wii sports resort
  • thelips
    • 84
    wii sports resort
    has anybody got this working on version 3.2e and if so would you tell me if you would thanks
  • wernley
    • 113
    is your wii soft modded or chipped might help with the answer pal
    • thelips
      • 84
      my wii is softmodded
      • wernley
        • 113
        1. Create NeoGamma Folder in the root of SD card and WITH RZTP.dol in it.OR IN THE neogamma v6 folder in APPS folder.
        MAKE SURE THE boot.dol is also in there.
        2. Through homebrew load Neogamma R6. Set setting in Neogamma to:
        002 fix: ON
        Alternative dol: SD
        3. Launch Disc. Game will load from RZTP.dol from SD card. You will be shown I video on how to connect wii motion plus.
        The video will end and you will have to push A. The system will restart and your back to the main menu.
        4. NOW go back to NeoGamma and turn off Alternative Dol. And Launch Disc.
        • thelips
          • 84
          002 fix: ON
          Alternative dol: SD
          do u have to this every time u want 2 play it or just the 1st time thanks again!!! took a while but got to load it and does it only work this way
          • funkysy
            • 105
            once you have done it once you need to again but you will have to use the HBC and neogamma to play
            • thelips
              • 84
              i tried 2 load straight from usb without watching video for 2nd time around just to see if it loaded and it did so thought no need to watch video twice!!!
              • Seasider
                • Jun 2009
                • 49
                I must be doing something wrong....still cannot get it to load using neogamma but loads and works fine using 1.5 or gx....oh well,.....least I can play it
                • ocrim
                  • 107
                  Hi, My wii its chipped, its possible play the game without problem??? (wiikey2)
                  Thank you
