hi im todd and i want to mod my wii
  • tscott123
    • Aug 2013
    high my name is todd and im looking to modify my nintendo wii
  • Keithuk
    • 2264
    Welcome to DK Todd.
    The first this you need to do is make sure your running a 4.3. Click on Wii Options bottom left the click on the Spanner picture Wii Settings on the right the Wii version number will be shown top right.
    If its not 4.3 scroll along to page 3 and click on Wii System Update and update the Wii to 4.3, you will need a web connection to do this.
    While you are there click on Internt anf Console Information and write down the MAC Address.
    Go onto LetterBomb and type in your MAC Address and make sure the correct area is selected at the top.
    You need a 2 GB SD card not SDHC formatted to FAT32. Download the Letterbomb.zip and extract all files and folders to the SD card.
    Put it back in the Wii and start it up. Click on Wii Messages bottom right and click back a day or two until you see the red envelope and click on it to start the installation.
    Install all 3 parts:
    1) Install Homebrew.
    2) Install BootMii on IOS.
    3) Prepare SD card - this is need so you can do a NAND backup straight afterwards, don't miss this. Save the [bootmii] folder and files along with keys.bin and nand.bin on the root of the SD card somewhere very safe as you will need these if you have to restore the NAND.
    Download sysCheck19 and add that to the SD card. Run Homebrew and run SysCheck, this will make a sysCheck.csv on the root of the SD card.
    Download ModMii6.2.7 and run it from Windows. Use the SU option from the main menu and find the location of the sysCheck.csv from the sysCheck. That will download all missing wads and apps to COPY_TO_SD sub folder just add all files and folders to the SD card.
    ModMii only installed 2 d2x v8.0 wads download d2x v8 Final wad pack and install all 7 wads when you install the other wads.
    Put the SD card back in the Wii and run Homebrew. Run IOS236 Installer v5 Mod first before you install any other wads. Multi Mod Manager should be the first app listed select it and load it. Once running scroll down to WAD Manager and press 'A' that will default to all wads in the wad folder. If you want to install all wads shown just press 1 that will list all wads you want to install press 'A' again to install them all.
    Watch for the Installed OK message after each one. If any don't say that message make a note of the wad name and back out. Scroll down to the wad that didn't install and press the + button the put a green + next to it then press 'A' to see that wads name listed then press 'A' to install again.
    Download PriiLoader 0.7 add it to the SD card and run it from Homewbrew and set it to block online and disc updates, you can turn off the 'A' safety prompt on startup I do.
    If you have to update to 4.3 then the Shopping Channel may work. If it doesn't without doing another system update don't bother just install my RVL-Shopping-21
    Do another sysCheck to make sure everything installed correctly and post that.
    Then you just have a to find a compatible mains powered USD hard drive to add your games onto and download USB Loader GX 3.0 to run them.
    Keith
    2010 Golf GTD (170)
