USB loader gx error/no USB found
  • koopa
    • May 2013
    Hi,
    I softmodded my Wii recently after my disc drive stopped working. I followed the steps on this tutorial & I downloaded the USB loader from here.
    When loading USB loader GX I get this error: usbloader requires at least cIOS 222 or 245-250.
    Once open I get "USB Device not found. Switching to channel list mode".
    Based on another post here, it seems like this (Usbloader gx 2.3 r1128 and d2x v7 with mmm 13.4 - Downloads - Digital Kaos) would solve my problem, but I'm not entirely sure.
    Any help is greatly appreciated, thank you!
  • Keithuk
    • 2264
    Welcome to DK.
    You need to post a sysCheck19 report as instructed in that link so I can see which IOS's you've installed.
    You need to download The ultimative All-In-One package for USB Loader GX v3.0 (boot IOS 249) there is no point in downloading the old USB Loader GX 2.3.
    Keith
    2010 Golf GTD (170)
    • koopa
      • May 2013
      Thank you!
      I erased and redownloaded the All In One.
      My system check:
      sysCheck v2.1.0b19 by Double_A and R2-D2199, Nano
      ...runs on IOS58 (rev 6176).
      Region: NTSC-U
      System Menu 4.3U (v513)
      Drive date: 2007.02.13
      Homebrew Channel 1.1.0 running on IOS58
      HomebrewFilter ist nicht installiert
      Hollywood v0x11
      Console ID: 57258358
      Boot2 v4
      Found 120 titles.
      Found 46 IOS on this console. 16 of them are stub.
      IOS4 (rev 65280): Stub
      IOS9 (rev 1034): No Patches
      IOS10 (rev 768): Stub
      IOS11 (rev 256): Stub
      IOS12 (rev 526): No Patches
      IOS13 (rev 1032): No Patches
      IOS14 (rev 1032): No Patches
      IOS15 (rev 1032): No Patches
      IOS16 (rev 512): Stub
      IOS17 (rev 1032): No Patches
      IOS20 (rev 256): Stub
      IOS21 (rev 1039): No Patches
      IOS22 (rev 1294): No Patches
      IOS28 (rev 1807): No Patches
      IOS30 (rev 2816): Stub
      IOS31 (rev 3608): No Patches
      IOS33 (rev 3608): No Patches
      IOS34 (rev 3608): No Patches
      IOS35 (rev 3608): No Patches
      IOS36 (rev 3608): No Patches
      IOS37 (rev 5663): No Patches
      IOS38 (rev 4124): No Patches
      IOS40 (rev 3072): Stub
      IOS41 (rev 3607): No Patches
      IOS43 (rev 3607): No Patches
      IOS45 (rev 3607): No Patches
      IOS46 (rev 3607): No Patches
      IOS48 (rev 4124): No Patches
      IOS50 (rev 5120): Stub
      IOS51 (rev 4864): Stub
      IOS52 (rev 5888): Stub
      IOS53 (rev 5663): No Patches
      IOS55 (rev 5663): No Patches
      IOS56 (rev 5662): No Patches
      IOS57 (rev 5919): No Patches
      IOS58 (rev 6176): USB 2.0
      IOS60 (rev 6400): Stub
      IOS61 (rev 5662): No Patches
      IOS62 (rev 6430): No Patches
      IOS70 (rev 6912): Stub
      IOS80 (rev 6944): No Patches
      IOS222 (rev 65280): Stub
      IOS223 (rev 65280): Stub
      IOS249 (rev 65280): Stub
      IOS250 (rev 65280): Stub
      IOS254 (rev 65281): BootMii
      BC v6
      MIOS v10
      Report generated on 2013/05/27.
      sysCheck #FKesMEr7
      • Keithuk
        • 2264
        Thats a typical Wii thats been softmodded as you have 16 IOS's that are stub which you need to bring down to 4 or 5.
        Now you have the sysCheck.csv file on the root of the SD card from the sysCheck is download ModMii6. 2.6 and run it from Windows. On the main menu type in SU and type in the location of the sysCheck.csv. Its easier to put this on the root of a drive as it saves typo's.
        That will download all wads and apps that are missing into a COPY_TO_SD sub folder. Add all files and folders to your SD card and run Homebrew with the SD card inserted.
        First of run IOS236 Installer from Homebrew and install IOS36 as IOS236. Come back out and run Multi-Mod-Manager and select WAD Manager this will default to the wad folder install all wads in there. Watch for the Installed OK message after each one. If any don't install just try them again.
        Now ModMii only installs 2 d2x v8.0 wads so you may as well install all the others. d2x v8.0 final pack
        You need to install PriiLoader 0.7 to block any online or disc updates.
        If you want to remove the IOS16 stub just add cIOS16-v257 wad to the wad folder and install it with MMM, this won't improve anything only remove the stub.
        You can post a new sysCheck afterwards.
        Keith
        2010 Golf GTD (170)
        • koopa
          • May 2013
          Everything appears to be up and running perfectly! Thank you for all your help!!
          My new system check:
          Region: NTSC-U
          Priiloader installed
          Hollywood v0x11
          Boot2 v4
          Found 126 titles.
          Found 49 IOS on this console. 4 of them are stub.
          IOS11 (rev 16174): Trucha Bug, NAND Access
          IOS20 (rev 16174): Trucha Bug, NAND Access
          IOS30 (rev 16174): Trucha Bug, NAND Access
          IOS40 (rev 16174): Trucha Bug, NAND Access
          IOS50 (rev 16174): Trucha Bug, NAND Access
          IOS52 (rev 16174): Trucha Bug, NAND Access
          IOS60 (rev 16174): Trucha Bug, NAND Access
          IOS70 (rev 16174): Trucha Bug, NAND Access
          IOS80 (rev 16174): Trucha Bug, NAND Access
          IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
          IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
          IOS223[38+37] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
          IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
          IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
          IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
          IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
          BC v6
          MIOS v10
          Report generated on 2013/05/28.
          • Keithuk
            • 2264
            You didn't do everything I said did you?
            Install all 7 wads not the 2 you've installed.
            Keith
            2010 Golf GTD (170)
