hello im new to wii soft modding, and am in need of help. i intstalled homebrew channel, and i followed this guide How to Play Wii Games from a USB Drive or Thumb Drive: 35 Steps to install usb gx, i used dop mii for ios36, i didnt have cIOS38r17 installer, but i used d2x cIOS Installer and messed with 249 and 250. when i launch usb gx it freezes trying to load the usb, everytime no matter what. i did a system checksysCheck v2.1.0b19 by Double_A and R2-D2199, Nano...runs on IOS58 (rev 6176).Region: NTSC-USystem Menu 4.3U (v513)Priiloader installedDrive date: 2008.07.14Homebrew Channel 1.1.2 running on IOS58HomebrewFilter ist nicht installiertHollywood v0x21Console ID: 97114257Boot2 v4Found 73 titles.Found 47 IOS on this console. 16 of them are stub.IOS3 (rev 65280): StubIOS4 (rev 65280): StubIOS9 (rev 1034): No PatchesIOS10 (rev 768): StubIOS11 (rev 256): StubIOS12 (rev 526): No PatchesIOS13 (rev 1032): No PatchesIOS14 (rev 1032): No PatchesIOS15 (rev 1032): No PatchesIOS16 (rev 512): StubIOS17 (rev 1032): No PatchesIOS20 (rev 256): StubIOS21 (rev 1039): No PatchesIOS22 (rev 1294): No PatchesIOS28 (rev 1807): No PatchesIOS30 (rev 2816): StubIOS31 (rev 3608): No PatchesIOS33 (rev 3608): No PatchesIOS34 (rev 3608): No PatchesIOS35 (rev 3608): No PatchesIOS36 (rev 3351): ES Identify, NAND AccessIOS37 (rev 5663): No PatchesIOS38 (rev 4124): No PatchesIOS40 (rev 3072): StubIOS41 (rev 3607): No PatchesIOS43 (rev 3607): No PatchesIOS45 (rev 3607): No PatchesIOS46 (rev 3607): No PatchesIOS48 (rev 4124): No PatchesIOS50 (rev 5120): StubIOS51 (rev 4864): StubIOS52 (rev 5888): StubIOS53 (rev 5663): No PatchesIOS55 (rev 5663): No PatchesIOS56 (rev 5662): No PatchesIOS57 (rev 5919): No PatchesIOS58 (rev 6176): USB 2.0IOS60 (rev 6400): StubIOS61 (rev 5662): No PatchesIOS62 (rev 6430): No PatchesIOS70 (rev 6912): StubIOS80 (rev 6944): No PatchesIOS222 (rev 65280): StubIOS223 (rev 65280): StubIOS249[37] (rev 21006, Info: d2x-v6): Trucha Bug, NAND Access, USB 2.0IOS250[37] (rev 21006, Info: d2x-v6): Trucha Bug, NAND Access, USB 2.0IOS254 (rev 65280): StubBC v6MIOS v10Report generated on 2014/05/14.my goal is to just play a wbfs file off my computer onto the usb, i do not currently have the disk.. can anyone shed some light please?
having problems with softmodding, please help!
hello im new to wii soft modding, and am in need of help. i intstalled homebrew channel, and i followed this guide How to Play Wii Games from a USB Drive or Thumb Drive: 35 Steps to install usb gx, i used dop mii for ios36, i didnt have cIOS38r17 installer, but i used d2x cIOS Installer and messed with 249 and 250. when i launch usb gx it freezes trying to load the usb, everytime no matter what. i did a system checksysCheck v2.1.0b19 by Double_A and R2-D2199, Nano...runs on IOS58 (rev 6176).Region: NTSC-USystem Menu 4.3U (v513)Priiloader installedDrive date: 2008.07.14Homebrew Channel 1.1.2 running on IOS58HomebrewFilter ist nicht installiertHollywood v0x21Console ID: 97114257Boot2 v4Found 73 titles.Found 47 IOS on this console. 16 of them are stub.IOS3 (rev 65280): StubIOS4 (rev 65280): StubIOS9 (rev 1034): No PatchesIOS10 (rev 768): StubIOS11 (rev 256): StubIOS12 (rev 526): No PatchesIOS13 (rev 1032): No PatchesIOS14 (rev 1032): No PatchesIOS15 (rev 1032): No PatchesIOS16 (rev 512): StubIOS17 (rev 1032): No PatchesIOS20 (rev 256): StubIOS21 (rev 1039): No PatchesIOS22 (rev 1294): No PatchesIOS28 (rev 1807): No PatchesIOS30 (rev 2816): StubIOS31 (rev 3608): No PatchesIOS33 (rev 3608): No PatchesIOS34 (rev 3608): No PatchesIOS35 (rev 3608): No PatchesIOS36 (rev 3351): ES Identify, NAND AccessIOS37 (rev 5663): No PatchesIOS38 (rev 4124): No PatchesIOS40 (rev 3072): StubIOS41 (rev 3607): No PatchesIOS43 (rev 3607): No PatchesIOS45 (rev 3607): No PatchesIOS46 (rev 3607): No PatchesIOS48 (rev 4124): No PatchesIOS50 (rev 5120): StubIOS51 (rev 4864): StubIOS52 (rev 5888): StubIOS53 (rev 5663): No PatchesIOS55 (rev 5663): No PatchesIOS56 (rev 5662): No PatchesIOS57 (rev 5919): No PatchesIOS58 (rev 6176): USB 2.0IOS60 (rev 6400): StubIOS61 (rev 5662): No PatchesIOS62 (rev 6430): No PatchesIOS70 (rev 6912): StubIOS80 (rev 6944): No PatchesIOS222 (rev 65280): StubIOS223 (rev 65280): StubIOS249[37] (rev 21006, Info: d2x-v6): Trucha Bug, NAND Access, USB 2.0IOS250[37] (rev 21006, Info: d2x-v6): Trucha Bug, NAND Access, USB 2.0IOS254 (rev 65280): StubBC v6MIOS v10Report generated on 2014/05/14.my goal is to just play a wbfs file off my computer onto the usb, i do not currently have the disk.. can anyone shed some light please? -
Well a sysCheck looks better when its laid out correctly. You have 16 IOS's that are Stub you have to reduce that to 4 or 5 by using this following procedure.hello im new to wii soft modding, and am in need of help.
Hollywood v0x21
Boot2 v4
Found 73 titles.
BC v6
MIOS v10
Download ModMii6.3.1 and run ModMii.exe from Windows. Use the SU option from the main menu and find the location of the sysCheck.csv from the sysCheck which is on the root of the SD card. That will download all missing wads and apps to COPY_TO_SD sub folder just add all files and folders to the SD card.
ModMii only installed 2 d2x v8.0 wads download d2x v8 Final wad pack and put these in the wad folder on the SD card, install all 7 wads when you install the other wads.
Put the SD card back in the Wii and run Homebrew. You already have IOS236 but it won't hurt to install it again. Run IOS236 Installer v5 Mod first before you install any other wads. Multi Mod Manager (MMM) should be the first app listed select it and load it. Once running scroll down to WAD Manager and press 'A' that will default to all wads in the wad folder. If you want to install all wads shown just press 1 that will list all wads you want to install press 'A' again to install them all.
Watch for the Installed OK message after each one. If any don't say that message make a note of the wad name and back out. Scroll down to the wad that didn't install and press the + button the put a green + next to it then press 'A' to see that wads name listed then press 'A' to install again.
Download PriiLoader 0.7 add it to the SD card and run it from Homebrew and set it to block online and disc updates, you can turn off the 'A' safety prompt on startup I do.
If you have to update to 4.3 then the Shopping Channel may not work. If it doesn't without doing another system update don't bother just install my RVL-Shopping-21
Do another sysCheck to make sure everything installed correctly and post that.
Then you just have a to find a compatible mains powered USB hard drive to add your games onto and download USB Loader GX 3.0 to run them.Keith
2010 Golf GTD (170)Comment
