Looking for a compatible USB Hard Drive
  • akbarirfan
    • Sep 2009
    • 93
    Hi Guys,
    I have read through the list of compatible hard drives on the gbatemp website, however I am having trouble buying the same ones (have searched for a variety of 1TB and 500GB options from the link).
    Has anybody bought a recent external hard disk drive for their Wii?
    Ideally I would like a 1TB USB powered drive then automatically powers up as per the Wii power status.
  • Keithuk
    • 2264
    I bought 2 of these drives to be used on a Wii and they work perfectly. Seagate 1TB FreeAgent? GoFlex***8482; Desk External Hard Drive
    There is another compatibility list but you have to join to read it.
    Keith
    2010 Golf GTD (170)
    • akbarirfan
      • Sep 2009
      • 93
      Thanks Keith - will take a look at the other list.
      The Seagate looks good, apart for the need for an external power source.
      • Keithuk
        • 2264
        Well an external mains powered drive is better which you say you've bought as there is no lag time while loading.
        Keith
        2010 Golf GTD (170)
        • akbarirfan
          • Sep 2009
          • 93
          Went for a WD My Passport Portable Hard Drive - 1TB, Black, thanks to the link you sent about Keith.
          Thanks - will report back once I am up and running.
          • Keithuk
            • 2264
            So how long as it been softmodded?
            Do you want to post a sysCheck19 report as intructed in that link so I can see which wads have been installed?
            Keith
            2010 Golf GTD (170)
            • akbarirfan
              • Sep 2009
              • 93
              Hi Keith,
              Yes I used ModMii to softmod, so I have the homebrew channel etc. (Think I did this on the 22/09/13)
              Picked up the hard drive after work, formatted to FAT32 (came as NTFS) copied some files on to there for CFG USB Loader and connected it to the Wii - works like a dream!!
              I have tested both CFG and GX, I prefer the GUI of GX, now just need to install the Channel rather than a forwarder or having to enter HBC in order to load GX.
              I think CFG also runs off the HDD, so would ideally like to get a channel for that too, so that I only have backups on the HDD - is that possible?
              Just to confirm, the HDD I got was a WD My Passport Portable Hard Drive - 1TB, Black Model: WDBBEP0010BBK-EESN (which was a confirmed HDD as per above link).
              Very happy with the result, can backup my games, and pack the discs away
              • akbarirfan
                • Sep 2009
                • 93
                Also do you know if it is possible to copy a game from a friends HDD on to mine? And it work?
                • Keithuk
                  • 2264
                  I haven't tried running the USB files from an HDD as mine is formatted WBFS.
                  You would have to choose the HDD from Homebrew then put all files in the correct folders. I would have thought the normal Forwarder Channel would work its like a Windows short-cut it just tells it where to look for the files, Homebrew will tell it to use then HDD.
                  It depends how your friends drive is formatted, FAT32 or NTFS you would just copy the files over to your drive in the games folder.
                  Keith
                  2010 Golf GTD (170)
                  • akbarirfan
                    • Sep 2009
                    • 93
                    I have placed the USB loader (CFG and GX) in the apps folder on the USB HDD, however HBC does not pick them up, it only seems to look within the SD Card (the file paths are identical apart from the drive letter of course). Is there a way to get HBC to read the HDD?
                    I tried to install the channel for GX using MMM, however the installation failed - not sure why, here is where I got the channel from:
                    USBLoaderGX_v3.0_IOS249.wad - usbloader-gui - USB Loader GX v3.0 WAD Channel (UNLR) (boot IOS 249) - USB Loader GX: GUI for Waninkoko?s USB Loader (based on libwiigui) - Google Project Hosting
                    Any reason why that shouldn't install?
                    Also how can I replace the Disc Channel with the USB Forwarder channel? (In Priiloader I have enabled "move disc channel")
                    • Keithuk
                      • 2264
                      Remove any SD cards and plug in your drive. Start HBC and you will see only bubbles. If you press the 1 button you will see the options, because there is no SD card inserted the Internal SD Slot won't be enabled but the USB Device should be, what happens if you click it?
                      What happens when you try to unstall USBLoaderGX_v3.0_IOS249.wad with MMM does it say Installed OK afterwards?
                      If you install USB Loader GX-UNEO_Forwarder_5_1_AHBPROT.wad does that work?
                      Keith
                      2010 Golf GTD (170)
                      • akbarirfan
                        • Sep 2009
                        • 93
                        Will try that tonight thanks.
                        With regards to the WADs, can't recall the exact text, something like "1 File not installed". This is for both WADs, both downloaded from the link above.
                        Also I already have a forwarder channel, but want an actual channel (just to be clear).
                        • Keithuk
                          • 2264
                          What are you using to install wads?
                          I only find that Multi-Mod-Manager (MMM) v13.4 works for me.
                          If wads don't install the first time just keep on trying them.
                          Keith
                          2010 Golf GTD (170)
                          • akbarirfan
                            • Sep 2009
                            • 93
                            I have been trying to install the WADS with Multi-Mod-Manager (MMM).
                            It installed all the WADs with MMM when softmodding so I am not sure what it going on!
                            Will try it some more, but I have tried multiple time.
                            • akbarirfan
                              • Sep 2009
                              • 93
                              So no success on the installation of the WADs...no biggie on tbh.
                              Is there a way to save the covers of games downloaded via GX to the USB HDD rather than the SD card? I have tried to change the path in settings, however it says "cannot create path". Do I have to manually create the folder via my PC?
