Need help with first time softmod wii
  • skullmen1990
    • Jan 2013
    • 11
    Hi
    I have just recently bought a Wii and have just softmodded today
    using the Letterbomb.
    Through some browsing of your awesome forums, I've managed to
    1) install the Homebrew Channel
    2) Installed Bootmii
    3) Backed up the SD
    I've previously thought that now all I need to do is install the
    WBFS manager, format my SDHC into a WBFS format
    then copy the .iso file (games) I've downloaded over the
    the WBFS-formatted SDHC and plug it into the Wii
    and I can play it through the Homebrew Channel.
    Alas, through much searching it seems I need much more than that
    but now I'm lost with all the priiloader, USB Loader, all the different
    types of IOS etc etc.
    I was hoping someone can guide me through the next few steps to
    end up being able to play .iso files through a USB?SD?External Harddrive?
    (I've read since my Wii is a new one, I wont be able to burn DVD)
    Here is my Syscheck to see exactly what kind of situation I'm on
    sysCheck v2.1.0b19 by Double_A and R2-D2199 Nano
    ...runs on IOS58 (rev 6176).
    Region: PAL (original region: AUS)
    System Menu 4.3E (v514)
    Drive date: 2007.02.13
    Homebrew Channel 1.1.0 running on IOS58
    HomebrewFilter ist nicht installiert
    Hollywood v0x11
    Console ID: 120652183
    Boot2 v4
    Found 68 titles.
    Found 47 IOS on this console. 17 of them are stub.
    IOS3 (rev 65280): Stub
    IOS4 (rev 65280): Stub
    IOS9 (rev 1034): No Patches
    IOS10 (rev 768): Stub
    IOS11 (rev 256): Stub
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS16 (rev 512): Stub
    IOS17 (rev 1032): No Patches
    IOS20 (rev 256): Stub
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 2816): Stub
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 3608): No Patches
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS40 (rev 3072): Stub
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 5120): Stub
    IOS51 (rev 4864): Stub
    IOS52 (rev 5888): Stub
    IOS53 (rev 5663): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 6400): Stub
    IOS61 (rev 5662): No Patches
    IOS62 (rev 6430): No Patches
    IOS70 (rev 6912): Stub
    IOS80 (rev 6944): No Patches
    IOS222 (rev 65280): Stub
    IOS223 (rev 65280): Stub
    IOS249 (rev 65280): Stub
    IOS250 (rev 65280): Stub
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v10
    Thanks a bunch in advance
  • Keithuk
    • 2264
    Welcome to DK.
    Well that a typical sysCheck of a Wii thats only been softmodded. You need to remove most of those IOS's that are stub down to 4 or 5.
    So you've softmodded it using all 3 options.
    1) Install the Homebrew Channel
    2) Installed Bootmii in IOS
    3) Prepared SD card - so you can do a NAND backup straight after softmodding.
    I've posted solutions to this problem in a few threads on here if your browse.
    Originally posted by Keithuk
    Well your sysCheck is a typical Wii thats only been softmodded with 17 stubs which you have to knock down to about 5.
    You need to download ModMii6.2.6 and run it from Windows. Now you have the sysCheck.csv file from the sysCheck which will be on the root of the SD card you can choose the SU option from the main menu. Type in the location of sysCheck.csv.
    This will download all files into COPY_TO_SD sub folder. Add all files and folders to your SD card and run Homebrew with the SD card inserted. ModMii only adds 2 d2x v8.0 wads so install all 7 wads from d2x v8.0 final wad pack after you've added them to the wad folder on the SD card.
    Run IOS236 installer from Homebrew first to install IOS36 into IOS236, you must do this before you install any other wads. Come back out then run Multi-Mod Manager and select WAD Manager and install all wads in that folder.
    You will need PriiLoader 0.7 installing to block online and disc updates.
    Your Drive date: 2007.02.13 so you should be able to play burnt discs but they aren't really worth it as you need to buy quality DVD's then find somewhere to store them all.
    The other thing is you say you've downloaded WBFS Manager which is great thats what I've always used but your trying to add games to a SDHC card. You don't say how big this SDHC card is but it won't be big enough. You need to locate a compatible mains powered USB hard drive to add all the games you will eventually get.
    Now there are 3 main USB Loaders, USB Loader GX, CFG USB Loader, WiiFlow the main one that most people use is USB Loader GX. Now you can Google this name and don't the neceassary files and add them to the SD card. If you don't have any success doing this we have USB Loader GX on here. Its also advisable to have USB Loader GX on the Wii menu that will save running HBC then clicking on USB Loader GX.
    You need to download Download Forwarder only and put USB Loader GX-UNEO_Forwarder_5_1_AHBPROT.wad in the wad folder on the SD card and install it with MMM.
    You can run sysCheck again and post a new sysCheck report afterward installing all the wads just to make sure all the necessary IOS's are installed.
    Keith
    2010 Golf GTD (170)
    • skullmen1990
      • Jan 2013
      • 11
      Hi Keithuk
      Thanks for the quick and detailed reply
      I've installed most of it using the MMM
      Heres a SysCheck report to see if you can spot anything wrong
      sysCheck v2.1.0b19 by Double_A and R2-D2199, Nano
      Priiloader installed
      Hollywood v0x11
      Boot2 v4
      Found 72 titles.
      Found 50 IOS on this console. 5 of them are stub.
      IOS11 (rev 16174): Trucha Bug, NAND Access
      IOS20 (rev 16174): Trucha Bug, NAND Access
      IOS30 (rev 16174): Trucha Bug, NAND Access
      IOS40 (rev 16174): Trucha Bug, NAND Access
      IOS50 (rev 16174): Trucha Bug, NAND Access
      IOS52 (rev 16174): Trucha Bug, NAND Access
      IOS60 (rev 16174): Trucha Bug, NAND Access
      IOS70 (rev 16174): Trucha Bug, NAND Access
      IOS80 (rev 16174): Trucha Bug, NAND Access
      IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
      IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
      IOS223[38+37] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
      IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
      IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
      IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
      IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
      BC v6
      MIOS v10
      Report generated on 2013/02/01.
      • skullmen1990
        • Jan 2013
        • 11
        I'm just in the process of downloading the USBLoader GX V3.0
        I haven't got an externally powered HDD so I'll have to get one
        before I can let you know more on how I'm going
        • skullmen1990
          • Jan 2013
          • 11
          So I've just downloaded the USBLoader GX 3.0 All-in-One from
          the Digital Kaos downloads and have installed it into my SD card.
          When I try open the USB Loader in the Homebrew Channel
          its says 'detecting HDD... 20seconds remaining'
          which means I probably need to have a HDD connected so
          this will have to wait I guess.
          So is there anything else I need to do? or can I just put the game
          .isos into an external HDD, connect it to Wii and run the
          USB Loader through Homebrew Channel and can start playing?
          Keithuk, I'm not too sure about
          your last few line about the Forwarder WAD.
          I've found four or so WAD Files that was included in the
          All-in-One pack such as
          1) Channel IDOL
          2) Forwarder DOL
          3) USB Loader GX-UNEO_Forwarder_5_1_AHBPPROT
          and 4) USBLoader_GX_V3_O_UNLR_Channel1_AHBPPROT.
          Is all I need to install the 4) one that you've told me to?
          Do I have to worry about installing these other WADS files?
          • Keithuk
            • 2264
            Well I don't know whats wrong with this forum yesterday and today I spend 5 minutes working out a reply and I clicked on preview and it showed I click submit and it came back with a database error. Luckly I copied and pasted in a file as a backup.
            I'll try again.
            That sysCheck look ok apart from you didn't do everything I said. you only installed the 2 ModMi d2x v8.0 wads
            If you want to remove the IOS16 stub which isn't critical, just add cIOS16-v257.zip and add it to the wad folder and install it with MMM.
            When I searched for USB Loader GX the I couldn't find the main site so I posted that link which should work. I've since found the main site USB Loader GX you need the IOS249 package. This site has Forwarders on the left so just download USB Loader GX-UNEO_Forwarder_5_1_AHBPROT.wad in the wad folder on the SD card and install it with MMM.
            If the same forwarder is in the package you downloaded then use that one.
            You said you were using a SDHC card to add game to as I said those aren't big enough. Ideally you need a mains powered USB hard drive, obviously the biggest you can afford. My first drive was a 120GB and that would hold 67 games.
            Install the other wads I suggested then try you SD card/drive to see if they play if they don't that your SD card/drive isn't suitable.
            Post a new sysCheck afterwards.
            Keith
            2010 Golf GTD (170)
            • skullmen1990
              • Jan 2013
              • 11
              Hey Thanks Keithuk
              Yup I completely forgot about the extra d2x packs
              So I've done the three things u asked, the
              1) d2x final WAD pack
              2) IOS16 stub removal
              and 3) The Forwarder
              Here is the SysCheck
              Hollywood v0x11
              Boot2 v4
              Found 78 titles.
              Found 55 IOS on this console. 4 of them are stub.
              IOS16 (rev 54321): Trucha Bug, ES Identify, Flash Access, NAND Access
              IOS245[37] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
              IOS246[38] (rev 21008, Info: d2x-v8final): Trucha Bug, ES Identify, NAND Access
              IOS247[53] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
              IOS248[55] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
              IOS251[58] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
              BC v6
              MIOS v10
              Anything else I need to do?
              • skullmen1990
                • Jan 2013
                • 11
                I've just formatted a 16gb flash drive into WBFS format
                and put in a Mario.iso and plugged in into the back of Wii.
                Then I've tried loading the USB Loader GX through both
                Wii channel and the Homebrew Channel but it says the
                USB Device is not found
                Does the Flash Drive have to be partitioned to X + WBFS
                or can it just be fully WBFS formatted through WBFS Manager?
                • skullmen1990
                  • Jan 2013
                  • 11
                  When I plug the USB in the top USB port, it says
                  waiting for HDD... 20sec countdown before saying
                  'USB DEvice is not found'
                  However if I plug it into the bottom USB Port,
                  it DOESN'T come up with the 20 second message
                  and goes straight to 'USB Device not found'
                  Hope this helps too
                  • Keithuk
                    • 2264
                    Thats sysCheck looks ok now.
                    Now these USB sticks/drives will only work of the port at the bottom or nearest the edge as you've found out. That was something I forgot to mension after sorting out your wads.
                    This depends on the users if they want to use all the space on the drive for games. If your using a 16GB flash drive then let it format all the drive to WBFS. Even though its call WBFS Manager it won't add wbfs files to a drive. Even if you save a game of a drive it saves it back as an iso. When you add an iso file to the list of games to be added you will se 2 file sizes. The original iso will be around 4.36GB then in the middle it will say 2.2GB after its been converted to wbfs on the drive.
                    I use Wii Game Converter GXS to convert any wbfs files I have to iso.
                    At Christmas time I tried different things on my spare 120GB drive. I formatted it NTFS in Windows and made two folders games and wbfs. I added a few iso files in the games folder and a few wbfs files in the wbfs folder. Now I read somewhere these filenames have to be the Wii game ID number then the game name. I put the drive back in the Wii and started USB Loader GX, it would only show the wbfs games in that wbfs folder.
                    I deleted all files a folder and I tried Wii Backup Manager and added the same iso and wbfs files to the drive, its still formatted NTFS which the later USB Loaders support. As it was adding the games to the drive it only made a wbfs folder and is converted the iso files to wbfs files. It only named them the Wii game ID number. I put the drive back in the Wii and all games showed.
                    As I've said I've always used WBFS Manager to add games to a drive and that has never failed. As I said the drive has to be compatible which is strange because all drive/fash drives are media storage devices so why are some compatible and some aren't?
                    You don't say the make or type of the 16GB flash drive you have, check out the drives.
                    USB Compatibility List
                    USB Devices Compatibility List - WikiTemp
                    Its a matter of finding a compatible drive.
                    Keith
                    2010 Golf GTD (170)
                    • skullmen1990
                      • Jan 2013
                      • 11
                      Yea it was a silicon power 16gb which I couldnt find
                      in the compatibility list so I guess I'll have to get one that is
                      Thanks for all the help
                      • Keithuk
                        • 2264
                        Sorry I missed something else with talking and wads and drives. Download PriiLoader 0.7 this will block any online or disc updates, I remove the 'A' safety prompt on startup.
                        If you used ModMii as suggested that should have added PriiLoader in the apps folder on the SD card.
                        Keith
                        2010 Golf GTD (170)
                        • skullmen1990
                          • Jan 2013
                          • 11
                          Yup I downloaded it as part of the ModWii and disabled four things including the updates and health start up thing
                          • Keithuk
                            • 2264
                            That ok then.
                            4 things you only need 2 disable online and disc updates the disable 'A' prompt is something I like to do.
                            ModWii, ModMii.
                            Keith
                            2010 Golf GTD (170)
                            • skullmen1990
                              • Jan 2013
                              • 11
                              Hey Thanks for all your help keithuk
                              I've managed to get it working!!
                              I had to try another external HDD (not externally powered :O)
                              which worked!!
                              Thanks again
