Some game suddenly stopped working! USB LOADERS
  • thethiny
    • Feb 2013
    • 5
    Hi,
    first of all I'm not a noob in Wii hacking or anything related to the wii , because I've been modding my Wii since 2008.
    Ok so..I was playing New super mario Bros using WiiFlow , everything working fine , then I decided that I should download the boxart. Once I did , it started giving me file not found error. I kept trying , after around 5 times I got the cover , but only in red color , no boxart image. After this , I was not able to play the game! I downloaded the covers of many other games , and they all failed , but the games worked , one succeeded , but the game failed to load.
    I tried using USB Loader GX (I believe v1.5) and the games work fine.
    So basically , anygame I download a cover for doesn't work, is there any reason or something I'm missing?
    When I downloaded covers yasterday everything worked fine. The covers are stored on my SD 1GB.
    please tell me what options should I try!
    EDIT:SOLVED! Looks Like Fix 002 Fixed the problem , I wonder how USB loader launched it without 002 Fix , any thoughts? Also one more question:
    I tried USB loader and WiiFlow on Mario Strikers , on USB loader , Mario said "Games" , and when I press home I see gray stripes. when I used wii Flow , PEach said "Games" and the screen looked better and more highres, but the controller kept releasing a tone sound.
    Download Covers Again
    0%
    Open SD from PC and remove the Covers
    0%
    This is normal , WiiFlow Can't run that game
    0%
  • Keithuk
    • 2264
    I have all the 3 USB Loaders but I only use USB Loader GX v3.0, I have the others if someone says a particular games don't work, as you've done.
    Every Wii game has an ID number which is unique to that game. I've search Wii Boxart for Mario and there are a few New Super Mario Bros games. If this problem only arose after downloading the cover art that shouldn't make any difference to the game as they are only the pictures that are displayed.
    WiiFlow only saves 2 pictures the full boxart picture in SD:\WiiFlow\boxcovers and the 2D pictures in SD:\WiiFlow\covers. If you know the game ID number search for these in the correct folder and just delete them, then try the game again.
    The other thing I notice is you aren't using the newest versions of these USB Loaders e.g. USB Loader GX (I believe v1.5). I've never used 1.5 its always been 2.3 and 3.0 so you need to update all your USB Loaders to the newest version in settings. On WiiFlow you just click the About button bottom left and update.
    So I can see you have all the correct IOS's installed you need to post a sysCheck19 report as instructed in that link.
    You say you have corrected this error by Fix 002, the Fix 002 is always enabled on mine so why do you want to disable it?
    Keith
    2010 Golf GTD (170)
    • thethiny
      • Feb 2013
      • 5
      Thanks for the reply , I read the tips and they say 002 must be off unless in certain cases , I'll try to put it always on.
      Anyways, Now I have bough an HDD (Seagate 500GB). It works.
      CFG: Can see games and play.
      Usb Loader: Cann See Games but Not Play!
      WiiFlow: Can't See Games , WBFS_Open Error -1
      HDD is formatted as NTFS. I don't want to format it as WBFS as I want to access it from my PC and be able to check whats inside.
      Edit:
      my CFG is running on IOS 248[56] d2x
      GX (2.3) not 1.5 , running on IOS 249[57]waninkoko rev21
      WiiFlow , running on IOS 249[57]waninkoko rev21
      maybe that's the problem?
      EDIT: fixed by using d2x v10
      • Keithuk
        • 2264
        You need to do what I've asked?
        You can set Fix 002 for all games and you can turn it off in that particular game settings.
        Keith
        2010 Golf GTD (170)
        • 12345guy12345
          • 162
          i had the same problem getting the pics for games and a tutorial that i read and helped me to sort it was to go on to your sd card where the covers folder is and delete all the pics in the folder so it is empty then put back into the wii then using the usb loader download the covers through that
