some games not working
  • bowie
    • 475
    hi all,
    i've been using usb loader gx for a while now got about 150 games on my hhd but all of a sudden some games have stopped working. i try to load them and i just get a blank sceen. i've tried deleting all the box arts and disk covers, because i've read that can be a problem, but no joy. any ideas? syscheck below
    sysCheck v2.1.0b19 by Double_A and R2-D2199, Nano
    ...runs on IOS58 (rev 6176).
    Region: PAL
    System Menu 4.3E (v514)
    Priiloader installed
    Drive date: 2007.02.13
    Homebrew Channel 1.1.0 running on IOS58
    HomebrewFilter ist nicht installiert
    Hollywood v0x11
    Console ID: 77775946
    Boot2 v4
    Found 220 titles.
    Found 54 IOS on this console. 5 of them are stub.
    IOS4 (rev 65280): Stub
    IOS9 (rev 54321): Trucha Bug
    IOS10 (rev 768): Stub
    IOS11 (rev 54321): Trucha Bug
    IOS12 (rev 269): No Patches
    IOS13 (rev 273): No Patches
    IOS14 (rev 520): No Patches
    IOS15 (rev 523): No Patches
    IOS16 (rev 54321): Trucha Bug, ES Identify, Flash Access, NAND Access
    IOS17 (rev 775): No Patches
    IOS20 (rev 54321): Trucha Bug
    IOS21 (rev 782): No Patches
    IOS22 (rev 1037): No Patches
    IOS28 (rev 1550): No Patches
    IOS30 (rev 54321): Trucha Bug
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3091): No Patches
    IOS34 (rev 3348): No Patches
    IOS35 (rev 3349): No Patches
    IOS36 (rev 54321): Trucha Bug, ES Identify, NAND Access
    IOS37 (rev 3869): No Patches
    IOS38 (rev 3867): No Patches
    IOS40 (rev 3072): Stub
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 54321): Trucha Bug
    IOS51 (rev 4864): Stub
    IOS52 (rev 5888): Stub
    IOS53 (rev 5406): No Patches
    IOS55 (rev 5406): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5661): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 54321): Trucha Bug
    IOS61 (rev 5662): No Patches
    IOS70 (rev 54321): Trucha Bug
    IOS80 (rev 54321): Trucha Bug
    IOS90 (rev 54321): Trucha Bug
    IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
    IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS223[38+37] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
    IOS236 (rev 54321): Trucha Bug, ES Identify, NAND Access
    IOS245[37] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS246[38] (rev 21008, Info: d2x-v8final): Trucha Bug, ES Identify, NAND Access
    IOS247[53] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS248[55] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS251[58] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v10
    Report generated on 2013/10/27.
    Men of Harlech onto glory
    This shall ever be your story
    Keep these fighting words before ye
    Cambria will not yield
  • Keithuk
    • 2264
    Sorry for the late post but I've just got back from a 2 weeks holiday in USA.
    I don't see much wrong with that sysCheck only your IOS236 is an older version 54321 my IOS236-v5-Mod is 65535, the disc art won't cause this problem. I assume your using USB Loader GX 3.0?
    Is every game on your drive showing a blank screen?
    Keith
    2010 Golf GTD (170)
    • bowie
      • 475
      hi keith, hope you had a good holiday.
      yeah i have the latest gx and its only some games doing it, like lego star wars 3 wouldn't work so i deleted it and got a new one then it worked fine. but a few more games are doing it like skylanders giants.
      also i've installed your new IOS236 but unfortunately no joy.
      thanks bowie
      • Keithuk
        • 2264
        I don't have LEGO Star Stars 3 but I have 5 other LEGO games that all work. I do have Skylanders Giants - PAL - SKYP52 but that needs USB wireless receiver/Portal of Power which you only get with the original game.
        Keith
        2010 Golf GTD (170)
        • bowie
          • 475
          i have the portal of power, got it with the first skylanders game. the problem i got is all my games used to work but now a few have stopped. what i think may of happened is because my drive is formatted to wbfs, sometimes when you delete a game i think it can remove some files from the game next to it?
          don't know how i'm going to get around it.
          • Keithuk
            • 2264
            I've deleted games with USB Loader GX and WBFS Manager and all the others still work.
            Keith
            2010 Golf GTD (170)
            • bowie
              • 475
              yeah i've never had a problem doing it in the past, but that is the only answer i've been able to find
              "There is NO good reason to be using a WBFS formatted drive and WBFS Manager anymore. If you are consistently adding and removing games you end up with unusable sections of the drive. WBFS formatted drives need the game in one continuous spot and write games directly after each other. So if you had a 3GB game you deleted from the middle of the drive then the next 2 games you install are 2GB each you now have a 1GB gap (because it will fill in the deleted spot but then skip to end of drive to write the whole second game) and NO program to defrag and condense the gaps. You don't have that issue with a drive containing a file allocation table..."
              not my words btw
