Hi, just wondering is anyone here knows how to fix a problem I am having with Wiiflow 4.1.3. Almost every time I start it, it goes to a screen prompting me to either select the game partition, or install a game. (from disc) Clicking the option to set the partition goes to a screen that says it is set on SD or USB1. It is usually on SD, but not always. If you change it from USB1 to SD, you cannot change it back. If it is on SD, you cannot put it on USB1. (which is where I want it to be) The only way I can find through this is to back out of Wiiflow completely (HOME button 2 times) and then go back in. At that point, sometimes the games come right up, but sometimes I have to set the partition, which now will work the way it is supposed to, but it never holds the change, and I cannot find a SAVE or APPLY button anywhere.This is driving me crazy, I'd really appreciate it if someone could tell me how to fix this, as Wifflow is the best, in my opinion. Thanks in advance!
Wiiflow 4.1.3 Partition Selection Problem........
Tags: None
Welcome to DK.
I know nothing about your system so post a sysCheck19 report as intructed in that link.
Explain how your drive is partitioned and formatted?Keith
2010 Golf GTD (170) -
I used WBFS Manager to format my Western Digital 2TB drive to WBFS. I did not partition it, maybe the program did it for me, but I do not think so. I also had problems with Configurable USB Loader and USBLoader GX freezing up while loading, but someone told me to update to d2x version 10 beta 52, which was no help. Beta 53 seems to have fixed those issues though, but it did not seem to help the Wiiflow problem I am having. Here is my syscheck, thank you for trying to help me sort this thing out.
sysCheck v2.1.0b19 by Double_A and R2-D2199 Nano
...runs on IOS58 (rev 6176).
Region: NTSC-U
System Menu 4.1U (v449)
Drive date: 2007.02.13
Homebrew Channel 1.1.0 running on IOS61
HomebrewFilter ist nicht installiert
Hollywood v0x11
Console ID: 57015467
Boot2 v4
Found 248 titles.
Found 50 IOS on this console. 4 of them are stub.
IOS4 (rev 65280): Stub
IOS9 (rev 1034): Trucha Bug
IOS10 (rev 768): Stub
IOS11 (rev 16174): Trucha Bug NAND Access
IOS12 (rev 526): Trucha Bug
IOS13 (rev 1032): Trucha Bug
IOS14 (rev 1032): Trucha Bug
IOS15 (rev 1032): Trucha Bug
IOS16 (rev 512): Stub
IOS17 (rev 1032): Trucha Bug
IOS20 (rev 16174): Trucha Bug NAND Access
IOS21 (rev 1039): Trucha Bug
IOS22 (rev 1294): Trucha Bug
IOS28 (rev 1807): Trucha Bug
IOS30 (rev 16174): Trucha Bug NAND Access
IOS31 (rev 3608): Trucha Bug
IOS33 (rev 3608): Trucha Bug
IOS34 (rev 3608): Trucha Bug
IOS35 (rev 3608): Trucha Bug
IOS36 (rev 3608): Trucha Bug ES Identify NAND Access
IOS37 (rev 5663): Trucha Bug
IOS38 (rev 4124): Trucha Bug
IOS40 (rev 16174): Trucha Bug NAND Access
IOS41 (rev 3607): Trucha Bug
IOS43 (rev 3607): Trucha Bug
IOS45 (rev 3607): Trucha Bug
IOS46 (rev 3607): Trucha Bug
IOS48 (rev 4124): Trucha Bug
IOS50 (rev 14889): Trucha Bug NAND Access
IOS51 (rev 4864): Stub
IOS52 (rev 15661): Trucha Bug NAND Access
IOS53 (rev 5663): Trucha Bug
IOS55 (rev 5663): Trucha Bug
IOS56 (rev 5662): Trucha Bug
IOS57 (rev 5919): Trucha Bug
IOS58 (rev 6176): USB 2.0
IOS60 (rev 16174): Trucha Bug NAND Access
IOS61 (rev 5662): No Patches
IOS62 (rev 6430): Trucha Bug
IOS70 (rev 16174): Trucha Bug NAND Access
IOS80 (rev 16174): Trucha Bug NAND Access
IOS202[38] (rev 65535 Info: hermes-v5.1): Trucha Bug ES Identify NAND Access USB 2.0
IOS222[38] (rev 65535 Info: Hermes-v55.1): Trucha Bug ES Identify NAND Access USB 2.0
IOS223[37] (rev 65535 Info: Hermes-v55.1): Trucha Bug NAND Access USB 2.0
IOS224[57] (rev 65535 Info: hermesrodries-v6): Trucha Bug NAND Access USB 2.0
IOS236 (rev 65535): Trucha Bug ES Identify NAND Access
IOS249[56] (rev 21010 Info: d2x-v10beta53-alt): Trucha Bug NAND Access USB 2.0
IOS250[57] (rev 21010 Info: d2x-v10beta53-alt): Trucha Bug NAND Access USB 2.0
IOS251[58] (rev 21010 Info: d2x-v10beta52): Trucha Bug NAND Access USB 2.0
IOS254 (rev 65281): BootMii
BC v6
MIOS v65535
Report generated on 2013/10/06.Comment
Well there isn't much wrong with that sysCheck apart from you only have 3 d2x v10 installed instead of the 7 wads in d2x v8 Final wad pack. I've never linked the d2x v10 as to me its still beta.
Is it some games that freeze up or all, can you list them?Keith
2010 Golf GTD (170)Comment
Not freezing, but partition selection
It is not that the games freeze up. It is that when I load wiiflow, it always asks me to set the partition where the games are located. Once I do that,it never remembers the setting I made. If I install the d2x v.8 final wad pack, do you think that will fix it? The issues with cry and USB loader gx freezing while loading have been resolved at this point.Well there isn't much wrong with that sysCheck apart from you only have 3 d2x v10 installed instead of the 7 wads in d2x v8 Final wad pack. I've never linked the d2x v10 as to me its still beta.
Is it some games that freeze up or all, can you list them?Comment
Have you checked the ini files to see if your settings have been saved with the current date/time if you say it doesn't save them?
I don't really use CFG USB Loader or WiiFlow only if someone has a problem running a specific game. I checked on the version and its 2.2 I downloaded the newer 4.2 and add that to the SD card. When I ran it, it asked for a source and I selected USB1 and all my games showed. I ran a game I usually play and when I exited it normally goes back to WiiFlow but it brought up a DSL error and I had to switch it over and back on.
On 2.2 I have an MP3 that plays perfectly but on 4.2 it stutters as I flick through the games just the same as playing music on USB Loader GX. I didn't like 4.2 so I put 2.2 back and it plays and exits as it should. On 2.2 if you click on the About button bottom left there is a button you can click on update, on 4.2 it isn't there whether it checks if I'm running the latest version on startup I'm not sure.
On WiiFlow 2.2 isn't listed anymore so if you want mine let me know.Keith
I find the .ini file to be confusing, at best. Could you take a look at it, and let me know what you think. The directory I want it to have is USB1, but I do not see that in here. Two potential spots I see are the second line in the DML section, and the second line above the HOMEBREW section. In the meantime, I am going to install that v.8 final wad pack, and see what happens. I have copy/pasted my .ini here......, and thank you very much for all your time and assisstance, it is surely appreciated!
[DEBUG]
sd_write_log=no
wifi_gecko=no
[DML]
always_show_button=no
dir_usb_games=games
dm_r2.1+=yes
dml_r52+=yes
source=no
[EMULATOR]
disable=no
dump_list=no
last_cf_mode=1
partition=0
smallbox=yes
sort=0
source=no
subfolder_cache=yes
[FANART]
enable_fanart=yes
[GAMERCARD]
dutag_key=
dutag_url=http://tag.darkumbra.net/{KEY}.update={ID6}
gamercards=wiinnertag|dutag
gamercards_enable=no
wiinnertag_key=
wiinnertag_url=http://www.wiinnertag.com/wiinnertag_scripts/update_sign.php?key={KEY}&game_id={ID6}
[GAMES]
cheat=no
current_item=STFP52
dump_list=no
last_cf_mode=1
partition=1
save_emulation=0
savepartition=-1
savepath=
show_full_banner=no
sort=0
source=yes
[GENERAL]
age_lock=0
allow_texture_compression=yes
async_network=no
b_lr_mode=no
banner_in_settings=yes
box_mode=yes
category_on_start=no
compress_cache=no
country_patch=no
cover_buffer=20
cover_prio=0
cover_use_hq=no
data_on_usb=no
dir_banner_cache=sd:/wiiflow/cache/banners
dir_box_covers=sd:/wiiflow/boxcovers
dir_cache=sd:/wiiflow/cache
dir_cheat=sd:/wiiflow/codes/gct
dir_custom_banners=sd:/wiiflow/custom_banners
dir_fanart=sd:/wiiflow/fanart
dir_flat_covers=sd:/wiiflow/covers
dir_help=sd:/wiiflow/help
dir_languages=sd:/wiiflow/languages
dir_list_cache=sd:/wiiflow/cache/lists
dir_music=sd:/wiiflow/music
dir_plugins=sd:/wiiflow/plugins
dir_screenshot=sd:/wiiflow/screenshots
dir_settings=sd:/wiiflow/settings
dir_source=sd:/wiiflow/source_menu
dir_themes=sd:/wiiflow/themes
dir_trailers=sd:/wiiflow/trailers
dir_txtcheat=sd:/wiiflow/codes
dir_wip=sd:/wiiflow/codes/wip
display_music_info=yes
dpad_mode=no
exit_to=1
game_language=0
hidechannel=no
hideviews=no
ini_rev=439
keep_png=yes
language=0
max_fsaa=3
music_fade_rate=8
parent_code=
randomize_music=yes
returnto=DWFA
rumble=yes
save_favorites_mode=no
sound_volume_bnr=255
sound_volume_coverflow=255
sound_volume_gui=255
sound_volume_music=255
startup_menu=no
theme=default
tv_height=480
tv_width=640
tv_x=0
tv_y=0
update_cache=no
updatetxturl=http://dl.dropbox.com/u/25620767/WiiflowMod/versions.txt
use_grab=no
use_source=yes
video_mode=0
vipatch=no
wii_games_dir=%s:/wbfs
wiimote_gestures=no
[HOMEBREW]
current_item=
disable=no
dump_list=no
last_cf_mode=1
parental=no
partition=0
smallbox=yes
sort=0
source=no
[NAND]
current_item=
disable=yes
dump_list=no
last_cf_mode=1
partition=1
path=
show_full_banner=no
sort=0
source=noComment
Yes, I've googled it over and over again, with no luck at this point. The .ini is one continuous line, but when I copy/pasted it here, it came out the way you see it here. Installing the wad pack did not help, and I updated ios 251 from d2x v.10 beta52 to beta53, and that was also no help. I guess I'm gonna try backing up the .ini and making some changes to the one on the SD card to see what might happen there. I think I will also make a new post and ask someone with a working copy of Wiiflow (any version) if they will post thier .ini so I can see what it is supposed to look like, as opposed to what mine looks like. Even if it is from a different version, I would think it would look somewhat similar. Again, thanks for all the advice you have given to me, even if it did not get me where I want to be. I'm determined to get there eventually. By the way, thanks for the offer of an older version of Wiiflow, but I have had older versions, but for whatever reason, they would not play all of my games, most notably the BACK TO THE FUTURE game Version 4.1.3 plays them all, it just has this darn partition selection issue going on.Comment
That strange if you post the complete line it separates properly on here.
This is my 2.2.
[FANART]
enable_fanart=yes
[GAMERCARD]
wiinnertag_enable=no
wiinnertag_key=
[GENERAL]
async_network=yes
box_mode=yes
cheat=yes
compress_cache=no
country_patch=no
cover_buffer=120
current_channel=
current_game=RJ4PRM
data_on_usb=no
dir_altdol=sd:/wiiflow/codes/alt_dols
dir_bca=sd:/wiiflow/codes/bca
dir_wdm=sd:/wiiflow/codes/wdm
dump_chanlist=no
dump_gamelist=no
error_002_fix=yes
exit_to=0
favorites=no
favorites_on_startup=yes
game_language=0
hidechannelsbutton=no
keep_png=yes
language=0
last_cf_mode=1
last_chan_cf_mode=1
max_fsaa=3
music_fade_rate=8
parent_code=
partition=WBFS1
randomize_music=yes
returnto=SRFW
rumble=yes
sort=0
theme=DEFAULT
tv_height=480
tv_width=640
tv_x=0
tv_y=0
updatetxturl=http://update.wiiflow.org/txt/versions.txt
url_flat_covers_id6=http://wiitdb.com/wiitdb/artwork/cover/{loc}/{gameid6}.png|http://wiitdb.com/wiitdb/artwork/cover/EN/{gameid6}.png|http://wiitdb.com/wiitdb/artwork/cover/other/{gameid6}.png
url_full_covers_id6=http://wiitdb.com/wiitdb/artwork/coverfullHQ/{loc}/{gameid6}.png|http://wiitdb.com/wiitdb/artwork/coverfullHQ/EN/{gameid6}.png|http://wiitdb.com/wiitdb/artwork/coverfullHQ/other/{gameid6}.png|http://wiitdb.com/wiitdb/artwork/coverfull/{loc}/{gameid6}.png|http://wiitdb.com/wiitdb/artwork/coverfull/EN/{gameid6}.png|http://wiitdb.com/wiitdb/artwork/coverfull/other/{gameid6}.png
use_grab=no
video_mode=1
vipatch=no
waitmessage_wiilight=yes
wiimote_gestures=no
write_playlog=yes
I've just tried to play BACK TO THE FUTURE on WiiFlow it started up but when I click on an episode it jumps back to the Wii menu. I play it with USB Loader GX and it plays perfectly. I would forget WiiFlow and stick to USB Loader GX if I were you.
Another thing I when into the saved games and there is a new one WiiFlow Save that must have been made when I used 4.2 earlier so that got erased.Keith
Now because the older WiiFlow 2.2 isn't available to download I've now added it in the Wii Dowloads section WiiFlow2.2-249. If your having problems when you exit WiiFlow with the Exception (DSI) occurred error then add this older version to the SD card and try it.Keith
Thank you, but no thank you. I don't want the older versions because they will not play some of the games, whereas the newer versions will. (reference what I said earlier about the BACK TO THE FUTURE game) Anyway, I have been away from here for several days while I tried to get my Wii/Wiiflow issue sorted out, and I finally decided to take your advice and get rid of Wiiflow completely. I now have CFG and Loader GX, and all is very well. I see under your avatar, it says 'thanked 48 times in 48 posts'. I'd like to add to this number, but do not know how to do so. Can you assist me with this, or does it not really matter to you one way or the other?Comment
Well under your details on the left their is a Thanks link if you click on it it thanks me for that reply. If you like any reply I've given the just click on the Thanks, it click the wrong one it says Remove the thanks on the right click that.Keith
