skylanders Giants
  • randallflagg
    • 27
    skylanders Giants
    Hi all,
    The kids are determined to buy this game with the " Rip-off Portal of Power" for 70E ish.
    I have a softmodded wii 4.0-4.1 with almost up-to-date cios and Priiloader installed - see end of post for syscheck
    I have 2 questions that I hope some-one can help me with:
    1. will this game work with my current system or is a further mod necessary. If necessary, what do i do ?
    2. some versions of this game (PC) come with a USB powered Portal of Power and some with wifi (Wii i think). will the PC version work with the wii as it would cut down on battery usage ?
    i've seen a couple of posts about skylanders but not many replies - is there anyone playing this on a softmodded Wii ?
    Thanks,
    randallflagg.
    sysCheck v2.1.0b11 by Double_A and R2-D2199
    ...runs on IOS58 (rev 6176).
    Region: PAL
    System Menu 4.0/4.1E (v54450)
    Priilaoder installed
    Homebrew Channel 1.0.0 running on IOS58
    Hollywood v0x21
    Console ID:
    Boot2 v4
    Found 135 titles.
    Found 55 IOS on this console. 6 of them are stub.
    IOS3 (rev 65280): Stub
    IOS4 (rev 65280): Stub
    IOS9 (rev 54321): Trucha Bug
    IOS10 (rev 768): Stub
    IOS11 (rev 54321): Trucha Bug
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS16 (rev 54321): Trucha Bug ES Identify Flash Access NAND Access
    IOS17 (rev 1032): No Patches
    IOS20 (rev 54321): Trucha Bug
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 54321): Trucha Bug
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 54321): Trucha Bug ES Identify NAND Access
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS40 (rev 3072): Stub
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 54321): Trucha Bug
    IOS51 (rev 4864): Stub
    IOS52 (rev 5888): Stub
    IOS53 (rev 5663): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 54321): Trucha Bug
    IOS61 (rev 5662): No Patches
    IOS70 (rev 54321): Trucha Bug
    IOS80 (rev 54321): Trucha Bug
    IOS90 (rev 54321): Trucha Bug
    IOS202[60] (rev 65535 Info: v5.1): Trucha Bug NAND Access USB 2.0
    IOS222[38] (rev 4 Info: v0.1): Trucha Bug ES Identify NAND Access USB 2.0
    IOS223[38] (rev 4 Info: v0.1): Trucha Bug ES Identify NAND Access USB 2.0
    IOS224[57] (rev 65535 Info: v5.1): Trucha Bug NAND Access USB 2.0
    IOS236 (rev 54321): Trucha Bug ES Identify NAND Access
    IOS245[37] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS246[38] (rev 21008 Info: d2x-v8final): Trucha Bug ES Identify NAND Access
    IOS247[53] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS248[55] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS249[56] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS250[57] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS251[58] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v65535
  • Keithuk
    • Aug 2010
    • 2264
    Well Skylanders Giants is a new game as with Wii games there isn't normally a minimum system spec to play it. Download it and try it, if it works then buy it.
    You will probably need a motion plus controller.
    Your sysCheck looks ok.
    Keith
    2010 Golf GTD (170)
    • randallflagg
      • 27
      probably wont work without the add-on Portal. that's needed to switch between characters i think !
      • Keithuk
        • Aug 2010
        • 2264
        I'm trying it and its asking for USB wirleless receiver/Portal of Power. I assume this is part of the full package you buy?
        Unless you can Google if it will work on your Wii then I don't think its worth the risk of buying it and it doesn't work.
        Keith
        2010 Golf GTD (170)
