chipped wii help please
  • tempo123
    • 344
    Hi all, I have a bought a second hand wii with "can't read disc error", when I opened up the wii I saw with surprise that the wii has been chipped.....but I can't find any informations on wii hardmodding. Anyway I need a bit of a help because you can see on the picture there is a plastic ribbon white conductor that wasn't plug in anywhere...is it correct? where should it go? Can't find any logic on this drive. I have only find solder less youtube videos but nothing like this. Any idea what to do? I know how to change the lens but a bit unsure on how to handle this chip.Many thanks
  • happy_highlander
    • 3535
    softmod it and use hdd rather than tear you hair out m8
    • Doomingdr
      • 39
      Soft mod is the way to go, I have a 250gb hard drive i play my games from and never had a problem
      • tempo123
        • 344
        Yes I can do that mate and I know that with a softmod the end result is brilliant, but I am really interested on how this chip has been soldered and how can I use it again. I suppose it is more a question of "fun learning" than playing the console. Any idea where I can get a diagram and some reading about it, please?
        • Doomingdr
          • 39
          I have a chip laying around some where will have a look at the connections but if i remember rightly the cable connects to the cd drive directly and then another cable would connect to the wii motherboard - the downside to mine was that the drive packed up and I needed to get a new one off ebay. The newer drives did not allow for the chips to be used.
          • 12345guy12345
            • 162
            I THINK THE CHIP IS CALLED WII KEY AND THERE IS ALSO A WII KEY 2 I HAD ONE FITTED YEARS AGO BUT AFTER ABOUT A YEAR OR SO NEW GAMES WHERE GIVING A 002 ERROR BUT OLDER GAMES WORKED SO I JUST SOFT MODDED NOW I CAN PLAY OFF HD THE PLACE THAT DID CHIP IT ARE PLAYBACKUPS.COM WITH INFO THERE ABOUT THE CHIP
            • tempo123
              • 344
              Thanks mate, well if you have a look on my picture you can see that there are a lot of soldered cables and just a white long ribbon cable there that I have not a clue where it goes, it does not fit any of the possible connectors on the drive. I understand your point, it is what I find online with solderless way to chip the wii drive, but my case is different because a lot of single cables have been soldered to the drive in differen positions... I am clueless....
              • tempo123
                • 344
                Thanks but it is not very clear to me what the guy does.....I suppose I just go for softmodding...quick and easy.
