Wiiflow says not enough blocks, though about 40GB available on usb
  • loz1
    • Nov 2014
    Hello,
    I bought a second hand wii for my niece, and I have the homebrew channel installed and wiiflow channel installed. When I go to install games on wiiflow it says I don't have enough blocks. For example I am trying to install 'Mad Dog McCree' from an original disc and it says "Not Enough Space: 441 6602 1 12 blocks needed, 295007 available.
    My calculations this is about 40GB I have available.
    Here's the Syscheck if that helps at all;
    sysCheck v2.1.0b19 by Double_A and R2-D2199 Nano
    ...runs on IOS58 (rev 6176).
    Region: PAL
    System Menu 4.3E (v514)
    Drive date: 2008.07.14
    Homebrew Channel 1.1.2 running on IOS58
    HomebrewFilter ist nicht installiert
    Hollywood v0x21
    Console ID: 94968611
    Boot2 v4
    Found 82 titles.
    Found 48 IOS on this console. 12 of them are stub.
    IOS3 (rev 65280): Stub
    IOS4 (rev 65280): Stub
    IOS9 (rev 1034): No Patches
    IOS10 (rev 768): Stub
    IOS11 (rev 256): Stub
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS16 (rev 512): Stub
    IOS17 (rev 1032): No Patches
    IOS20 (rev 256): Stub
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 2816): Stub
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 3608): No Patches
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS40 (rev 3072): Stub
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 4889): No Patches
    IOS51 (rev 4864): Stub
    IOS52 (rev 5888): Stub
    IOS53 (rev 5663): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 6174): No Patches
    IOS61 (rev 5662): No Patches
    IOS62 (rev 6430): No Patches
    IOS70 (rev 6687): No Patches
    IOS80 (rev 6944): No Patches
    IOS222 (rev 65280): Stub
    IOS223 (rev 65280): Stub
    IOS236[36] (rev 65535 Info: rev 3351): Trucha Bug ES Identify NAND Access
    IOS249[38] (rev 17): Trucha Bug ES Identify NAND Access USB 2.0
    IOS250 (rev 65535): Trucha Bug ES Identify NAND Access USB 2.0
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v10
    Report generated on 2014/11/08.
    Please help.
    Thanks.
  • Keithuk
    • 2264
    Welcome to DK.
    Not enough blocks normally means you have to many saves games in Wii memory, you can reduce that by copying them to the SD card then delete them.
    That sysCheck doesn't look too bad as you only have 12 IOS's that are Stub you need to reduce that to 4-5. The easiest way is to download ModMii6.3.1 and run ModMii.exe from Windows. Use the SU option from the main menu and find the location of the sysCheck.csv from the sysCheck which is on the root of the SD card. That will download all missing wads and apps to COPY_TO_SD sub folder just add all files and folders to the SD card.
    ModMii only installed 2 d2x v8.0 wads download d2x v8 Final wad pack and put these in the wad folder on the SD card, install all 7 wads when you install the other wads.
    Put the SD card back in the Wii and run Homebrew. Multi Mod Manager (MMM) should be the first app listed select it and load it. Once running scroll down to WAD Manager and press 'A' that will default to all wads in the wad folder. If you want to install all wads shown just press 1 that will list all wads you want to install press 'A' again to install them all.
    Watch for the Installed OK message after each one. If any don't say that message make a note of the wad name and back out. Scroll down to the wad that didn't install and press the + button the put a green + next to it then press 'A' to see that wads name listed then press 'A' to install again.
    Download PriiLoader 0.7 add it to the SD card and run it from Homebrew and set it to block online and disc updates, you can turn off the 'A' safety prompt on startup I do.
    Do another sysCheck to make sure everything installed correctly and post that.
    Then you just have a to find a compatible mains powered USB hard drive to add your games onto and download USB Loader GX 3.0 to run them.
    Keith
    2010 Golf GTD (170)
    • loz1
      • Nov 2014
      Thanks Keith
      That has helped. I've managed to install Wii play but Mad Dog McCree keeps coming up with a black screen saying 99% exception (dsi), STACK DUMP, STACK DUMP, and Ghost Squad gets stuck at 99%. I haven't tried to rip any other games with WiiFlow yet.
      Here's the updated Syscheck.
      sysCheck v2.1.0b19 by Double_A and R2-D2199, Nano
      Region: PAL
      Hollywood v0x21
      Boot2 v4
      Found 86 titles.
      Found 55 IOS on this console. 5 of them are stub.
      IOS11 (rev 16174): Trucha Bug, NAND Access
      IOS20 (rev 16174): Trucha Bug, NAND Access
      IOS30 (rev 16174): Trucha Bug, NAND Access
      IOS40 (rev 16174): Trucha Bug, NAND Access
      IOS50 (rev 16174): Trucha Bug, NAND Access
      IOS52 (rev 16174): Trucha Bug, NAND Access
      IOS60 (rev 16174): Trucha Bug, NAND Access
      IOS70 (rev 16174): Trucha Bug, NAND Access
      IOS80 (rev 16174): Trucha Bug, NAND Access
      IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
      IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
      IOS223[38+37] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
      IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
      IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
      IOS245[37] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
      IOS246[38] (rev 21008, Info: d2x-v8final): Trucha Bug, ES Identify, NAND Access
      IOS247[53] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
      IOS248[55] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
      IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
      IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
      IOS251[58] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
      BC v6
      MIOS v10
      Report generated on 2014/11/11.
      Any ideas?
      • Keithuk
        • 2264
        Well that sysCheck looks ok now though you haven't installed PriiLoader 0.7 as I've suggested.
        My Mad Dog McCree Gunslinger Pack - NTSC - RQ5E5G, Mad Dog McCree Gunslinger Pack - PAL - RQ5X5G, Ghost Squad - PAL - RGSP8P play without a problem. You would be better of using USBLoader GX 3.0 All in one package ios 249
        Keith
        2010 Golf GTD (170)
