Noobie, Usb Loader Gx won't detect my Usb drive. Pleae help
  • Whysohacky
    • Aug 2013
    Hello, guys. Iv'e jut softmodded my Wii 4.3E console, with letterbomb. Iv'e installed the HMC and Usb Loader Gx, but anytime time I insert my drive
    into my wii, it won't detect it. Im using a 8gb Kingston usb and it is compatible. I've followed this Tutorial on youtube.
    Hack your Wii Letterbomb Homebrew USB Loader GX 4.3 - YouTube
    Heres my syscheck.
    sysCheck v2.1.0b19 by Double_A and R2-D2199, Nano
    ...runs on IOS58 (rev 6176).
    Region: PAL
    System Menu 4.3E (v514)
    Drive date: 2008.07.14
    Homebrew Channel 1.1.0 running on IOS58
    HomebrewFilter ist nicht installiert
    Hollywood v0x21
    Console ID: 126385867
    Boot2 v4
    Found 70 titles.
    Found 48 IOS on this console. 15 of them are stub.
    IOS3 (rev 65280): Stub
    IOS4 (rev 65280): Stub
    IOS9 (rev 1034): No Patches
    IOS10 (rev 768): Stub
    IOS11 (rev 256): Stub
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS16 (rev 512): Stub
    IOS17 (rev 1032): No Patches
    IOS20 (rev 256): Stub
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 2816): Stub
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 3608): No Patches
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS40 (rev 3072): Stub
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 5120): Stub
    IOS51 (rev 4864): Stub
    IOS52 (rev 5888): Stub
    IOS53 (rev 5663): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 6400): Stub
    IOS61 (rev 5662): No Patches
    IOS62 (rev 6430): No Patches
    IOS70 (rev 6912): Stub
    IOS80 (rev 6944): No Patches
    IOS222 (rev 65280): Stub
    IOS223 (rev 65280): Stub
    IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
    IOS249[57] (rev 20, Info: rev 20): Trucha Bug, NAND Access, USB 2.0
    IOS250[57] (rev 65535, Info: rev 18): Trucha Bug, NAND Access, USB 2.0
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v10
    Report generated on 2013/08/20.
    Please help, I'm a complete Noob at this. Thanks
  • Keithuk
    • 2264
    Welcome to DK.
    Thats a typical Wii thats only been softmodded with 15 IOS's that are Stub you need to drop that to 4 or 5, I said this many times on here if you look.
    Download ModMii6.2.7 and run it from Windows. Use the SU option from the main menu and find the location of the sysCheck.csv from the sysCheck. That will download all missing wads and apps to COPY_TO_SD sub folder just add all files and folders to the SD card.
    ModMii only installed 2 d2x v8.0 wads download d2x v8 Final wad pack and install all 7 wads when you install the other wads.
    Put the SD card back in the Wii and run Homebrew. Run IOS236 Installer v5 Mod first before you install any other wads. Multi Mod Manager should be the first app listed select it and load it. Once running scroll down to WAD Manager and press 'A' that will default to all wads in the wad folder. If you want to install all wads shown just press the '1' button that will list all wads you want to install press 'A' again to install them all.
    Watch for the Installed OK message after each one. If any don't say that message make a note of the wad name and back out. Scroll down to the wad that didn't install and press the + button the put a green + next to it then press 'A' to see that wads name listed then press 'A' to install again.
    Download PriiLoader 0.7 add it to the SD card and run it from Homewbrew and set it to block online and disc updates, you can turn off the 'A' safety prompt on startup I do.
    You'll find that the Shopping Channel doesn't work without a system update. If it doesn't then don't bother with the system update just install my RVL-Shopping-21
    Do another sysCheck to make sure everything installed correctly and post that.
    If after you have done all this correctly and the USB drive still isn't recongised then either the drive isn't compatible (Not All Drives Are) or its how you added games to the drive.
    Keith
    2010 Golf GTD (170)
    • Whysohacky
      • Aug 2013
      I installed Cfg instead and works perfectly. Thanks for the info
      Originally posted by Keithuk
      Welcome to DK.
