BRICKED wii possibly? no wii menu but loads hbrew from bootmii
  • jamieupanddown
    • Mar 2009
    network not initalised 1.0.3
    Homebrew IOS61v19.26
    Above is what it shows on the homebrew screen.
    From the top
    installed twighlight hack. hbrew
    1:installed Ios-16-64-v257 with wad manager version 1.1 waninkoko
    2:Installed Cios_fix.wad using custom wm version 1.1 waninkoko
    3: downgraded to 3.2e using custom Ios downgrader v1.2 waninkoko
    4: Loaded Ios downgrader v1.1 waninkoko and apllied all.
    4a: installed starfall apllied all.
    5: loaded shop channel INSTALLED Ios51 and Patched sig Hash Check in Ios51, didnt install shop chanell.
    6: Installed Backup launcher 0.3wiish-v3_en.wad using wad manager version 1.1 waninkoko.
    7: Installed Ios38-64-v3609.wad using wad manager version 1.1 waninkoko.
    8: installed Cios36 boot.dol used network and did as told.
    everything worked FANTASTIC!!!!!!!!!!!
    9: problem with some things loading.
    10: LOADED Custom ios installer 2.0 waninkoko/wiigator/kwiirk used IOS 249 installed IOS38-64-v3610.wad
    11: Installed BACKUP LAUNCHER_WBKL.wad (Neogammer v6)
    Wii now worked a charm.
    12: i was interested to use hackmii so upgraded using nintendo update to 4.1
    everything worked fine. i removed hbrew and installed hbrew via hackmii (bbom) installed bootmii and dvdx.
    I tried to create a nand but the wii had a bad factrory sector! this was my downfall!
    13:I tried downgrading to 3.2e using custom ios downgrader v1.2 waninkoko but no joy.
    I remember having a 3.2e system menu wad.
    14 :I istalled system menu v2.9 wad using wad manager.
    THIS IS WHEN THE WII boot up and everything dissapeared.
    15: i could still load hbrew via bootmii and use my wiimotes to access apps etc in hbrew.
    16: UNinstalled System menu v2.9 wad using wad manager (THIS MUST BE THE PROBLEM I THOUGHT!)
    17: THIS IS WHEN THE HBREW SCREEN TURNED RED AND WII MOTES STOPPED WORKING. i could load hbrew via bootmii and load games via neogamma via hbrew. using
    gc controller (once the games where loaded the wiimote would sync)
    18:I installed the wad manager (that supports gc controllers) as an app, as i had no way to load wad manager.
    19: I installed IOS60-64-v6174.wad from nusdownloader.
    20: I installed System menu-nus-v450.wad
    still no wii to access, can only load hbrew vai bootmii nothing loads via neogamma and hbrew screen is still red.
    THATS BASICALLY IT from the top
    IF IT AINT BROKE DONT FIX IT.
    IF ITS KINDA BROKE LEAVE IT ALONE.
    IF IT SEEMS REALLY BROKE THEN KEEP TRYING!
    thanks for any info and help.
  • ManofScience
    • 650
    doesn't the nand backup always have a few bad blocks in? have u tried restoring it anyway?
    • jamieupanddown
      • Mar 2009
      nand backup
      when i copied nand to sd and tried to reinstall via bootmii it would not let me as the nand had a bad sector!!
      sd card has since been overwritten! doh
      wii's not got long left in it, help please LOL
      • nenene
        • 41
        homebrew
        can you not format your wii to factory settings
        • nutta_nic
          • 18
          uninstall IOS60-64-v6174.wad then install the two wads in this rar file, RapidShare: 1-CLICK Web hosting - Easy Filehosting
          you should then be back on SM 3.2e
