WBFS Manager for Windows
  • darkken
    hi this problem doesn't seem to work for me. it won't open up.
    • drawflex
      • 440
      #17
      WBFS manager version 3 is out !
      GET IT HERE
      Changes (3.0):
      Added Channel Creation support. (Disabled by default, to enable go to Options->Channel Creation and Enable. Follow the instructions provided below.)
      Added "Large Cover View"s, which are two side panels that display the cover for the currently selected item.
      Added Automatically Check for Updates option (Requires Internet access, can be disabled).
      Added the option to cancel batch operations (cancellation occurs as soon as the current item is finished).
      Added drive status indicator under the left-hand list, blue shows amount of used space, green shows amount of used space after adding all entries from the "Games To Add" list.
      Added Help menu option.
      Added direct drive-to-drive copying for drive's with similar sector sizes. Drive-To-Drive copying will now first check if it's possible to do direct copying, if not it will revert to indirect copying.
      Fixes (3.0):
      Now automatically requests to Run as Administrator.
      Fixed the estimated size being wrong for some games.
      Fixed an issue with CSV files being exported incorrectly sometimes.
      Save expander states, so the user doesn't have to keep re-opening them each time.
      Fixed Homebrew Channel creation. (Now using WiiCrazy's USB Loader DOL instead of Yal).
      Fixed an issue with the "Estimated Total Size" not updating correctly when games were removed from the right-hand list.
      Now checks the filesystem type of a drive before loading to make sure it's not NTFS, FAT or ext.
      Fixed an issue with games with ":" or other special characters causing issues during batch extraction.
      Fixed issue with game regions showing up incorrectly in initial 2.5 release.
      Fixed issue with RAR files in subfolders not being detected during drag and drop operations.
      Removed thousandth of a seconds from elapsed time in progress bar.
      Fixed mislabled blocks status (was Blocks Used, should be Blocks Free).
      Fixed some other minor issues.
      Changed installer (now prompts for .NET 3.5 SP1 before installing, also gives options for installing langauges, etc).
      'He's not the messiah, he's a very naughty boy'.
      • kid123
        i hope this works
        • renzo217
          • Jul 2010
          yeah wbfs 3.0 is better
          • killer77
            • Jul 2010
            this really helped me out thank ypu
            • lytbrte
              • Jul 2010
              #21
              the wbfs manager never opened up for me... does it work on laptops? i run windows and when i download the 32 bit, it asks me to dl the 64 bit. then when i download the 64 bit, it says download the 32 bit. o_O !!! HELP
              • lytbrte
                • Jul 2010
                #22
                SAME HERE!!! LOOK AT MY POST ABOVE
                • lytbrte
                  • Jul 2010
                  #23
                  OH AND SORRY ABOUT THE MULTIPOST BUT I JUST REMEMBERED SOMETHING... I ONLY TRIED TO DL WBFS MANAGER 3.0
                  • ck-ok
                    • 2592
                    #24
                    try the 3.0.1 version from here wbfsmanager - Release: WBFS Manager 3.0
                    • blindnose
                      • Jul 2010
                      WBFS Manager is great, but I'm missing the linux support for it...
                      Btw, don't forget that you have to use the right usb port (the one which is nearer to the edge of wii
                      • smokinl
                        Going to download now ...
                        I'm looking forward to trying this out. Thanks!
                        • javierirapuato
                          excelent application
                          i?m new on this, and i want to try this aplication
                          • FXless
                            • Apr 2010
                            • 177
                            #28
                            very good app!
                            • r4evolution
                              • Oct 2010
                              thanks, does this work with out installing 3.5?
                              • Borikua65
                                • Oct 2010
                                Version??
                                Hi, Which version of WBFS is this one. Thanks
