HELP PLZ WITH WiiFlow
  • danno1980
    • Dec 2012
    • 4
    wii flow worked fine"standed unzip to sd card" before adding music an now just feezes up"black screen" when i load any game ,but usb loader gx works fine still?? heres my syscheck readout ,can anyone please help/tell me what the problem is i also tryed dx cIOS guide with MMM an when i try to install wads just says 7 unsucessful not even sure if i need to update them ,i've been trying to get this to work for 3 days now an starting to pull my hair out thanks
    sysCheck v2.1.0b17 by Double_A and R2-D2199
    ...runs on IOS58 (rev 6176).
    Region: PAL (original region: AUS)
    System Menu 4.3E (v514)
    Priiloader installed
    Drive date: 2007.02.13
    Homebrew Channel 1.0.0 running on IOS58
    Hollywood v0x11
    Console ID: 117251334
    Boot2 v4
    Found 94 titles.
    Found 54 IOS on this console. 5 of them are stub.
    IOS4 (rev 65280): Stub
    IOS9 (rev 54321): Trucha Bug
    IOS10 (rev 768): Stub
    IOS11 (rev 54321): Trucha Bug
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS16 (rev 54321): Trucha Bug, ES Identify, Flash Access, NAND Access
    IOS17 (rev 1032): No Patches
    IOS20 (rev 54321): Trucha Bug
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 54321): Trucha Bug
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 54321): Trucha Bug, ES Identify, NAND Access
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS40 (rev 3072): Stub
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 54321): Trucha Bug
    IOS51 (rev 4864): Stub
    IOS52 (rev 5888): Stub
    IOS53 (rev 5663): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 54321): Trucha Bug
    IOS61 (rev 5662): No Patches
    IOS70 (rev 54321): Trucha Bug
    IOS80 (rev 54321): Trucha Bug
    IOS90 (rev 54321): Trucha Bug
    IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
    IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS223[38+37] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
    IOS236 (rev 54321): Trucha Bug, ES Identify, NAND Access
    IOS245[37] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS246[38] (rev 21008, Info: d2x-v8final): Trucha Bug, ES Identify, NAND Access
    IOS247[53] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS248[55] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS251[58] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v65535
    Report generated on 2012/12/14.
  • Keithuk
    • Aug 2010
    • 2264
    Well your sysCheck looks ok.
    Your other post in http://www.digital-kaos.co.uk/forums...65/index2.html says
    same problem how to use it
    So are you trying to play games of a USB stick.
    What did you update when you said?
    Was that updating d2x v8.0?
    Are you running the latest WiiFlow when you click on About if USB Loader GX works?
    Keith
    2010 Golf GTD (170)
    • danno1980
      • Dec 2012
      • 4
      yes thank you man i got it working was older version of wiiflow an the music i made 0gg.file but it was 17mb dropped it down to under 3mbs an lastest version an works sweet .....only problem i got now is the silly channel/forwarder, i try using MMM's wads manger and when i try to install any of the 5 willflow channels or forwarders wads in same thing unsuscessfull so im not 100% sure if MMM is the best way to install a channel i got wiiMC last night an it came with a channel installer app u run in HBC an automatic installs the channel is there one for wiiflow would make life easyer
      • Keithuk
        • Aug 2010
        • 2264
        You can update any app with an internal link providing the Wii is web connected then you just do a restart the app.
        I always use an mp3 file to play in WiiFlow as thats the only USB Loader that option works.
        There are various WiiFlow Forwarders out there if you Google them. I have Wiiflow Forwarder Channel.wad and WiiFlow Forwarder-WFHL.wad.
        WiiMC has a Forwarder installation but I don't remember using it I just install wiimc106.wad with MMM. WiiMC has many updates when you use it.
        Keith
        2010 Golf GTD (170)
