Hello All,
Note : This is a long post. I've posted the last sysCheck.csv at the end of this post.
I upgraded my virgin 4.1E wii to 4.3E wii and have installed USB Loader GX v2.3. Everything was working fine initially. However instead of leaving my wii alone, I downloaded ModMii, created a sysCheck file and launched ModMii with SU option. It proceeded to download some wads which I installed with mmm (using IOS236). Now for some reason, when playing games from my USB Flash drive the games suddenly hangs or freezes.
Examples are: New Super Mario Bros Wii from USB Flash drive (wbfs partition, wbfs file) hangs after the title introduction screen. The screen goes black and I'm forced to a reset. The same happens when I play Newer Super Mario Bros Wii (I built the ISO myself and can confirm before applying the Modmii - wads mmm patch, all levels were working and I never encountered wii freezing or black screen). Just to be sure it was'nt a defective flash drive, I installed the games into a new flash drive (FAT32, wbfs folder with the wbfs files copied) and I still experience the same errors. I also have OCARINA codes enabled in USB Loader GX v2.3 for the games mentioned.
Thinking it could be a USBLoader GX issue, I tried WiiFlow with the same result (games freezing or black screen). Thinking it might be IOS249 causing the issue, I configured USBLoader GX and wiiflow to use IOS222 with the same result.
Finally, after lots of frustration, I thought an official forced System Menu 4.3 update would clear out Homebrew and patch all official IOSs. Unfortunately it removed only Homebrew, CIOS, IOS222, IOS223, IOS249 and IOS250. I discovered after reinstalling Homebrew (via LetterBomb), Bootmii as IOS and then Prilloader 0.7 that it did NOT fix the original issue and the games continue to experience a black screen or freeze. The game still loads from flash drive and I can play for a while but it hangs randomly.
Frustrated now, I launched ModMii, started in W (wizard mode), answered I have a already softmodded wii and would like to reapply all softmods, downloaded and installed all the wads via mmm (mmmconfig using IOS236). I still experience the game freeze or black screen (esp after intro in NSMBW).
Can the experts tell me:
1. If my sysCheck looks okay? What I'm missing.
2. That the only way to restore a NAND backup when bootmii is installed as IOS, is by entering the Konami code with a GC Controller (after running KeyFix on the NAND Backup to fix the console id key). I ask this because I took a full NAND backup when I first installed homebrew but have no way of restoring this since I don't have a gamecube controller.
3. Using ModMii to downgrade my System Menu from 4.3E to 4.2E is safe? I want to do this to force an official 4.3 system menu upgrade to reinstall all official IOSs, so that I can start the softmod making the bare minimum changes (as I originally did first and got it right the first time).
4. If there is an easier way of restoring all the IOSs to virgin state (as close as possible, since I believe the wii can never be fully virginized).
5. When playing from USBLoader, can the crash/freeze be caused due to OCARINA being enabled? I believe not since it froze when I used WiiFlow (with no cheats enabled).
6. Is USB Loader GX v3 as stable as USB Loader GX v2.3 and will using that fix this issue?
All I care about now is to get my games to continue working again from USB Flash Drive (without crashes or freezes, with OCARINA codes enabled). Thanks in advance and apologies for the long post, I wanted to give as much info as possible. SysCheck report follows.
EDIT1: Reading some more posts in this forum and comparing the sysCheck report made by Keithuk on Jan 8 2013 from his wii, I can see that I'm missing IOS245 to IOS248 and IOS251. I also see that my IOS16 is a stub whilst his wii has the Trucha bug installed. I'll download d2x v8 Final wad pack from this forum and see whats going. Can anyone tell me what IOS16 does and if a patches IOS16 is necessary. Thanks.
EDIT2: Based on the post from Keithuk, I've installed d2x v8 final wad pack, IOS16 patch. I've posted the updated sysCheck.csv below. I'll play and test this for a while and revert. Meanwhile if any experts can answer the above questions, it'll be much appreciated as I'm unable to find conclusive answers to the above questions.
sysCheck v2.1.0b19 by Double_A and R2-D2199, Nano
...runs on IOS58 (rev 6176).
Region: PAL (original region: AUS)
System Menu 4.3E (v514)
Priiloader installed
Drive date: 2008.07.14
Homebrew Channel 1.1.2 running on IOS58
HomebrewFilter ist nicht installiert
Hollywood v0x21
Console ID: 951XXXXX
Boot2 v4
Found 77 titles.
Found 55 IOS on this console. 4 of them are stub.
IOS3 (rev 65280): Stub
IOS4 (rev 65280): Stub
IOS9 (rev 1034): No Patches
IOS10 (rev 768): Stub
IOS11 (rev 16174): Trucha Bug, NAND Access
IOS12 (rev 526): No Patches
IOS13 (rev 1032): No Patches
IOS14 (rev 1032): No Patches
IOS15 (rev 1032): No Patches
IOS16 (rev 54321): Trucha Bug, ES Identify, Flash Access, NAND Access
IOS17 (rev 1032): No Patches
IOS20 (rev 16174): Trucha Bug, NAND Access
IOS21 (rev 1039): No Patches
IOS22 (rev 1294): No Patches
IOS28 (rev 1807): No Patches
IOS30 (rev 16174): Trucha Bug, NAND Access
IOS31 (rev 3608): No Patches
IOS33 (rev 3608): No Patches
IOS34 (rev 3608): No Patches
IOS35 (rev 3608): No Patches
IOS36 (rev 3608): No Patches
IOS37 (rev 5663): No Patches
IOS38 (rev 4124): No Patches
IOS40 (rev 16174): Trucha Bug, NAND Access
IOS41 (rev 3607): No Patches
IOS43 (rev 3607): No Patches
IOS45 (rev 3607): No Patches
IOS46 (rev 3607): No Patches
IOS48 (rev 4124): No Patches
IOS50 (rev 16174): Trucha Bug, NAND Access
IOS51 (rev 4864): Stub
IOS52 (rev 16174): Trucha Bug, NAND Access
IOS53 (rev 5663): No Patches
IOS55 (rev 5663): No Patches
IOS56 (rev 5662): No Patches
IOS57 (rev 5919): No Patches
IOS58 (rev 6176): USB 2.0
IOS60 (rev 16174): Trucha Bug, NAND Access
IOS61 (rev 5662): No Patches
IOS62 (rev 6430): No Patches
IOS70 (rev 16174): Trucha Bug, NAND Access
IOS80 (rev 16174): Trucha Bug, NAND Access
IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS223[38+37] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
IOS245[37] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS246[38] (rev 21008, Info: d2x-v8final): Trucha Bug, ES Identify, NAND Access
IOS247[53] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS248[55] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS251[58] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS254 (rev 65281): BootMii
BC v6
MIOS v10
Report generated on 2013/07/11.
Hollywood v0x21
Boot2 v4
Found 77 titles.
BC v6
MIOS v10
Anyway, can you take a stab at those questions Ive asked...Thanks again.
