Help
  • wiihackplz
    • Jul 2014
    • 10
    Help
    Can't i just reset my wii all over again and install homebrew again???
  • Keithuk
    • 2264
    It won't reset with the reset button or power button.
    So are thing working as before or not?
    Keith
    2010 Golf GTD (170)
    • wiihackplz
      • Jul 2014
      • 10
      I mean like if I could erase everything on my wii and install homebrew again. I did a syscheck19 im not sure if its that but i did it. Anyways i want to launch bootmii but it does not allow me the screen just turns black and the disc drive just blinks. Other than that my wii works fine. Ill send you the syscheck19 maybe you can help me.
      sysCheck v2.1.0b19 by Double_A and R2-D2199, Nano
      ...runs on IOS58 (rev 6432).
      Region: NTSC-U
      System Menu 4.3U (v513)
      Drive date: 2008.12.18
      Homebrew Channel 1.1.0 running on IOS58
      HomebrewFilter ist nicht installiert
      Hollywood v0x21
      Console ID: 202216727
      Boot2 v5
      Found 72 titles.
      Found 47 IOS on this console. 17 of them are stub.
      IOS3 (rev 65280): Stub
      IOS4 (rev 65280): Stub
      IOS9 (rev 1290): No Patches
      IOS10 (rev 768): Stub
      IOS11 (rev 256): Stub
      IOS12 (rev 782): No Patches
      IOS13 (rev 1288): No Patches
      IOS14 (rev 1288): No Patches
      IOS15 (rev 1288): No Patches
      IOS16 (rev 512): Stub
      IOS17 (rev 1288): No Patches
      IOS20 (rev 256): Stub
      IOS21 (rev 1295): No Patches
      IOS22 (rev 1550): No Patches
      IOS28 (rev 2063): No Patches
      IOS30 (rev 2816): Stub
      IOS31 (rev 3864): No Patches
      IOS33 (rev 3864): No Patches
      IOS34 (rev 3864): No Patches
      IOS35 (rev 3864): No Patches
      IOS36 (rev 54321): Trucha Bug, ES Identify, NAND Access
      IOS37 (rev 5919): No Patches
      IOS38 (rev 4380): No Patches
      IOS40 (rev 3072): Stub
      IOS41 (rev 3863): No Patches
      IOS43 (rev 3863): No Patches
      IOS45 (rev 3863): No Patches
      IOS46 (rev 3863): No Patches
      IOS48 (rev 4380): No Patches
      IOS50 (rev 5120): Stub
      IOS51 (rev 4864): Stub
      IOS52 (rev 5888): Stub
      IOS53 (rev 5919): No Patches
      IOS55 (rev 5919): No Patches
      IOS56 (rev 5918): No Patches
      IOS57 (rev 6175): No Patches
      IOS58 (rev 6432): USB 2.0
      IOS60 (rev 6400): Stub
      IOS61 (rev 5918): No Patches
      IOS62 (rev 6430): No Patches
      IOS70 (rev 6912): Stub
      IOS80 (rev 7200): No Patches
      IOS222 (rev 65280): Stub
      IOS223 (rev 65280): Stub
      IOS249 (rev 65280): Stub
      IOS250 (rev 65280): Stub
      IOS254 (rev 65281): BootMii
      BC v6
      MIOS v10
      Report generated on 2014/06/25.
      • Keithuk
        • 2264
        As you may have read on here that's a typical sysCheck of a Wii that's only been softmodded as you have 17 IOS's that are Stub. You need to reduce that 17 down to 4 or 5.
        Download ModMii6.3.1 and run ModMii.exe from Windows. Use the SU option from the main menu and find the location of the sysCheck.csv from the sysCheck which is on the root of the SD card. That will download all missing wads and apps to COPY_TO_SD sub folder just add all files and folders to the SD card.
        ModMii only installed 2 d2x v8.0 wads download d2x v8 Final wad pack and put these in the wad folder on the SD card, install all 7 wads when you install the other wads.
        Put the SD card back in the Wii and run Homebrew. Run IOS236 Installer v5 Mod first before you install any other wads. Multi Mod Manager (MMM) should be the first app listed select it and load it. Once running scroll down to WAD Manager and press 'A' that will default to all wads in the wad folder. If you want to install all wads shown just press 1 that will list all wads you want to install press 'A' again to install them all.
        Watch for the Installed OK message after each one. If any don't say that message make a note of the wad name and back out. Scroll down to the wad that didn't install and press the + button the put a green + next to it then press 'A' to see that wads name listed then press 'A' to install again.
        Download PriiLoader 0.7 add it to the SD card and run it from Homebrew and set it to block online and disc updates, you can turn off the 'A' safety prompt on startup I do.
        If you have to update to 4.3 then the Shopping Channel may not work. If it doesn't without doing another system update don't bother just install my RVL-Shopping-21
        Do another sysCheck to make sure everything installed correctly and post that.
        Then you just have a to find a compatible mains powered USB hard drive to add your games onto and download USB Loader GX 3.0 to run them.
        Keith
        2010 Golf GTD (170)
