how to copy wii games
  • mickscouse
    • Aug 2009
    • 7
    hi,i have a chipped wii and would like to know how to copy and backup games so i can use them on the wii,any help would be grateful thanks
  • thelips
    • 84
    imgburn is what u need but you would better off reading the wii section as u can just load games from hard drive
    • mickscouse
      • Aug 2009
      • 7
      hi thanks for that could i download a game from a torrant site then burn it to disk with imgburn ;.)
      • donan4523
        Step By Step Guide Showing You How To Copy Wii Games
        Found this on another site could not get the images to load in the post hope this helps:
        First step in the backup, burn or copy process is to get the right harware and software to
        make it posible to copy Wii games. You will need one of the following DVD drives to copy
        Wii games(To date, no other drives have been found to copy Wii games reliably).
        LG-8164b
        LG-8163b
        LG-8162b
        LG-8161b
        Next you will need to download the following applications
        *Raw dump 2.0
        .net Framework 2.0
        Winrar * Software to unzip the Raw Dump files
        How to copy Wii Games and save on scratched disks. Also you have to modchip and backup
        nintendo wii games
        Once you have downloaded all the required files stated above necessary to copy Wii games,
        right-click on the rawdump2.0.rar and select "Extract to rawdump2.0\" this will make a
        folder on your desktop called rawdump2.0.
        The next step of the process is to insert the Wii games disc you wish to copy into your LG
        drive as per previously mentioned requirements.
        Next, open the rawdump2.0 folder and double click on the rawdump2.0.exe file.
        nintendo wii games
        After doing this you will be presented with the following interface. The next step is to
        just click "Start Dump." The time it takes to copy Wii games will vary but on an average
        machine it should take approx. 2 1/2 hours. When it is complete you will be greeted with a
        nice finished message. The file it creates will be in the same directory as the rawdump.exe
        file. It should be called "Game Name.iso." This ISO is an image of the actual game and is
        ready to be burned. You can burn this image with many different applications, but I will be
        providing screenshots for Nero Burning Rom.
        This step is very important. You need to check your file and see how large (Giga Bytes) it
        is. To do this Right-Click on your iso(this is in your rawdump directory) and select
        properties. It should say,
        * Nintendo Wii ISO size: 4.37 GB (4,699,979,776 bytes).
        * Nintendo Gamecube ISO size: 1.35 GB (1,459,978,240 bytes)
        All Nintendo Wii and Gamecube images will be this exact byte size. If your Wii image is off
        by any then you have a bad dump and need to try again.
        So next step is to open Nero.
        Once nero opens, cancel out of the create new dvd/cd/etc dialog box and 0n the top drop
        down menu go to - Recorder ----> Burn Image.
        When you click "Burn Image" you will be asked to locate the image file you wish to copy.
        The image will be located in your Rawdump2.0 folder (Usually on the desktop).
        nintendo wii games
        Select the Wii game that you have dumped with rawdump and click open. You will then be
        presented with this dialog. Make sure to select a relatively slow burn speed at first to
        attempt to prevent DRE's (Disc Read Errors). These seem to be common among people that do
        not use high quality dvd's.
        Last minute note on "How to copyWii games" - Make sure you use good media! Taiyo Yudens are
        a reasonable brand and they are also cheap. They have been used sucessfully to copy DVDs
        and PS2 as well as to copy Wii games. Generally consoles use fairly cheap laser DVD Drives
        in their systems so using good quality disc to copy your Wii games is the key. The burner
        is the other key ingredient. Do some research and find a good one.
        Please Note - The LG drive required for READING the Wii games disc is NOT a DVD Writer. You
        will need a separate burner. Make sure to install . net Framework 2.0 (3.0 also works)
        before you run RawDump2.0 to copy your Wii games. Vista users ignore...it's already in
        there.
        Modchip installation...wiikey.cn.
        If after your dump you see a rar file (or image file) it is an .iso file. You are looking
        at the icon, not the extension. Change windows settings to see the extension and you will
        see, ".iso". The reason you might see the RAR "book stack" symbol is because when you
        installed WinRAR you selected it to recognize .iso files, and so it associates the WinRAR
        icon with .iso files.
        I hope this mini-guide on "How to copy Wii games" helps you. Keep Gaming ok.
        Raw Dump 2.0:
        RapidShare: 1-CLICK Web hosting - Easy Filehosting
        _____________________________________
        [ame=http://www.youtube.com/watch?v=EuOaQ_aNrR4]copy wii games[/ame]
        [ame=http://www.youtube.com/watch?v=EuOaQ_aNrR4]copy wii games without a mod chip[/ame]
