your preffered loaders. Don't update as the config files may be corrupt
      • Keithuk
        • Aug 2010
        • 2264
        #18
        Well I've just tried Toy Story 3 and it works perfectly. The main problem with games that don't run/black screen/lockup is a bad download.
        PM sent.
        Keith
        2010 Golf GTD (170)
        • billy2
          • 1381
          #19
          ok hope this is it now
          Region: PAL
          Hollywood v0x11
          Boot2 v4
          Found 145 titles.
          IOS36 (rev 3608 Info: rev 3351): Trucha Bug ES Identify NAND Access
          IOS223[38+37] (rev 4 Info: hermes-v4): Trucha Bug ES Identify NAND Access USB 2.0
          BC v5
          MIOS v10
          Report generated on 2012/11/02.
          • happy_highlander
            • Aug 2010
            • 3535
            #20
            That's you all sorted now. Just remember if you still have problems the loaders are as much a part of making the games work as the cios are, so remove all traces of old loaders and install latest versions with a clean install (especially if your using gx as it has changed dramatically just recently)
            • Keithuk
              • Aug 2010
              • 2264
              #21
              So does Toy Story 3 work now, did you read my PM?
              Keith
              2010 Golf GTD (170)
              • billy2
                • 1381
                #22
                hi m8 did not get a chance to down from the link you sent m8 the toy story 3 i had was working when i put it on hdd was played for mths , after all the updates some of the games are still not working anyone know what the ios in the game settings should be ????
                cheers guys for all your time and help
                • happy_highlander
                  • Aug 2010
                  • 3535
                  #23
                  Almost all games load from ios 249[56] with the exception of cod games that use 250[57] and most mic games use an ios with a base of [37] or [38] same with dual layer.....I have just noticed you are still missing ios 236 but ios 36 is now patched so should be ok
                  • Keithuk
                    • Aug 2010
                    • 2264
                    #24
                    Billy as I've told users in other threads if you want to check for updates use ModMii in Windows. Use the SU option (SysCheck Update) which scans your sysCheck.csv from sysCheck and it downloads any updated wads needed. It should add IOS236-v5-Mod folder in the apps folder so it installs IOS36 into IOS236. IOS36-64-v3351.wad must be on the root of the SD card for this to work.
                    Keith
                    2010 Golf GTD (170)
                    • reddevil157
                      • 1427
                      #25
                      Try another usb loader, the latest Cfg is loading toy story 3 with 247 for me without any problems, give it a go.
