Hello everyone, let me first start out by saying I'm no stranger to Softmodding Wii's, I have done over 10 of them, some of them have been easy while others have required a bit more work to fix up. I also wanted to say that I really like the community here and there are some very talented individuals who post. Which is why I'm about to tell you my current problem after rescuing a Wii from a Black Screen Of Death.
I followed the direction of the number of people who were able to rescue Wii's from the BSOD from installing a Bluetooth Module. I stripped the Wii down to the core, where only the bottom of the plastic case remains, everything else is exposed. I even disconnected the DVD Rom Drive because it wasn't functioning. After installing the new Bluetooth Module I was able to load up into the System Menu and install The Homebrew Channel and all the cIOSes that would make my games run off of a external USB Drive successfully but this is where my trouble started again....
I am getting an error message after a delayed startup of all games I try to play that says: "An error has occured press the eject button remove the game disc and turn off the power to the console." I have had a few other consoles with bad DVD Roms with homebrew installed successfully on them but none of them actually had the DVD Rom REMOVED....so here is my question, by disconnecting the drive did I bring this error message out at me and how would I go about correcting it?
Let it be noted I can still access everything okay, including The Homebrew Channel and the Wii System Menu I just can't play any Games.
. Keep in mind i installed homebrew without the DVD Rom being hooked up, it won't work at all, but I figured I didn't need it because I have a USB drive with all the games on it. That USB drive was hooked up to other wiis that have homebrew installed and it worked fine with them. I have never modded a wii without the drive being hooked up though, do you think that caused it?
