usb loader gx requires at least cios 222 or 245-250
  • Keithuk
    • 2264
    #16
    You will see alot of 1 post users just post a single comment so they can have access to download files in the download section.
    Keith
    2010 Golf GTD (170)
    • wiiuserchuck
      • Jan 2013
      #17
      Wii Cios 222 required error
      Hi Keith,
      I am getting following error when I try to run the Wii from USB HD
      Please help........
      • wiiuserchuck
        • Jan 2013
        #18
        I followd exactly the same way but still getting the same error - please help
        Thanks in Advance
        • wiiuserchuck
          • Jan 2013
          #19
          I dont see the option for IOS236 in the menu, Please help Thanks.....
          • Keithuk
            • 2264
            #20
            Thats because you haven't read or understood what I've posted before. You need sysCheck to post a report as instructed in that link.
            Originally posted by Keithuk
            Your easiest thing to do now you have the sysCheck.csv file on the root of the SD card from the sysCheck is download ModMii6. 2.4 and run it from Windows. On the main menu type in SU and type in the location of the sysCheck.csv. Its easier to put this on the root of a drive as it saves typo's.
            That will download all wads and apps that are missing into a COPY_TO_SD sub folder. Add all files and folders to your SD card and run Homebrew with the SD card inserted.
            First of run IOS236 Installer from Homebrew and install IOS36 as IOS236, you must do this before you install the other wads. Come back out and run Multi-Mod-Manager and select WAD Manager this will default to the wad folder install all wads in there. Watch for the Installed OK message after each one. If any don't install just try them again.
            Now ModMii only installs 2 d2x v8.0 wads so you may as well install all the others. d2x v8.0 final pack
            Then post a new sysCheck.
            Oh after you've installed all those wads download PriiLoader 0.7 add that to the SD card and run it to block online and disc updates.
            Keith
            2010 Golf GTD (170)
            • three3buchanans
              • Jan 2013
              having same issue with 4.3e stating i need iso 222 or 249?
              • glm1982
                • Feb 2013
                #22
                About to try this I have 2 wiis giving me the same cios 222 error.
                • bee9791
                  Hi Keith I hope it's ok to ask a question here, I have soft modded my wii, and I have the Homebrew Channel but when I go to install the homebrew browser from my sd card an error comes up : homebrowser won't install exception DSI occurred.. I'm wondering what I should do next? Thanks,
                  Stephen
                  • davidr84
                    • Mar 2013
                    #24
                    having the same problem need cios 222 245-250
                    sysCheck v2.1.0b19 by Double_A and R2-D2199, Nano
                    ...runs on IOS58 (rev 6176).
                    Region: NTSC-U
                    System Menu 4.3U (v513)
                    Drive date: 2007.02.13
                    Homebrew Channel 1.1.0 running on IOS58
                    HomebrewFilter ist nicht installiert
                    Hollywood v0x11
                    Console ID: 58642638
                    Boot2 v4
                    Found 85 titles.
                    Found 46 IOS on this console. 16 of them are stub.
                    IOS4 (rev 65280): Stub
                    IOS9 (rev 1034): No Patches
                    IOS10 (rev 768): Stub
                    IOS11 (rev 256): Stub
                    IOS12 (rev 526): No Patches
                    IOS13 (rev 1032): No Patches
                    IOS14 (rev 1032): No Patches
                    IOS15 (rev 1032): No Patches
                    IOS16 (rev 512): Stub
                    IOS17 (rev 1032): No Patches
                    IOS20 (rev 256): Stub
                    IOS21 (rev 1039): No Patches
                    IOS22 (rev 1294): No Patches
                    IOS28 (rev 1807): No Patches
                    IOS30 (rev 2816): Stub
                    IOS31 (rev 3608): No Patches
                    IOS33 (rev 3608): No Patches
                    IOS34 (rev 3608): No Patches
                    IOS35 (rev 3608): No Patches
                    IOS36 (rev 3608): No Patches
                    IOS37 (rev 5663): No Patches
                    IOS38 (rev 4124): No Patches
                    IOS40 (rev 3072): Stub
                    IOS41 (rev 3607): No Patches
                    IOS43 (rev 3607): No Patches
                    IOS45 (rev 3607): No Patches
                    IOS46 (rev 3607): No Patches
                    IOS48 (rev 4124): No Patches
                    IOS50 (rev 5120): Stub
                    IOS51 (rev 4864): Stub
                    IOS52 (rev 5888): Stub
                    IOS53 (rev 5663): No Patches
                    IOS55 (rev 5663): No Patches
                    IOS56 (rev 5662): No Patches
                    IOS57 (rev 5919): No Patches
                    IOS58 (rev 6176): USB 2.0
                    IOS60 (rev 6400): Stub
                    IOS61 (rev 5662): No Patches
                    IOS62 (rev 6430): No Patches
                    IOS70 (rev 6912): Stub
                    IOS80 (rev 6944): No Patches
                    IOS222 (rev 65280): Stub
                    IOS223 (rev 65280): Stub
                    IOS249 (rev 65280): Stub
                    IOS250 (rev 65280): Stub
                    IOS254 (rev 65281): BootMii
                    BC v6
                    MIOS v10
                    Report generated on 2013/03/19.
                    sysCheck #OEZ6Ty5M
                    • Keithuk
                      • 2264
                      #25
                      Welcome to DK David.
                      Read what I said in post #2 and do everything I said?
                      Thats a typical Wii thats only been softmodded with 16 stubs you need to change. There are threads on here that have the same problem.
                      Your easiest thing to do now you have the sysCheck.csv file on the root of the SD card from the sysCheck is download ModMii6. 2.6 and run it from Windows. On the main menu type in SU and type in the location of the sysCheck.csv. Its easier to put this on the root of a drive as it saves typo's.
                      First of run IOS236 Installer from Homebrew and install IOS36 as IOS236, this must be done before you install any other wads. Come back out and run Multi-Mod-Manager and select WAD Manager this will default to the wad folder install all wads in there. Watch for the Installed OK message after each one. If any don't install just try them again.
                      Keith
                      2010 Golf GTD (170)
                      • davidr84
                        • Mar 2013
                        #26
                        Keith
                        I did as told and when I went into mod manager on the wii to install and patch ios 36/246 it states: " Could not open file: sd:IOS36-64-v3608.wad" Could not open file: sd:wad/IOS36-64-v308.wad" Error getting IOS
                        • Keithuk
                          • 2264
                          #27
                          Originally posted by davidr84
                          Keith
                          Thats because you didn't copy all files and folders to the SD card IOS36-64-v3351.wad is missing of the root of the SD card. Its installs IOS36 into IOS236.
                          Don't bother with the SIP folder, I haven't found a use for that.
                          Keith
                          2010 Golf GTD (170)
                          • lloydpogi
                            • Jul 2013
                            Hi Keith this is my system check
                            Region: PAL
                            System Menu 4.3E (v514)
                            Drive date: 2008.12.18
                            Hollywood v0x21
                            Console ID: 148466315
                            Boot2 v4
                            Found 69 titles.
                            Found 46 IOS on this console. 17 of them are stub.
                            IOS3 (rev 65280): Stub
                            BC v6
                            MIOS v10
                            Report generated on 2013/07/09.
                            • Keithuk
                              • 2264
                              #29
                              Welcome to DK.
                              You must have read other posts of mine on here?
                              Thats a typical Wii thats only been softmodded as you have 17 Stubs on the IOS's which you have to bring down to 4 or 5.
                              Your easiest thing to do now you have the sysCheck.csv file on the root of the SD card from the sysCheck is download ModMii6 2.7 and run it from Windows. On the main menu type in SU and type in the location of the sysCheck.csv. Its easier to put this on the root of a drive as it saves typo's.
                              First ofrun IOS236 Installer from Homebrew and install IOS36 as IOS236, you must do this before you install the other wads. Come back out and run Multi-Mod-Manager and select WAD Manager this will default to the wad folder install all wads in there. Watch for the Installed OK message after each one. If any don't install just try them again.
                              You need to download PriiLoader 0.7 add that to the SD card and run it to block online and disc updates, install all the other wads first then run PriiLoader form Homebrew.
                              Keith
                              2010 Golf GTD (170)
                              • aHmonkey
                                • Mar 2014
                                only place that i found any kind of solution to this problem
