all USB loader not working? loads then flashes to wii menu. syscheck included
  • redtomato
    • Jun 2013
    Hi!
    Apologies for being a total noob but I've no idea what's wrong.
    My brother modded my wii to play from a HDD but he did it 6 months ago and I haven't attempted to play anything from a HDD until now. I've formatted my HDD (Seagate, 150gb) to WBFS using WBFS manager and each time I load USB Loader GX, it shows the loading screen then flashes back to the wii menu? No error message, nothing. When I load USB Loader GX without a HDD plugged in, it freezes in the load screen until I have to reset the Wii.
    For some reason, my brother also has USB configurable, neogamma and wiiflow installed. tried all, same thing happens. loads then flashes to wii menu.
    Tried switching ports as well- no luck. I tried hunting the net for solutions but it's a bit difficult since I wasn't involved in modding my wii so I'm not quite sure how my brother did it (which ios he has installed, etc). I ran a syscheck which is below.
    Any help is greatly appreciated!
    sysCheck v2.1.0b19 by Double_A and R2-D2199, Nano
    ...runs on IOS58 (rev 6176).
    Region: PAL
    System Menu 4.3E (v514)
    Priiloader installed
    Drive date: 2008.12.18
    Homebrew Channel 1.1.0 running on IOS58
    HomebrewFilter ist nicht installiert
    Hollywood v0x21
    Console ID: 139988099
    Boot2 v4
    Found 91 titles.
    Found 55 IOS on this console. 6 of them are stub.
    IOS3 (rev 65280): Stub
    IOS4 (rev 65280): Stub
    IOS9 (rev 54321): Trucha Bug
    IOS10 (rev 768): Stub
    IOS11 (rev 54321): Trucha Bug
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS16 (rev 54321): Trucha Bug, ES Identify, Flash Access, NAND Access
    IOS17 (rev 1032): No Patches
    IOS20 (rev 54321): Trucha Bug
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 54321): Trucha Bug
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 54321): Trucha Bug, ES Identify, NAND Access
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS40 (rev 3072): Stub
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 54321): Trucha Bug
    IOS51 (rev 4864): Stub
    IOS52 (rev 5888): Stub
    IOS53 (rev 5663): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 54321): Trucha Bug
    IOS61 (rev 5662): No Patches
    IOS70 (rev 54321): Trucha Bug
    IOS80 (rev 54321): Trucha Bug
    IOS90 (rev 54321): Trucha Bug
    IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
    IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS223[38+37] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
    IOS236 (rev 54321): Trucha Bug, ES Identify, NAND Access
    IOS245[37] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    IOS246[38] (rev 21007, Info: d2x-v7final): Trucha Bug, ES Identify, NAND Access
    IOS247[53] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    IOS248[55] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    IOS249[56] (rev 21006, Info: d2x-v6): Trucha Bug, NAND Access, USB 2.0
    IOS250[57] (rev 21006, Info: d2x-v6): Trucha Bug, NAND Access, USB 2.0
    IOS251[58] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v65535
  • Keithuk
    • 2264
    Welcome to DK.
    Are you running USB Loader GX from a forwarder channel or from Homebrew? If you run it from a forwarder and it jumps back to the Wii menu that normally means it can't read the files on the SD card or a bad forwarder, try running it from Homebrew. Which version of USB Loader GX are you using, when you start it from Homebrew note the version number?
    What you need are some newer wads installing.
    Now you have the sysCheck.csv file on the root of the SD card from the sysCheck is download ModMii6. 2.6 and run it from Windows. On the main menu type in SU and type in the location of the sysCheck.csv. Its easier to put this on the root of a drive as it saves typo's.
    That will download all wads and apps that are missing into a COPY_TO_SD sub folder. Add all files and folders to your SD card and run Homebrew with the SD card inserted.
    You need a new IOS236 so first of run IOS236 Installer from Homebrew and install IOS36 as IOS236. Come back out and run Multi-Mod-Manager and select WAD Manager this will default to the wad folder install all wads in there. Watch for the Installed OK message after each one. If any don't install just try them again.
    Now ModMii only installs 2 d2x v8.0 wads so you may as well install all the others. d2x v8.0 final pack
    You can post a new sysCheck afterwards.
    Keith
    2010 Golf GTD (170)
