Help! 4.3U Wii Disaster :(
  • wiigangstaz
    • May 2013
    Hi,
    I recently followed a few youtube videos on how to get USB Loader GX to work with my flash drive (Install USB Hard Drive for Wii (USB Loader GX) - YouTube) but my Wii is acting up. I think some of these IOS's are old or maybe this tutorial is outdated. Whenever I try to use the Loader it goes black. I read a couple of threads on here but I'm just super newb with this and nothing is working. (Possible because I don't know how to install everything correctly) Any help would be greatly appreciated!
    Thanks,
    Trying to Learn
    sysCheck v2.1.0b19 by Double_A and R2-D2199, Nano
    ...runs on IOS58 (rev 6175).
    Region: NTSC-U
    System Menu 4.3U (v513)
    Drive date: 2007.02.13
    Homebrew Channel 1.1.0 running on IOS58
    HomebrewFilter ist nicht installiert
    Hollywood v0x11
    Console ID: 58429819
    Boot2 v4
    Found 79 titles.
    Found 46 IOS on this console. 14 of them are stub.
    IOS4 (rev 65280): Stub
    IOS9 (rev 1034): No Patches
    IOS10 (rev 768): Stub
    IOS11 (rev 256): Stub
    IOS12 (rev 525): No Patches
    IOS13 (rev 1031): No Patches
    IOS14 (rev 1031): No Patches
    IOS15 (rev 1031): No Patches
    IOS16 (rev 512): Stub
    IOS17 (rev 1031): No Patches
    IOS20 (rev 256): Stub
    IOS21 (rev 1038): No Patches
    IOS22 (rev 1293): No Patches
    IOS28 (rev 1806): No Patches
    IOS30 (rev 2816): Stub
    IOS31 (rev 3607): No Patches
    IOS33 (rev 3607): No Patches
    IOS34 (rev 3607): No Patches
    IOS35 (rev 3607): No Patches
    IOS36 (rev 3607): No Patches
    IOS37 (rev 5662): No Patches
    IOS38 (rev 4123): No Patches
    IOS40 (rev 3072): Stub
    IOS41 (rev 3606): No Patches
    IOS43 (rev 3606): No Patches
    IOS45 (rev 3606): No Patches
    IOS46 (rev 3606): No Patches
    IOS48 (rev 4123): No Patches
    IOS50 (rev 5120): Stub
    IOS51 (rev 4864): Stub
    IOS52 (rev 5888): Stub
    IOS53 (rev 5662): No Patches
    IOS55 (rev 5662): No Patches
    IOS56 (rev 5661): No Patches
    IOS57 (rev 5918): No Patches
    IOS58 (rev 6175): USB 2.0
    IOS60 (rev 6400): Stub
    IOS61 (rev 5661): No Patches
    IOS70 (rev 6912): Stub
    IOS80 (rev 6943): No Patches
    IOS222 (rev 65280): Stub
    IOS223 (rev 65280): Stub
    IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
    IOS249[56] (rev 20, Info: rev 20): Trucha Bug, NAND Access, USB 2.0
    IOS250[38] (rev 20, Info: rev 20): Trucha Bug, ES Identify, NAND Access
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v10
    Report generated on 2013/05/31.
    sysCheck #kUipn8Ef
  • wiigangstaz
    • May 2013
    Disaster no more! Thanks @KeithUK, I know you never responded to this and I'm new but I read your other posts and figured out all on my own!!
    Just a heads up for people who may have ran into problems I had; I later figured out that the best method to solving your problems is to use ModMii. Part of the reason I was having so many problems loading backups and system file structure was because I was on a Mac. If you're looking to go the Mac route definitely install Parallels and a copy of Windows so you can access ModMii and Wii Backup Manager.
    Thanks again Digital-Kaos!
    • Keithuk
      • 2264
      Welcome to DK.
      You posted twice today at 01:10 AM and 08:25 AM but I wan't here.
      If you've found a solution with ModMii then I'm assuming you've read my other posts on the subject.
      Your easiest thing to do now you have the sysCheck.csv file on the root of the SD card from the sysCheck is download ModMii6. 2.6 and run it from Windows. On the main menu type in SU and type in the location of the sysCheck.csv. Its easier to put this on the root of a drive as it saves typo's.
      That will download all wads and apps that are missing into a COPY_TO_SD sub folder. Add all files and folders to your SD card and run Homebrew with the SD card inserted.
      First of run IOS236 Installer from Homebrew and install IOS36 as IOS236. Come back out and run Multi-Mod-Manager and select WAD Manager this will default to the wad folder install all wads in there. Watch for the Installed OK message after each one. If any don't install just try them again.
      Now ModMii only installs 2 d2x v8.0 wads so you may as well install all the others. d2x v8.0 final pack
      You will need to install PriiLoader 0.7 to block online and disc updates.
      Then post a new sysCheck.
      Keith
      2010 Golf GTD (170)
      • wiigangstaz
        • May 2013
        Hey Keith, thanks for the link to the final packs. Just installed the new cIOS's. How does my system look? Seems to be running pretty solid over here. Hope it's fully updated!
        ...runs on IOS58 (rev 6176).
        Region: NTSC-U
        Priiloader installed
        Hollywood v0x11
        Boot2 v4
        Found 94 titles.
        Found 54 IOS on this console. 4 of them are stub.
        IOS11 (rev 16174): Trucha Bug, NAND Access
        IOS12 (rev 526): No Patches
        IOS13 (rev 1032): No Patches
        IOS14 (rev 1032): No Patches
        IOS15 (rev 1032): No Patches
        IOS17 (rev 1032): No Patches
        IOS20 (rev 16174): Trucha Bug, NAND Access
        IOS21 (rev 1039): No Patches
        IOS22 (rev 1294): No Patches
        IOS28 (rev 1807): No Patches
        IOS30 (rev 16174): Trucha Bug, NAND Access
        IOS31 (rev 3608): No Patches
        IOS33 (rev 3608): No Patches
        IOS34 (rev 3608): No Patches
        IOS35 (rev 3608): No Patches
        IOS36 (rev 3608): No Patches
        IOS37 (rev 5663): No Patches
        IOS38 (rev 4124): No Patches
        IOS40 (rev 16174): Trucha Bug, NAND Access
        IOS41 (rev 3607): No Patches
        IOS43 (rev 3607): No Patches
        IOS45 (rev 3607): No Patches
        IOS46 (rev 3607): No Patches
        IOS48 (rev 4124): No Patches
        IOS50 (rev 16174): Trucha Bug, NAND Access
        IOS52 (rev 16174): Trucha Bug, NAND Access
        IOS53 (rev 5663): No Patches
        IOS55 (rev 5663): No Patches
        IOS56 (rev 5662): No Patches
        IOS57 (rev 5919): No Patches
        IOS58 (rev 6176): USB 2.0
        IOS60 (rev 16174): Trucha Bug, NAND Access
        IOS61 (rev 5662): No Patches
        IOS62 (rev 6430): No Patches
        IOS70 (rev 16174): Trucha Bug, NAND Access
        IOS80 (rev 16174): Trucha Bug, NAND Access
        IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
        IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
        IOS223[38+37] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
        IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
        IOS236 (rev 65535): Trucha Bug, ES Identify, NAND Access
        IOS245[37] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
        IOS246[38] (rev 21008, Info: d2x-v8final): Trucha Bug, ES Identify, NAND Access
        IOS247[53] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
        IOS248[55] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
        IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
        IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
        IOS251[58] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
        BC v6
        MIOS v10
        Report generated on 2013/06/02.
        • Keithuk
          • 2264
          Yes that sysCheck look ok.
          If you want to remove that IOS16 stub just install my cIOS16-v257 wad, it won't improve anything only remove that stub.
          So your now up and running with your USB Loaders?
          You can click the Thanks button under the posts that I've helped you with?
          Happy gaming.
          Keith
          2010 Golf GTD (170)
