Hi, not used Wii for a couple of years and looking to upgrade to 4.3 to use the newer letterbomb as things not working as they should, any help please?? Thanks.
4.1E to 4.3E please im stuck..
So have you upgraded to 4.3 and used Letterbomb?
If you have then post a sysCheck19 report as instructed I that link so I can see which IOS's you've installed.Keith
2010 Golf GTD (170) -
is this what you want?
sysCheck v2.1.0b19 by Double_A and R2-D2199, Nano
...runs on IOS58 (rev 6176).
Region: PAL
System Menu 4.0/4.1E (v54450)
Priiloader installed
Drive date: 2006.09.07
Homebrew Channel 1.0.8 running on IOS58
HomebrewFilter ist nicht installiert
Hollywood v0x11
Console ID: 44372363
Boot2 v4
Found 139 titles.
Found 54 IOS on this console. 5 of them are stub.
IOS4 (rev 65280): Stub
IOS9 (rev 54321): Trucha Bug
IOS10 (rev 768): Stub
IOS11 (rev 54321): Trucha Bug
IOS12 (rev 526): No Patches
IOS13 (rev 1032): No Patches
IOS14 (rev 1032): No Patches
IOS15 (rev 1032): No Patches
IOS16 (rev 54321): Trucha Bug, ES Identify, Flash Access, NAND Access
IOS17 (rev 1032): No Patches
IOS20 (rev 54321): Trucha Bug
IOS21 (rev 1039): No Patches
IOS22 (rev 1294): No Patches
IOS28 (rev 1807): No Patches
IOS30 (rev 54321): Trucha Bug
IOS31 (rev 3608): No Patches
IOS33 (rev 3608): No Patches
IOS34 (rev 3608): No Patches
IOS35 (rev 3608): No Patches
IOS36 (rev 54321): Trucha Bug, ES Identify, NAND Access
IOS37 (rev 5663): No Patches
IOS38 (rev 4124): No Patches
IOS40 (rev 3072): Stub
IOS41 (rev 3607): No Patches
IOS43 (rev 3607): No Patches
IOS45 (rev 3607): No Patches
IOS46 (rev 3607): No Patches
IOS48 (rev 4124): No Patches
IOS50 (rev 54321): Trucha Bug
IOS51 (rev 4864): Stub
IOS52 (rev 5888): Stub
IOS53 (rev 5663): No Patches
IOS55 (rev 5663): No Patches
IOS56 (rev 5662): No Patches
IOS57 (rev 5919): No Patches
IOS58 (rev 6176): USB 2.0
IOS60 (rev 54321): Trucha Bug
IOS61 (rev 5662): No Patches
IOS70 (rev 54321): Trucha Bug
IOS80 (rev 54321): Trucha Bug
IOS90 (rev 54321): Trucha Bug
IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS223[38+37] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
IOS236 (rev 54321): Trucha Bug, ES Identify, NAND Access
IOS245[37] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
IOS246[38] (rev 21007, Info: d2x-v7final): Trucha Bug, ES Identify, NAND Access
IOS247[53] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
IOS248[55] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
IOS249[56] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
IOS250[57] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
IOS251[58] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
IOS254 (rev 65281): BootMii
BC v6
MIOS v65535
Report generated on 2014/11/14.Comment
That sysCheck doesn't look to bad but you need to download d2x v8 Final wad pack and put these in the wad folder on the SD card, install all 7 wads with Multi Mod Manager (MMM).
IOS40 is Stub so after you have installed all 7 d2x v8.0 wads download ModMii6.3.1 and run ModMii.exe from Windows. Use the SU option from the main menu and find the location of the sysCheck.csv from the sysCheck which is on the root of the SD card. That will download all missing wads and apps to COPY_TO_SD sub folder just add all files and folders to the SD card. Just put IOS40v16174(IOS60v6174[FS-ES-NP-VP-DIP]).wad in the wad folder and install it.
As you've said you want to upgrade to 4.3 which you can do if your Wii is web connected then you have to re-softmod with Letterbomb. I may ask you do an additional update a four figure number something like 4128 just click No to ignore that.Keith
2010 Golf GTD (170)Comment
Sorry didn't get your reply till just now, I managed to get to 4.3E but cant seem to get some games to work, some .wad games install but others dont and not sure about usb games yet as need a decent loader. here is a syscheck of where I am now, sorry might seem bit noob but didnt have this much bother 3 years ago
Region: PAL
System Menu 4.3E (v514)
Homebrew Channel 1.1.2 running on IOS58
Hollywood v0x11
Boot2 v4
Found 127 titles.
IOS9 (rev 1034): No Patches
IOS11 (rev 16174): Trucha Bug, NAND Access
IOS20 (rev 16174): Trucha Bug, NAND Access
IOS30 (rev 16174): Trucha Bug, NAND Access
IOS36 (rev 3608): No Patches
IOS50 (rev 14889): Trucha Bug, NAND Access
IOS60 (rev 16174): Trucha Bug, NAND Access
IOS70 (rev 16687): Trucha Bug, NAND Access
IOS80 (rev 6944): Trucha Bug, NAND Access
IOS202[57] (rev 65535, Info: hermes-v5.0): Trucha Bug, NAND Access, USB 2.0
IOS222[38] (rev 65535, Info: hermes-v5.0): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS223[38] (rev 4, Info: hermes-v4.0): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS224[57] (rev 65535, Info: hermes-v5.0): Trucha Bug, NAND Access, USB 2.0
IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
IOS249[56] (rev 20, Info: rev 20): Trucha Bug, NAND Access, USB 2.0
IOS250 (rev 65535): Trucha Bug, ES Identify, NAND Access
BC v6
MIOS v4
Report generated on 2014/11/15.Comment
Well that sysCheck is the same as your last one so do everything I've said in post #5.
Which game names in particular don't work? How are you loading games on the drive I use WBFS Manager 3.0 and it never fails.Keith
