i did everything you said to do but it doesnt work when i try to install ios236-v5-mod it comes up the screen and say failed to install and it said that it cud not find some file in the sd then my wii control doesnt work to push anything.
still need help
Tags: None
Why have you started a new thread for the same problem?
Did you follow my instructions to the letter? You copy all files and folder from COPY_TO_SD folder t the SD card.
IOS236 Installer v5 Mod needs IOS36-64-v3351.wad on the root of the SD card before it will install.Keith
2010 Golf GTD (170) -
im kinda new so i dont know how this works. Anyways i was able to to download the ISO36-64-v3351 but now i went to the second step which was the mod mii u told me to to go to wad manager but then my control stops working i cant scroll down to wad manager then if i take off my battery and put it back inside it starts to blink and the screen has dots flying i dont know how to fix that.Comment
im not an expert but it might have something to do with your remote,if your remote has motion plus built in I don't think it will work when trying to softmod you will need one without the motion plusComment
Thats what i figured i did some research and i was having that problem where the remote just started to blink and my remote had wii motion plus and when i saw a video it was the other control that worked fine the one and it worked perfectly without the wii motion plus.Comment
