hi guys anyone know if you can use the store on backup games of just dance 4 to get new songs
cheers
I was just saying I can't get WAD Manager 1.5 or 1.7 to work.
after wad manager 1.7 failed to install the wad i assumed it didnt work,but after starting the game in neogamma and opening the store feature i found the songs were "available" to download.
i dont know why wad manager isnt working for you,my system version is 3.3 maybe its to do with that,just a guess
I've got the USA version. I see the store just fine, I just haven't clicked on purchase just yet. I didn't use any extra anything to see it either. It just works.
I've just tried storing downloaded song on Just Dance 4. It will save them to the Wii memory or an SD card but it asks for 300 Wii points to do each one.
Let me know if you figure it out. If not you will have to install the wad manually into your nand which will require you to use an emu nand within gx or neek2o. The wad has been pulled from a real nand same as what I had to do for folks to get cod online working within neek2o. I would try installing it into either 236 or 249 especially if the game loads from 249.
2.At installation,make sure you get the error -1022 or error -1017.
3.Enter your Just dance 4 game.
4.Go to the song store.
Thats it.All songs should be marked as purchased .
thanks m8 have done all of the above and when i go to store all i get is a error code 206710
now like i say this worked for me,but im not that savvy when it comes to ios`s n stuff,maybe someone else can confirm it is safe for all system versions?,im3.3
you may need to update your shopping channel (DO NOT UPDATE THE WII SYSTEM).
