how can i play wii games on dvd after i install HBC?
  • mjlregalado
    • Jun 2013
    • 5
    help me pls
  • Keithuk
    • Aug 2010
    • 2264
    Post a sysCheck19 report as in instructed in that link so I can see what your system is and which IOS's you've installed.
    Playing burnt games of a DVD isn't really worth it as you have to use quality DVD's and store them all somewhere. Get yourself a compatible mains powered USB hard drive and add all your original games on to it so they don't get damaged.
    Keith
    2010 Golf GTD (170)
    • mjlregalado
      • Jun 2013
      • 5
      sysCheck v2.1.0b19 by Double_A and R2-D2199 Nano
      ...runs on IOS58 (rev 6176).
      Region: PAL
      System Menu 4.3E (v514)
      Priiloader installed
      Drive date: 2007.02.13
      Homebrew Channel 1.1.0 running on IOS58
      HomebrewFilter ist nicht installiert
      Hollywood v0x11
      Console ID: 117753910
      Boot2 v4
      Found 69 titles.
      Found 46 IOS on this console. 15 of them are stub.
      IOS4 (rev 65280): Stub
      IOS9 (rev 1034): No Patches
      IOS10 (rev 768): Stub
      IOS11 (rev 256): Stub
      IOS12 (rev 526): No Patches
      IOS13 (rev 1032): No Patches
      IOS14 (rev 1032): No Patches
      IOS15 (rev 1032): No Patches
      IOS16 (rev 512): Stub
      IOS17 (rev 1032): No Patches
      IOS20 (rev 256): Stub
      IOS21 (rev 1039): No Patches
      IOS22 (rev 1294): No Patches
      IOS28 (rev 1807): No Patches
      IOS30 (rev 2816): Stub
      IOS31 (rev 3608): No Patches
      IOS33 (rev 3608): No Patches
      IOS34 (rev 3608): No Patches
      IOS35 (rev 3608): No Patches
      IOS36 (rev 3608): No Patches
      IOS37 (rev 5663): No Patches
      IOS38 (rev 4124): No Patches
      IOS40 (rev 3072): Stub
      IOS41 (rev 3607): No Patches
      IOS43 (rev 3607): No Patches
      IOS45 (rev 3607): No Patches
      IOS46 (rev 3607): No Patches
      IOS48 (rev 4124): No Patches
      IOS50 (rev 5120): Stub
      IOS51 (rev 4864): Stub
      IOS52 (rev 5888): Stub
      IOS53 (rev 5663): No Patches
      IOS55 (rev 5663): No Patches
      IOS56 (rev 5662): No Patches
      IOS57 (rev 5919): No Patches
      IOS58 (rev 6176): USB 2.0
      IOS60 (rev 6400): Stub
      IOS61 (rev 5662): No Patches
      IOS62 (rev 6430): No Patches
      IOS70 (rev 6912): Stub
      IOS80 (rev 6944): No Patches
      IOS222 (rev 65280): Stub
      IOS223 (rev 65280): Stub
      IOS249[56] (rev 21006 Info: d2x-v6): Trucha Bug NAND Access USB 2.0
      IOS250 (rev 65280): Stub
      IOS254 (rev 65281): BootMii
      BC v6
      MIOS v10
      • mjlregalado
        • Jun 2013
        • 5
        thats my syscheck. what should i do now?
        • Keithuk
          • Aug 2010
          • 2264
          I've posted what to do many times on here so I may as well quote it again.
          Originally posted by Keithuk
          Thats a typical Wii thats been softmodded as you have 15 IOS's that are stub which you need to bring down to 4 or 5.
          Now you have the sysCheck.csv file on the root of the SD card from the sysCheck is download ModMii6. 2.6 and run it from Windows. On the main menu type in SU and type in the location of the sysCheck.csv. Its easier to put this on the root of a drive as it saves typo's.
          That will download all wads and apps that are missing into a COPY_TO_SD sub folder. Add all files and folders to your SD card and run Homebrew with the SD card inserted.
          First of run IOS236 Installer from Homebrew and install IOS36 as IOS236. Come back out and run Multi-Mod-Manager and select WAD Manager this will default to the wad folder install all wads in there. Watch for the Installed OK message after each one. If any don't install just try them again.
          Now ModMii only installs 2 d2x v8.0 wads so you may as well install all the others. d2x v8.0 final pack
          You need to install PriiLoader 0.7 to block any online or disc updates.
          If you want to remove the IOS16 stub just add cIOS16-v257 wad to the wad folder and install it with MMM, this won't improve anything only remove the stub.
          You can post a new sysCheck afterwards.
          If you really want to play burnt discs then you'll need Neogamma R9beta56 with forwarder and mmm - Downloads - Digital Kaos. You will still need to do what I've said before NeoGamma will work. You will need to burn the games with http://www.filehippo.com/download_imgburn/ ImgBurn at a slow speed onto quality DVD's. But burnt discs don't read as fast as an hard drive.
          You can Google for USB Loader GX or use this one. USBLoader GX 3.0 All in one package ios 249 - Downloads - Digital Kaos
          Keith
          2010 Golf GTD (170)
          • mjlregalado
            • Jun 2013
            • 5
            where caN I get the MMM? and what does it do?
            • mjlregalado
              • Jun 2013
              • 5
              and how i can bring down my ios to 5?
              • Keithuk
                • Aug 2010
                • 2264
                Well if you look what I've said you can get it from this download
                or if you used ModMii that will add apps\MMM folder.
                Keith
                2010 Golf GTD (170)
                • cclo
                  • Jun 2013
                  Didnt need to ask what to do you solved it already. Dropping you a thanks instead.
