USB Loader/CFW Firmware help.
  • docdock
    • Jul 2013
    First of all, forgive me as this is a repost but i didn't have access to posting in the wii forums at the time. Anyway, got an issue with usb loader. Basically USB loader won't recognise my usb hard drive. And also as a result of that i can't rip any wii games to the hdd. I've done a fairly recent sys check, as advised in other threads. The results of which are below....
    sysCheck GX v1.0.0 by Erik Spyder
    sysCheck GX is running under IOS58 (rev 6176).
    Console ID: 115599557.
    Region: PAL.
    Hollywood v0x11.
    Boot2 v4.
    System Menu v514 (4.3E).
    BC v6.
    MIOS v65535.
    Found 86 titles.
    Found 50 IOS and 5 IOS Stubs on this console.
    Priiloader is installed.
    IOS 4 (rev 65280): Stub
    IOS 9 (rev 54321): Trucha Bug, ES_Identify, NAND Access
    IOS 10 (rev 768): Stub
    IOS 11 (rev 54321): Trucha Bug, ES_Identify, NAND Access
    IOS 12 (rev 526)
    IOS 13 (rev 1032)
    IOS 14 (rev 1032)
    IOS 15 (rev 1032)
    IOS 16 (rev 54321): Trucha Bug, ES_Identify, FLASH Access, NAND Access
    IOS 17 (rev 1032)
    IOS 20 (rev 54321): Trucha Bug, ES_Identify, NAND Access
    IOS 21 (rev 1039)
    IOS 22 (rev 1294)
    IOS 28 (rev 1807)
    IOS 30 (rev 54321): Trucha Bug, ES_Identify, NAND Access
    IOS 31 (rev 3608)
    IOS 33 (rev 3608)
    IOS 34 (rev 3608)
    IOS 35 (rev 3608)
    IOS 36 (rev 54321): Trucha Bug, ES_Identify, NAND Access
    IOS 37 (rev 5663)
    IOS 38 (rev 4124)
    IOS 40 (rev 3072): Stub
    IOS 41 (rev 3607)
    IOS 43 (rev 3607)
    IOS 45 (rev 3607)
    IOS 46 (rev 3607)
    IOS 48 (rev 4124)
    IOS 50 (rev 54321): Trucha Bug, ES_Identify, NAND Access
    IOS 51 (rev 4864): Stub
    IOS 52 (rev 5888): Stub
    IOS 53 (rev 5663)
    IOS 55 (rev 5663)
    IOS 56 (rev 5662)
    IOS 57 (rev 5919)
    IOS 58 (rev 6176): USB 2.0
    IOS 60 (rev 54321): Trucha Bug, ES_Identify, NAND Access
    IOS 61 (rev 5662)
    IOS 62 (rev 6430)
    IOS 70 (rev 54321): Trucha Bug, ES_Identify, NAND Access
    IOS 80 (rev 54321): Trucha Bug, ES_Identify, NAND Access
    IOS 90 (rev 54321): Trucha Bug, ES_Identify, NAND Access
    IOS202 (rev 65535): Trucha Bug, ES_Identify, NAND Access, USB 2.0
    IOS222 (rev 4): Trucha Bug, ES_Identify, NAND Access, USB 2.0
    IOS223 (rev 4): Trucha Bug, ES_Identify, NAND Access, USB 2.0
    IOS224 (rev 65535): Trucha Bug, ES_Identify, NAND Access, USB 2.0
    IOS236 (rev 54321): Trucha Bug, ES_Identify, NAND Access
    IOS245 (rev 21008): Trucha Bug, ES_Identify, NAND Access
    IOS246 (rev 21008): Trucha Bug, ES_Identify, NAND Access
    IOS247 (rev 21008): Trucha Bug, ES_Identify, NAND Access
    IOS248 (rev 21008): Trucha Bug, ES_Identify, NAND Access
    IOS249 (rev 21008): Trucha Bug, ES_Identify, NAND Access
    IOS250 (rev 21008): Trucha Bug, ES_Identify, NAND Access
    IOS251 (rev 21008): Trucha Bug, ES_Identify, NAND Access
    IOS254 (rev 65281)
    Report generated on 2013-07-20.
    Anybody got any ideas as to why it doesn't work? Please bear in mind i'm a complete novice when it comes to using wii homebrew.
    Thanks for any responses i get.
  • Keithuk
    • 2264
    Welcome to DK.
    Thats a sysCheck GX report which isn't as good as sysCheck19 because it shows Stubs but other lines are blank not even No Patches. Run my sysCheck and save the sysCheck.csv file.
    There are a few IOS's that need updating IOS40, IOS52. The easiest way is download ModMii6.2.7 and run it from Windows. On the main menu type in SU and type in the location of the sysCheck.csv from the sysCheck. Its easier to put this on the root of a drive as it saves typo's.
    That will download all wads and apps that are missing into a COPY_TO_SD sub folder. Add all files and folders to your SD card and run Homebrew with the SD card inserted.
    First of run IOS236 Installer v5 Mod and install IOS36 as IOS236, you must do this before you install any other wads. Come back out and run Multi-Mod-Manager and select WAD Manager this will default to the wad folder install all wads in there, read the instructions at the bottom for which buttons to press. Install the other wads that ModMii gave you, watch for the Installed OK message after each one. If any don't install just try them again.
    As I've said that sysCheck GX is a shitty report as it only says (21008) which sounds like d2x v8.0. You may as well download d2x v8 Final wad pack just in case you need to install all 7 wads.
    You will find that the Shopping Channel won't work anymore it will say you need to do a system update but don't bother just download and add RVL-Shopping-21.wad to the wad folder and install it with MMM. RVL-Shopping-21
    Then post a new sysCheck.
    Keith
    2010 Golf GTD (170)
    • docdock
      • Jul 2013
      Hi there,
      Thanks ever so much for getting back to me. My apologies for the really late reply, i'm going to have a look at all of the above and crack on with it. Obviously any problems i'll reply in this thread.
      Once again, thanks for the response.
      I should also add i predominantly use a mac but i can get access to a windows based laptop if needs must.
