USB LOADER GX 3.0
  • 3lektra
    • Dec 2012
    • 12
    USB LOADER GX 3.0
    Hi guys,
    I'm currently using a Mac, which is giving me a hard time,
    as per below my Syscheck
    sysCheck v2.1.0b11 by Double_A and R2-D2199
    ...runs on IOS58 (rev 6176).
    Region: PAL
    System Menu 4.3E (v514)
    Priilaoder installed
    Homebrew Channel 1.0.0 running on IOS58
    Hollywood v0x21
    Console ID: 133946087
    Boot2 v5
    Found 75 titles.
    Found 56 IOS on this console. 4 of them are stub.
    IOS3 (rev 65280): Stub
    IOS4 (rev 65280): Stub
    IOS9 (rev 54321): Trucha Bug
    IOS10 (rev 768): Stub
    IOS11 (rev 16174): Trucha Bug
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS16 (rev 54321): Trucha Bug
    IOS17 (rev 1032): No Patches
    IOS20 (rev 16174): Trucha Bug
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 16174): Trucha Bug
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 54321): Trucha Bug
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS40 (rev 16174): Trucha Bug
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 16174): Trucha Bug
    IOS51 (rev 4864): Stub
    IOS52 (rev 16174): Trucha Bug
    IOS53 (rev 5663): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 16174): Trucha Bug
    IOS61 (rev 5662): No Patches
    IOS62 (rev 6430): No Patches
    IOS70 (rev 16174): Trucha Bug
    IOS80 (rev 16174): Trucha Bug
    IOS90 (rev 54321): Trucha Bug
    IOS202[60] (rev 65535
    IOS222[38] (rev 4
    IOS223[38] (rev 4
    IOS224[57] (rev 65535
    IOS236 (rev 65535): Trucha Bug
    IOS245[37] (rev 21007
    IOS246[38] (rev 21007
    IOS247[53] (rev 21007
    IOS248[55] (rev 21007
    IOS249[56] (rev 21007
    IOS250[57] (rev 21007
    IOS251[58] (rev 21007
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v65535
    Report generated on 2012/12/30.
    Can Someone explain me why USB LOADER GX 3.0 won't work ?
    or explain me the step by step how to instal it properly
    Regards
    Audrey
  • Keithuk
    • 2264
    Welcome to DK Audrey.
    Thats a sysCheck v2.1.0b11 ideally you should have used sysCheck b18.
    I don't know if a MAC has a different word processor but there are words missing of the lower IOS's. The rev 21007 looks like you only have d2x v7.0 final installed
    IOS245[37] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    IOS246[38] (rev 21007, Info: d2x-v7final): Trucha Bug, ES Identify, NAND Access
    IOS247[53] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    IOS248[55] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    IOS249[56] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    IOS250[57] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    IOS251[58] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    Download and install d2x v8.0 final wad pack and add all 7 files to the wad folder on the SD card and install them with Multi-Mod Manger 13.4 from Homebrew.
    Do you get any error message when you try and see the games on the drive?
    How are these games added to the drive and how is it formatted?
    If the above d2x v8.0 doesn't cure your problem you can download the older USB Loader 2.3 and add tthat to the SD card. Don't add the d2x v7 wad pack else you will be back where you started from. Multi-Mod Manger 13.4 is in this package if you don't have it in the apps folder on the SD card.
    Keith
    2010 Golf GTD (170)
    • 3lektra
      • Dec 2012
      • 12
      Hi Keithuk, Thanks for the welcoming
      Thank you also for your help, unfortunately it still doesn't work,
      but there is a progress, the USB LOADER GX start and recognise the game on the usb, but it wont start, before adding game on it i wanted it to back up a disc to make sure i have the right format,
      My usb is on fat32, and I have one game on wsbf which is not recognised,
      The other day I've tried to add New super Mario bros, it seems it did add it but when you start to load the game on the USB it doesn't open it also at the end of the upload (100%) it doesn't show any close or exit only a cancel button
      See below NEW SYSCHECK (I have instal the one you gave me on the link) I also add the 7 wad you said were missing, but when i read this report it seems it still the same problem...
      sysCheck v2.1.0b18 by Double_A and R2-D2199
      Region: PAL
      Priiloader installed
      Drive date: 2010.12.07
      Homebrew Channel 1.1.0 running on IOS58
      Hollywood v0x21
      Boot2 v5
      Found 80 titles.
      IOS9 (rev 1034): No Patches
      IOS36 (rev 3608): No Patches
      IOS222[38] (rev 4
      IOS223[38+37] (rev 4
      IOS236[36] (rev 65535
      BC v6
      MIOS v10
      Report generated on 2012/12/31.
      • Keithuk
        • 2264
        Well Audrey as I said before:
        Its still showing rev 21007 after installing d2x v8.0 final wads pack, the number should have changed to rev 21008.
        IOS245[37] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
        IOS246[38] (rev 21008, Info: d2x-v8final): Trucha Bug, ES Identify, NAND Access
        IOS247[53] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
        IOS248[55] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
        IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
        IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
        IOS251[58] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
        On the Wii if you scrolll down the report afterwards you should be able to see Info: d2x-v8final on the IOS's at the bottom. Sometimes it says uploading that adds a web link at the bottom, if it does post that.
        I've always used WBFS Manager to add games to my drive and its never failed. Give its a try you have nothing to loose, only remove any games of the drive as those will be lost as the first job is find the drive letter and click Format before you can add any games onto it. I've also tried Wii Backup Manager but I don't like that.
        Whats the make and model of your external USB hard drive, I hope it isn't a USB powered drive? Not all drives are compatible.
        USB Compatibility List
        USB Devices Compatibility List - WikiTemp
        Did you try the old USB Loader GX v2.3 I gave the link to. I also said don't install the d2x v7 wad pack else you will be back where you started from as that sysCheck is showing.
        Happy New Year.
        Keith
        2010 Golf GTD (170)
        • 3lektra
          • Dec 2012
          • 12
          Sorry for late reply,
          I've noticed the ios36 is back to no patches, I've got now the update for below ios :
          Syscheck refused to download the check as I can copy all it here
          USB LOADER recognize game but wont launch it it get back to the main menu of the wii
          • 3lektra
            • Dec 2012
            • 12
            there you go Keith :
            Region: PAL
            Hollywood v0x21
            Boot2 v5
            Found 81 titles.
            IOS36 (rev 3351): No Patches
            IOS222[38] (rev 4
            BC v6
            MIOS v10
            Report generated on 2013/01/13.
            • Keithuk
              • 2264
              Well it appears to look better now you have d2x v8.0 installed Audrey.
              I'm not sure why IOS36 (rev 54321): Trucha Bug as been removed to No Patches its the same as mine IOS36 (rev 3608): No Patches and my system works.
              Why it jumps back to the Wii menu after you click on a game its probably down to the drive or how its formatted or how you've added the games.
              As I've said before.
              Keith
              2010 Golf GTD (170)
              • 3lektra
                • Dec 2012
                • 12
                I made it work,
                USB LOADER GX works perfectly,
                only got trouble to find the right wbfs manager for mac and the one I find doesn't recognise my hard drive when i plugged it in
                Keith Thanks for your help
                Regarding to the games they cannot be named differently than those weird code right ?
                what about the cover ?
                Can you put folder in the wbfs folder ?
                to know which game is which ?
                • Keithuk
                  • 2264
                  Have you Googled wbfs manager for mac there are alot that talk about it?
                  WBFS for MACOS X1.2
                  I tried Wii Backup Manager over Christmas on my spare drive. I added a few iso games and a few wbfs games. It made a wbfs folder on the drive and converted them all to the game ID name and wbfs file type.
                  Google Wii Backup Manager MAC
                  Can you put folder in the wbfs folder? I'm not sure I haven't really tried it. Everything works perfectly for me with WBFS Manager.
                  You can search for game ID's in Wii Boxart
                  Keith
                  2010 Golf GTD (170)
                  • happy_highlander
                    • 3535
                    gx will download all boxart pressing "1" on the wiimote whilst on the main screen. Just choose what you would like to download...I would recommend 3d, 2d, original and custom disc....That way you will get all the covers
                    • Keithuk
                      • 2264
                      Welcome back HH long time no see.
                      Providing the Wii is networked then it should download the game pics as you say. I was just showing her a way of getting the game ID.
                      The main problem she has is using apps that will run on a MAC like WBFS Manager or Wii Backup Manager.
                      Keith
                      2010 Golf GTD (170)
                      • happy_highlander
                        • 3535
                        Shouldn't be trying to use an a Apple product for something that is designed to use a system for a use its notintended for
                        • 3lektra
                          • Dec 2012
                          • 12
                          Thanks for your helps guys,
                          I manage to make it work true a different way the wad manager isn't a good idea for mac, every one talks about it but it doesnt' really work for mac,
                          Other question Can we upload game straight to the loader gx or do we have to go to the laptopt/computer to load them to the hdd ?
                          • Keithuk
                            • 2264
                            You download games to your computer then add them to the HDD with which ever software your using. You can install games to the HDD from a disc. On USB Loader GX if you insert a disc while its running it will ask if you want to install or you click the small + button bottom left.
                            Keith
                            2010 Golf GTD (170)
                            • 3lektra
                              • Dec 2012
                              • 12
                              All done Keith
                              GOt a new thread for all different games from others console....
                              If you can help
