hi guys, been awhile since i messed about with the wii... but my neighbour dropped over with a black wii. 4.3E and i used letterbomb to mod it... now it installed homebrew channl. but as i was about to install bootmii as ios , i seen it was in purple writing and said Bootmii cant be installed as a ios ..... usb loader wont even load either.... any help please.. i will post a system check later..
help needed here.
here is my system check .. please help thanks guys,,
sysCheck v2.1.0b19 by Double_A and R2-D2199 Nano
...runs on IOS58 (rev 6176).
Region: PAL
System Menu 4.3E (v514)
Priiloader installed
Drive date: 2009.11.21
Homebrew Channel 1.1.2 running on IOS58
HomebrewFilter ist nicht installiert
Hollywood v0x21
Console ID: 156179372
Boot2 v4
Found 73 titles.
Found 44 IOS on this console. 13 of them are stub.
IOS3 (rev 65280): Stub
IOS4 (rev 65280): Stub
IOS9 (rev 1034): No Patches
IOS10 (rev 768): Stub
IOS11 (rev 256): Stub
IOS12 (rev 526): No Patches
IOS13 (rev 1032): No Patches
IOS14 (rev 1032): No Patches
IOS15 (rev 1032): No Patches
IOS16 (rev 512): Stub
IOS17 (rev 1032): No Patches
IOS20 (rev 256): Stub
IOS21 (rev 1039): No Patches
IOS22 (rev 1294): No Patches
IOS28 (rev 1807): No Patches
IOS30 (rev 2816): Stub
IOS31 (rev 3608): No Patches
IOS33 (rev 3608): No Patches
IOS34 (rev 3608): No Patches
IOS35 (rev 3608): No Patches
IOS36 (rev 3608 Info: rev 3351): Trucha Bug ES Identify NAND Access
IOS37 (rev 5663): No Patches
IOS38 (rev 4124): No Patches
IOS40 (rev 3072): Stub
IOS41 (rev 3607): No Patches
IOS43 (rev 3607): No Patches
IOS45 (rev 3607): No Patches
IOS46 (rev 3607): No Patches
IOS48 (rev 4124): No Patches
IOS50 (rev 5120): Stub
IOS51 (rev 4864): Stub
IOS52 (rev 5888): Stub
IOS53 (rev 5663): No Patches
IOS55 (rev 5663): No Patches
IOS56 (rev 5662): No Patches
IOS57 (rev 5919): No Patches
IOS58 (rev 6176): USB 2.0
IOS60 (rev 6400): Stub
IOS61 (rev 5662): No Patches
IOS70 (rev 6912): Stub
IOS80 (rev 6944): No Patches
IOS236[36] (rev 65535 Info: rev 3351): Trucha Bug ES Identify NAND Access
IOS249 (rev 3608): Trucha Bug ES Identify NAND Access
IOS254 (rev 65281): BootMii
BC v6
MIOS v10
Report generated on 2014/12/19. -
As far as I know Bootmii will only install in IOS on a 2009.11.21 Wii, it installs in IOS on my 2008.
As you may have read on here that's a typical sysCheck of a Wii that's only been softmodded as you have 13 IOS's that are Stub. You do have IOS36 and IOS236 that's all but you need to reduce that 16 down to 4 or 5.
Download ModMii6.3.1 and run ModMii.exe from Windows. Use the SU option from the main menu and find the location of the sysCheck.csv from the sysCheck which is on the root of the SD card. That will download all missing wads and apps to COPY_TO_SD sub folder just add all files and folders to the SD card.
ModMii only installed 2 d2x v8.0 wads download d2x v8 Final wad pack and put these in the wad folder on the SD card, install all 7 wads when you install the other wads.
Put the SD card back in the Wii and run Homebrew. You already have IOS236 but it won't hurt to install it again. Run IOS236 Installer v5 Mod first before you install any other wads. Multi Mod Manager (MMM) should be the first app listed select it and load it. Once running scroll down to WAD Manager and press 'A' that will default to all wads in the wad folder. If you want to install all wads shown just press 1 that will list all wads you want to install press 'A' again to install them all.
Watch for the Installed OK message after each one. If any don't say that message make a note of the wad name and back out. Scroll down to the wad that didn't install and press the + button the put a green + next to it then press 'A' to see that wads name listed then press 'A' to install again.
If you have to update to 4.3 then the Shopping Channel may not work. If it doesn't without doing another system update don't bother just install my RVL-Shopping-21
Do another sysCheck to make sure everything installed correctly and post that.
Then you just have a to find a compatible mains powered USB hard drive to add your games onto and download USB Loader GX 3.0 to run them.Keith
2010 Golf GTD (170)Comment
hi keith, im reading this but dont understand it , can you spoonfeed me ere.... ( find the location of the sysCheck.csv from the sysCheck which is on the root of the SD card. That will download all missing wads and apps to COPY_TO_SD sub folder just add all files and folders to the SD card.)
thanks m8Comment
ok , did as said above everything seems to loaded ok... think i may have made mistake with partition HDD any way this is systemcheck have a look m8
Region: PAL
Hollywood v0x21
Boot2 v4
Found 85 titles.
Found 55 IOS on this console. 5 of them are stub.
IOS11 (rev 16174): Trucha Bug NAND Access
IOS20 (rev 16174): Trucha Bug NAND Access
IOS30 (rev 16174): Trucha Bug NAND Access
IOS36 (rev 3608): No Patches
IOS40 (rev 16174): Trucha Bug NAND Access
IOS50 (rev 16174): Trucha Bug NAND Access
IOS52 (rev 16174): Trucha Bug NAND Access
IOS60 (rev 16174): Trucha Bug NAND Access
IOS62 (rev 6430): No Patches
IOS70 (rev 16174): Trucha Bug NAND Access
IOS80 (rev 16174): Trucha Bug NAND Access
IOS202[60] (rev 65535 Info: hermesrodries-v6): Trucha Bug NAND Access USB 2.0
IOS222[38] (rev 4 Info: hermes-v4): Trucha Bug ES Identify NAND Access USB 2.0
IOS223[38+37] (rev 4 Info: hermes-v4): Trucha Bug ES Identify NAND Access USB 2.0
IOS224[57] (rev 65535 Info: hermesrodries-v6): Trucha Bug NAND Access USB 2.0
IOS245[37] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
IOS246[38] (rev 21008 Info: d2x-v8final): Trucha Bug ES Identify NAND Access
IOS247[53] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
IOS248[55] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
IOS249[56] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
IOS250[57] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
IOS251[58] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
BC v6
MIOS v10
Report generated on 2014/12/20.Comment
Well that new sysCheck looks ok, if you want to remove IOS16 Stub then install my cIOS16-v257 but that will make no difference for running games of an HDD.
Have you tried to run any games of a mains powered hard drive?Keith
back again... helping out a friend here with his wii.. not playing games, as custom ios 249 in a stub. anyway i did a system check maybe ye can have a look
Region: PAL
Drive date: 2007.02.13
Hollywood v0x11
Console ID: 72858397
Boot2 v4
Found 105 titles.
Found 48 IOS on this console. 8 of them are stub.
IOS222 (rev 65280): Stub
IOS223 (rev 65280): Stub
IOS249 (rev 65280): Stub
IOS250 (rev 65280): Stub
BC v6
MIOS v10
Report generated on 2015/01/03.Comment
If you do everything I said then there shouldn't be a problem the bit you missed was.
Along with cIOS222[38]-v4.wad, cIOS223[37-38]-v4.wad
ModMii only installed 2 d2x v8.0 wads download d2x v8 Final wad pack and put these in the wad folder on the SD card, install all 7 wads when you install the other wads.Keith
guys,,, me again. kids broke hdd... so i got new one copied 240 games from m8 hdd,, but for some reason the covers wont download... my kids are yound and go by pictures to play games.. now they have now covers so its a pain..... any ideas, i have try to d/load covers via menu on wii, and wii game manager.. any helpComment
Game covers are stored on the SD card.
USB Loader GX - SD:\config\images\(3D), config\images\2D, config\images\disc, config\images\full
CFG USB Loader - SD:\usb-loader/covers/2D, usb-loader/covers/2D, usb-loader/covers/3D, usb-loader/covers/disc, usb-loader/covers/full
Wii Flow - SD:\wiiflow\boxcovers (full cover), SD:\Wiiflow\covers (2D)
If your Wii has a web connection you can download covers in options or search for the game name or better the game ID number at http://www.wiiboxart.com/pal.php then add them to the correct folders on the SD card. Each download will have the same filename for full, 2D, 3D, disc, e.g. R5UP41.png, SKCE20.png which is the game ID number so don't mix them up.Keith
As I've said your Wii needs an internet connection to download game pictures. You can also search for the game ID number from http://www.wiiboxart.com/pal.php
Your example http://www.wiiboxart.com/wiigame.php?game=R5FP41 The full one doesn't show right so that's corrupted.
Just click on each picture then right-click on the picture and save it to correct folder on the SD card. All pictures have the same filename so don't mix them up.
USB Loader GX:
2D = SD:\config\images\2d
3D = SD:\config\images\3d
Disc = SD:\config\images\disc
Full = SD:\config\images\full
CFG USB Loader:
2D = SD:\usb-loader\covers\2d
3D = SD:\usb-loader\covers\3d
Disc = SD:\usb-loader\covers\disc
Full = SD:\usb-loader\covers\full
WiiFlow:
2D = SD:\wiiflow\covers
Full = SD:\wiiflow\boxcoversKeith
