How do I create unlimited channels for WiiWare games, etc?
  • danielscissorhands
    • Aug 2014
    • 12
    Hi. On my soft-modded Wii, I have all the Wii Ware games, but I think you can only create like 48 channels on the Wii Memory, unless you have "emulated memory" or nand or something. I don't even know what that means.
    Can someone please help me so that it installs the wad files to my sd card or hard drive so that I have more memory for channels?
    Also, is there a way to play wad games without installing channels?
    Thanks.
    Noob Scissorhands.
  • Keithuk
    • 2264
    Post a sysCheck19 report as instructed I that link so I can see which IOS's you've installed.
    Keith
    2010 Golf GTD (170)
      • Aug 2014
      • 12
      Thanks, Keith. Here is my system check:
      ps: I also posted 2 other questions that no one has replied to yet, maybe you can check those out too...?
      1. http://www.digital-kaos.co.uk/forums...memory-435900/
      2. http://www.digital-kaos.co.uk/forums...-cioss-435878/
      sysCheck v2.1.0b19 by Double_A and R2-D2199, Nano
      ...runs on IOS58 (rev 6176).
      Region: NTSC-U
      System Menu 4.3U (v513)
      Drive date: 2007.02.13
      Homebrew Channel 1.1.2 running on IOS58
      HomebrewFilter ist nicht installiert
      Hollywood v0x11
      Console ID: 48460815
      Boot2 v4
      Found 107 titles.
      Found 46 IOS on this console. 14 of them are stub.
      IOS4 (rev 65280): Stub
      IOS9 (rev 1034): No Patches
      IOS10 (rev 768): Stub
      IOS11 (rev 256): Stub
      IOS12 (rev 526): No Patches
      IOS13 (rev 1032): No Patches
      IOS14 (rev 1032): No Patches
      IOS15 (rev 1032): No Patches
      IOS16 (rev 512): Stub
      IOS17 (rev 1032): No Patches
      IOS20 (rev 256): Stub
      IOS21 (rev 1039): No Patches
      IOS22 (rev 1294): No Patches
      IOS28 (rev 1807): No Patches
      IOS30 (rev 2816): Stub
      IOS31 (rev 3608): No Patches
      IOS33 (rev 3608): No Patches
      IOS34 (rev 3608): No Patches
      IOS35 (rev 3608): No Patches
      IOS36 (rev 3351): ES Identify, NAND Access
      IOS37 (rev 5663): No Patches
      IOS38 (rev 4124): No Patches
      IOS40 (rev 3072): Stub
      IOS41 (rev 3607): No Patches
      IOS43 (rev 3607): No Patches
      IOS45 (rev 3607): No Patches
      IOS46 (rev 3607): No Patches
      IOS48 (rev 4124): No Patches
      IOS50 (rev 5120): Stub
      IOS51 (rev 4864): Stub
      IOS52 (rev 5888): Stub
      IOS53 (rev 5663): No Patches
      IOS55 (rev 5663): No Patches
      IOS56 (rev 5662): No Patches
      IOS57 (rev 5919): No Patches
      IOS58 (rev 6176): USB 2.0
      IOS60 (rev 6400): Stub
      IOS61 (rev 5662): No Patches
      IOS62 (rev 6430): No Patches
      IOS70 (rev 6912): Stub
      IOS80 (rev 6944): No Patches
      IOS222 (rev 65280): Stub
      IOS223 (rev 65280): Stub
      IOS249[37] (rev 21006, Info: d2x-v6): Trucha Bug, NAND Access, USB 2.0
      IOS250[37] (rev 21006, Info: d2x-v6): Trucha Bug, NAND Access, USB 2.0
      IOS254 (rev 65281): BootMii
      BC v6
      MIOS v10
      Report generated on 2014/08/21.
      • Keithuk
        • 2264
        I don't bother with Wii Ware games but that sysCheck has 14 IOS's that are Stub you need to reduce that to 3 or 4 if you want to run games of an external USB hard drive.
        As I've posted many many times on here.
        Download ModMii6.3.1 and run ModMii.exe from Windows. Use the SU option from the main menu and find the location of the sysCheck.csv from the sysCheck which is on the root of the SD card. That will download all missing wads and apps to COPY_TO_SD sub folder just add all files and folders to the SD card.
        ModMii only installed 2 d2x v8.0 wads download d2x v8 Final wad pack and put these in the wad folder on the SD card, install all 7 wads when you install the other wads.
        Put the SD card back in the Wii and run Homebrew. Run IOS236 Installer v5 Mod first before you install any other wads. Multi Mod Manager (MMM) should be the first app listed select it and load it. Once running scroll down to WAD Manager and press 'A' that will default to all wads in the wad folder. If you want to install all wads shown just press 1 that will list all wads you want to install press 'A' again to install them all.
        Watch for the Installed OK message after each one. If any don't say that message make a note of the wad name and back out. Scroll down to the wad that didn't install and press the + button the put a green + next to it then press 'A' to see that wads name listed then press 'A' to install again.
        Download PriiLoader 0.7 add it to the SD card and run it from Homebrew and set it to block online and disc updates, you can turn off the 'A' safety prompt on startup I do.
        Keith
        2010 Golf GTD (170)
          • Aug 2014
          • 12
          Thanks. I think I installed Priiloader. It took me a while to figure out that I have to hold down the reset key to get it to load. :P
          But.. I noticed I can't exit to the Homebrew Channel from it, i can get an error that says something like "Maybe it's not installed?" But it is installed. It will let me choose the option to exit to the Wii's Main Menu, but not to the HC. Do you know how i fix this?
          Btw, do I need priloader if I already have Bootmii installed as boot2? Isn't that redundant? And also do i have to worry about disk updates if Nintendo has shut down their servers for the Wii. They shut them down in May.
          And, will the hacks I installed on Priiloader work if I load my Wii normally without using Priiloader? Like the region free stuff, etc.. or do I always need to load it using Priiloader for those to work?
          Did I install Priiloader wrong?
          There is a folder called APPS and another folder called EXTRA, and then in the root are two files: GPL and READMEH
          AND then... in the apps folder there is the PRILOADER folder, and then in the EXTRA folder there is another zip file called LOAD PRILOADER and inside of that are two sub folders called INCLUDE and SOURCE and like 5 files (.boot, .dol. .elf .sln, and makefile). And, in the root of that second zip folder there are a few files as well.
          I was confused by the zip folder inside the sub folder that is in the main zip folder.
          Btw, you didn't tell me to download the hacks.ini file but I found out about that in a google search, so i put it in the root of the sd card. Is that right?
          And finally... Is there a way to load WiiWare wads from my HD instead of the SD card?
          And.. is there a way to play wad games without installing them as channels?
          Your help is much appreciated. Thanks!
          Here is my latest System Check:
          Region: NTSC-U
          Priiloader installed
          Hollywood v0x11
          Boot2 v4
          Found 107 titles.
          Found 54 IOS on this console. 4 of them are stub.
          IOS11 (rev 16174): Trucha Bug, NAND Access
          IOS20 (rev 16174): Trucha Bug, NAND Access
          IOS30 (rev 16174): Trucha Bug, NAND Access
          IOS36 (rev 65535): Trucha Bug, ES Identify, NAND Access
          IOS40 (rev 16174): Trucha Bug, NAND Access
          IOS50 (rev 16174): Trucha Bug, NAND Access
          IOS52 (rev 16174): Trucha Bug, NAND Access
          IOS60 (rev 16174): Trucha Bug, NAND Access
          IOS70 (rev 16174): Trucha Bug, NAND Access
          IOS80 (rev 16174): Trucha Bug, NAND Access
          IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
          IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
          IOS223[38+37] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
          IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
          IOS236 (rev 65535): Trucha Bug, ES Identify, NAND Access
          IOS245[37] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
          IOS246[38] (rev 21008, Info: d2x-v8final): Trucha Bug, ES Identify, NAND Access
          IOS247[53] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
          IOS248[55] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
          IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
          IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
          IOS251[58] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
          BC v6
          MIOS v10
          Report generated on 2014/08/23.
          Daniel
            • Aug 2014
            • 12
            ps:
            I uninstalled and then reinstalled the HBC. And Priiloader still wouldn't exit to it, but I found a workaround here:
            What steps will reproduce the problem? 1. Install Homebrew Channel 1.1.2 (HackMii Installer 1.2) 2. Install Priiloader 0.7 3. Try to load Homebrew Channel from Priiloader What is the expected outpu...
            Q:"Can you update Priiloader to realize that HBC now uses LULZ as its title?"
            A:"ye the new titleID isn't added yet. use the boot title menu to boot it "
            That worked for me! Yay!
            Why doesn't it work normally though? :P
            • Keithuk
              • 2264
              That first sysCheck didn't show PriiLoader that's why I told you to install, the second sysCheck shows its installed. PriiLoader can be a bit awkward sometimes it will say can't find hacks.ini even though its on the root of the SD card, you can forget can't find password file. Just power the Wii off and start it and it installs no problem.
              That second sysCheck looks correct its the same as mine http://syscheck.softwii.de/MKWDueNa
              There is only 3 things you need to disable with PriiLoader block online and disc updates, you can turn off the 'A' safety prompt on startup I do.
              "I was confused by the zip folder inside the sub folder that is in the main zip folder."
              There shouldn't be any extra zips on the SD card unless you have downloaded updates from USB Loader GX.
              "Btw, you didn't tell me to download the hacks.ini file but I found out about that in a google search"
              The ini files are this the PriiLoader download link I gave you PriiLoader 0.7
              Keith
              2010 Golf GTD (170)
