ive got an argon chip in my wii and i got an ntsc version of the kart. ran the update without even knowing it was an ntsc version. luckily i have the same region, so ive learned my lesson on checking the region. however ive tried to burn the kart around 5 times now.
the first time i used a blank dvd+r that was kind of scratched. like i said i ran the update then it loaded up fine. then i got a warning telling me that it couldnt read the disc right before the race. i ejected the disc then put it back in and the race started. after the race the same thing. then i ejected it and put it back in and it worked. so i can keep ejecting and re inserting and it will work fine.
the 2nd time i used a new dvd+R with that ppf patch and i got a message saying remove the disc from the wii and turn it off. i did as it said. but the power button wouldnt work, i had to unplug the machine.
the 3rd time i used a dvdrw and the same thing as the 1st time i burned the disc.
4th time i used a dual layer disc bc i ran out of dvd+R(which is also why i used an rw the 3rd time) it wouldnt work either
5th time i used the wiibrickblocked then again i put it on a DL it still wouldnt work.
has anyone had these problems? id keep trying but im running out of DL's and those things arent cheap. can i even burn a game to a DL or RW? im kinda new to the wii scene so im not entirely sure what im doing. however i got SMG to work fine on my first burn, then i tried the kart and everything went downhill
by me...its not possible, not even plausible....
