I did the softmod by myself because i wanted to play some JP games on my NTSC wii. Altho everything turned out working but i still have some unsolved questions in mind. I had followed the softmodding steps below:
1) Format your SD card to FAT16. Copy the contents inside the sd folder to the root of your SD card
If you have bootmii with a nand backup, the homebrew channel, and cios installed already you may skip to step 8
2) Insert the SD card in the Wii and go to Data Management>Channels>SD Card press YES on the dialog box that asks to load boot.dol
3) Install the Homebrew Channel and install BootMii as boot2 if possible or as an IOS if boot2 is not available.
4) Launch Bootmii (if you installed to boot2 just reset the system if you installed to IOS go to the HBC and press the Home button)
5) Open the config menu (gears) and choose backup NAND (green arrow) wait for it to finish and restart the Wii
6) Run Trucha Bug Restorer and choose "IOS36" and pick "Downgrade IOS15" and "Download IOS from NUS" then restart
7) Run Trucha Bug Restorer again and choose "IOS15" then "IOS36 menu" set "IOS to slot 36" and "yes" "yes" "yes" to the 3 options then press "Install patched IOS36" and "Download IOS from NUS"
8) Install cIOS36 rev10 to IOS249 using Network install mode
9) Downgrade system IOS files using IOS Downgrader
10) Downgrade to 3.2 using cIOS Downgrader even if you are already on 3.2 run this
11) Run 4.1 Firmware-Updater.
12) Using Dop-IOS install IOS60 v6174 with Sig Hash Check.
13) Install preloader. On the install screen press 1
14) Set your preloader settings. In preloader hacks enable "Skip disc update check"
however i skipped step 10 and my wii stays at 4.1U. I also skipped step 11 and 12. At the end i use NeoGamma to load the JP game i wanted to play and it works
Just wondering if it's ok to skip step 10-12? What's gonna happen if i downgrade my wii to 3.2? Btw my wii doesnt start with LU64.
Thank you
Thank you
