How make Skylanders (original) run on softmodded 4.1E?
  • darson
    • Dec 2011
    • 9
    EDIT: Problem fixed - just found out the skip update on Priiloader was not enabled, just followed this guide - starting up the wii while pressing reset button: [ame="http://www.youtube.com/watch?v=531RVoABFVQ"]Suppress Wii Disc Updates with Priiloader - YouTube[/ame]
    Kids got a Skylanders Giant pack with the USB portal and figures for xmas. Alas, when inserting the DVD it wants to update system. Of course I do not run it.
    I have homebrew and usb loader gx, my wii is 4.1E.
    No problem running other original games like Mario Kart etc.
    I do not remember what I used to softmod this, it is a year ago or more. Ran a syscheck, and the result is as following.
    Anyone that knows a quick fix for this problem?
    sysCheck v2.1.0b18 by Double_A and R2-D2199
    ...runs on IOS37 (rev 5663).
    Region: PAL
    System Menu 4.1E (v450)
    Priiloader installed
    Drive date: 2007.02.13
    Homebrew Channel 1.0.8 running on IOS37
    Hollywood v0x11
    Console ID: 62327767
    Boot2 v3
    Found 87 titles.
    Found 46 IOS on this console. 2 of them are stub.
    IOS4 (rev 65280): Stub
    IOS9 (rev 1034): No Patches
    IOS10 (rev 768): Stub
    IOS11 (rev 16174): Trucha Bug, NAND Access
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS17 (rev 1032): No Patches
    IOS20 (rev 16174): Trucha Bug, NAND Access
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 16174): Trucha Bug, NAND Access
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 3608): No Patches
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS40 (rev 16174): Trucha Bug, NAND Access
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 16174): Trucha Bug, NAND Access
    IOS52 (rev 16174): Trucha Bug, NAND Access
    IOS53 (rev 5663): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 16174): Trucha Bug, NAND Access
    IOS61 (rev 5662): No Patches
    IOS70 (rev 16174): Trucha Bug, NAND Access
    IOS80 (rev 16174): Trucha Bug, NAND Access
    IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
    IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS223[38+37] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
    IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
    IOS249[56] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    IOS250[57] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    IOS254 (rev 65281): BootMii
    BC v5
    MIOS v10
    Report generated on 2013/01/01.
  • Keithuk
    • 2264
    Just reading the Skylanders online manual it says it checks if the Wii system is up to date meaning a 4.3 system. Your system is 4.1E so it asks you to update. This would mean that the update would remove the softmod so you would have to softmod it again if you want Skylanders Giants working.
    Happy New Year.
    Keith
    2010 Golf GTD (170)
    • redondo5
      • 277
      is there not a workaround?
      maybe install the dvd onto hard disk using your loader (cfg?)
      then run the patches from the loader to run the game... have you tried that - assuming you are using a usb disk loader
      • HQS
        • Dec 2012
        • 4
        Here's the quick solution.
        Rip the game to your USB drive and load it using CFG V70. Select the Skylander's game, goto options and load the game using Ios 223. In looking at your syscheck, you already have version 4 of hermes in slot 223 so it should boot up and recognize the portal or power. U should be able to play the game now..
