Please help I can't get this to work
  • zinali
    Hello,
    The wii is my first venture into console modding. I first used letterbomb while I learned how to do it but in the end it wasn't correct as well as I knew how to do it. So I redid everything with modmii. I think it's all set up pretty much correct now. I have a bunch of apps and emulators working fine. One problem though that I have had since I started is that the loaders can't seem to connect to my HDD. It's a western digital 80g FAT32 formatted drive in a simple enclosure connected through usb of course. Every time I load up usb loader x or CFG my HDD read/write activity turns off. The loader lags as if it is trying to read the drive but then eventually times out. When it's plugged in an on the process of the loader is very long so I can tell it's trying to do something. Because when it's off/not pluuged in/plugged into the incorrect usb the loader times out very quickly. I have 2 games on the HDD via backup manager which seems to work great, backup manager that is. At this point I'm guessing it's a problem with an IOS(totally newb to this and still not sure what these even are) or the HDD isn't compatible even though others seem to be able to use similar HDDs. I have tried a lot of tutorials and troubleshooting guides but just can't figure it out. I ran syscheck from the wiibrew download and it crashes at the end, maybe because it's outdated? I downloaded and installed syscheck GX from the homebrew browser and it produced this.
    sysCheck GX v1.0.0 by Erik Spyder
    sysCheck GX is running under IOS58 (rev 6176).
    Console ID: 82449157.
    Region: NTSC-U.
    Hollywood v0x21.
    Boot2 v4.
    System Menu v513 (4.3U).
    BC v6.
    MIOS v10.
    Found 97 titles.
    Found 52 IOS and 4 IOS Stubs on this console.
    Priiloader is installed.
    IOS 3 (rev 65280): Stub
    IOS 4 (rev 65280): Stub
    IOS 9 (rev 1034)
    IOS 10 (rev 768): Stub
    IOS 11 (rev 16174): Trucha Bug, ES_Identify, NAND Access
    IOS 12 (rev 526)
    IOS 13 (rev 1032)
    IOS 14 (rev 1032)
    IOS 15 (rev 1032)
    IOS 16 (rev 54321): Trucha Bug, ES_Identify, FLASH Access, NAND Access
    IOS 17 (rev 1032)
    IOS 20 (rev 16174): Trucha Bug, ES_Identify, NAND Access
    IOS 21 (rev 1039)
    IOS 22 (rev 1294)
    IOS 28 (rev 1807)
    IOS 30 (rev 16174): Trucha Bug, ES_Identify, NAND Access
    IOS 31 (rev 3608)
    IOS 33 (rev 3608)
    IOS 34 (rev 3608)
    IOS 35 (rev 3608)
    IOS 36 (rev 3608)
    IOS 37 (rev 5663)
    IOS 38 (rev 4124)
    IOS 40 (rev 16174): Trucha Bug, ES_Identify, NAND Access
    IOS 41 (rev 3607)
    IOS 43 (rev 3607)
    IOS 45 (rev 3607)
    IOS 46 (rev 3607)
    IOS 48 (rev 4124)
    IOS 50 (rev 16174): Trucha Bug, ES_Identify, NAND Access
    IOS 51 (rev 4864): Stub
    IOS 52 (rev 16174): Trucha Bug, ES_Identify, NAND Access
    IOS 53 (rev 5663)
    IOS 55 (rev 5663)
    IOS 56 (rev 5662)
    IOS 57 (rev 5919)
    IOS 58 (rev 6176): USB 2.0
    IOS 60 (rev 16174): Trucha Bug, ES_Identify, NAND Access
    IOS 61 (rev 5662)
    IOS 62 (rev 6430)
    IOS 70 (rev 16174): Trucha Bug, ES_Identify, NAND Access
    IOS 80 (rev 16174): Trucha Bug, ES_Identify, NAND Access
    IOS 90 (rev 54321): Trucha Bug, ES_Identify, NAND Access
    IOS202 (rev 65535): Trucha Bug, ES_Identify, NAND Access, USB 2.0
    IOS222 (rev 4): Trucha Bug, ES_Identify, NAND Access, USB 2.0
    IOS223 (rev 4): Trucha Bug, ES_Identify, NAND Access, USB 2.0
    IOS224 (rev 65535): Trucha Bug, ES_Identify, NAND Access, USB 2.0
    IOS236 (rev 65535): Trucha Bug, ES_Identify, NAND Access
    IOS245 (rev 21007): Trucha Bug, ES_Identify, NAND Access
    IOS246 (rev 21007): Trucha Bug, ES_Identify, NAND Access
    IOS247 (rev 21007): Trucha Bug, ES_Identify, NAND Access
    IOS248 (rev 21007): Trucha Bug, ES_Identify, NAND Access
    IOS249 (rev 21008): Trucha Bug, ES_Identify, NAND Access
    IOS250 (rev 21008): Trucha Bug, ES_Identify, NAND Access
    IOS251 (rev 21007): Trucha Bug, ES_Identify, NAND Access
    IOS254 (rev 65281)
  • Keithuk
    • 2264
    Welcome to DK.
    I don't know why you have only found the sysCheck GX v1.0.0 I don't like GX because it doesn't show everything, just use the latest sysCheck v2.1.0 Beta 18
    It looks ok apart from you don't have d2x v8 final wad pack installed.
    You say you have a western digital 80g FAT32 formatted drive in a simple enclosure. Is that a mains powered enclosure?
    I use WBFS Manager and it works perfect on every Wii I've softmodded just try it. If that works ok then it how the games have been added.
    I see you've posted the same question on wiihacks.
    Keith
    2010 Golf GTD (170)
    • zinali
      I'm not sure what a mains powered means, it is powered by it's own adapter that you plug into a normal power outlet. It's in a "rocketfish" enclosure. Found the syscheck on homebrew browser. I wasn't really sure where to get the newest files/programs because I am so new to this. I pulled the drive out and it's says 2003. Also uses scsi...so I'm thinking it may be incompatible. I will test a different one as soon as I can. I installed the v8 shortly after my post. Whenever any loader is about to boot up the read/write light just turns off. Will test with the program you suggested and a new hd.
      • Keithuk
        • 2264
        A mains powered drive is what its says it has a seperate power supply throught a convertor to probably 5v DC. These USB powered drives aren't really suitable as the read time slows it down because of the power needed, which I thought was happening to yours.
        Not all external hard drives are compatible on Wii's unlike computers.
        USB Compatibility List
        USB Devices Compatibility List - WikiTemp
        I've never heard of SCSI drives being used. If you have a large enough USB flash drive that will work just to test. I've had 4 wbfs games in a wbfs folder on a 4GB flash drive and they all worked. Iso files are generally 4.5GB so you would need a big flash drive for those.
        Keith
        2010 Golf GTD (170)
        • zinali
          Well I derped out and was looking at my drive for the compatibility guide. When my enclosure is the issue. It's listed as not working with usb loader and only works with cfg if you change the ios to mload=223. And when it does work like that it doesn't work for long. Gonna pick up another one today. Thanks for the help. Will repost after I get a new one.
