Error USB Device not found. Switchiing to channel list mode.
I am getting the same error, and it is looking for the HDD too. But I cannot download the file since it says that I don't have access to that file.
Originally posted by Muasau
I did as you said. Installs "D2X v8.0 final wad pack" and "my wad pack". But, now USBLoaderGX not find my HDD. It counts down 20 seconds. And does not find HDD.
Then I try to backup a game. It reads disk but says 0.0Gb.
sysCheck v2.1.0b19 by Double_A and R2-D2199, Nano
...runs on IOS58 (rev 6176).
Region: PAL
System Menu 4.3E (v514)
Priiloader installed
Drive date: 2007.02.13
Homebrew Channel 1.1.0 running on IOS58
HomebrewFilter ist nicht installiert
Hollywood v0x11
Console ID: 115512241
Boot2 v4
Found 74 titles.
Found 50 IOS on this console. 4 of them are stub.
IOS4 (rev 65280): Stub
IOS9 (rev 1034): No Patches
IOS10 (rev 768): Stub
IOS11 (rev 16174): Trucha Bug, NAND Access
IOS12 (rev 526): No Patches
IOS13 (rev 1032): No Patches
IOS14 (rev 1032): No Patches
IOS15 (rev 1032): No Patches
IOS16 (rev 512): Stub
IOS17 (rev 1032): No Patches
IOS20 (rev 16174): Trucha Bug, NAND Access
IOS21 (rev 1039): No Patches
IOS22 (rev 1294): No Patches
IOS28 (rev 1807): No Patches
IOS30 (rev 16174): Trucha Bug, NAND Access
IOS31 (rev 3608): No Patches
IOS33 (rev 3608): No Patches
IOS34 (rev 3608): No Patches
IOS35 (rev 3608): No Patches
IOS36 (rev 3351): Trucha Bug, ES Identify, NAND Access
IOS37 (rev 5663): No Patches
IOS38 (rev 4124): No Patches
IOS40 (rev 16174): Trucha Bug, NAND Access
IOS41 (rev 3607): No Patches
IOS43 (rev 3607): No Patches
IOS45 (rev 3607): No Patches
IOS46 (rev 3607): No Patches
IOS48 (rev 4124): No Patches
IOS50 (rev 16174): Trucha Bug, NAND Access
IOS51 (rev 4864): Stub
IOS52 (rev 16174): Trucha Bug, NAND Access
IOS53 (rev 5663): No Patches
IOS55 (rev 5663): No Patches
IOS56 (rev 5662): No Patches
IOS57 (rev 5919): No Patches
IOS58 (rev 6176): USB 2.0
IOS60 (rev 16174): Trucha Bug, NAND Access
IOS61 (rev 5662): No Patches
IOS62 (rev 6430): No Patches
IOS70 (rev 16174): Trucha Bug, NAND Access
IOS80 (rev 16174): Trucha Bug, NAND Access
IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
IOS245[37] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS246[38] (rev 21008, Info: d2x-v8final): Trucha Bug, ES Identify, NAND Access
IOS247[53] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS248[55] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS251[58] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS254 (rev 65281): BootMii
BC v6
MIOS v10
I don't see much wrong with your sysCheck only Full cios wad pack is missing wads 202, 222, 223 and 224.
Well the second picture you've shown USB device not found switching to channel list mode. Means it can't find the HDD plugged in. That normally means its formatted wrong, its an incopmpatible HDD or you've added the games onto the drive incorrectly.
Now you've made you first post you should be able to download files in that section.
I've heard of this wii error #002 talked about if you Google it. Do you know something I've missed a few wads of your sysCheck that I've only just seen 202, 222, 223 and 224. Like I said to dlhilario yesterday.
I was probably looking at the total stub count. Try these wads first. That won't make the total stub count to 0.
In USB Loader GX settings there is an option to turn the Error 002 Fix you can turn ON/OFF make sure its ON. There are loads of video's on YouTube about this error.
I understood what you said you only get this error when you play original game disc from the disc channel. The games on the HDD play ok. Have you installed the missing wads I said you needed?
Is the USB Loader GX settings option to turn the Error 002 Fix turned ON?
Well I don't know what to say if you've installed 202, 222, 223 and 224 wads your sysCheck is going to the the same as mine and my system doesn't show that error if I play a genuine disc.
Region: PAL
Drive date: 2008.07.14
Homebrew Filter is not installed
Hollywood v0x11
Console ID: 91742115
Boot2 v4
Found 134 titles.
Found 55 IOS on this console. 4 of them are stub.
IOS3 (rev 65280): Stub
IOS16 (rev 54321): Trucha Bug, ES Identify, Flash Access, NAND Access
IOS36 (rev 3608): No Patches
IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS223[38+37] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
BC v6
MIOS v10
