HomeBrew Working but not all games, do you know the fix?
  • mirage99max
    • Feb 2014
    Hi Guys, Ive been using HomeBrew for a number of years, but only recently have I realised that not all the games load, since I don't play the wii that much myself these days its mostly the kids. Im using Wiiflow.
    Does anyone have an SD card image that I could download or use? I have a 2GB FAT format card with the following directory structure:
    apps/wiiflow/ boot.dol, icon, meta, wiiflow
    wiiflow/boxovers etc
    wiimc/boot.dol, etc
    The external drive has all the ISO images installed using Wii BackupManager
    Has anyone a fix for this or do you know what to do?
  • Keithuk
    • Aug 2010
    • 2264
    Welcome to DK.
    I thought the Wii had died now its Wii U.
    Download http://www.digital-kaos.co.uk/forums...o=file&id=2442 and make a report as instructed I that link so I can see which IOS's you've installed.
    Download ModMii6.3.1 and run ModMii.exe from Windows. Use the SU option from the main menu and find the location of the sysCheck.csv from the sysCheck which is on the root of the SD card. That will download all missing wads and apps to COPY_TO_SD sub folder just add all files and folders to the SD card.
    Keith
    2010 Golf GTD (170)
    • mirage99max
      • Feb 2014
      SysCheck - ModMii6.3.1.
      Originally posted by Keithuk
      Welcome to DK.
      Hi Keith, Thanks for your reply. Yes the kids and I still use the Wii (The original is still the best!).
      Here is a dump from the syscheck.... I never came across the ModMii tool before btw - seems interesting.
      I generated this report a few minutes ago:
      sysCheck v2.1.0b19 by Double_A and R2-D2199 Nano
      ...runs on IOS58 (rev 6176).
      Region: PAL
      System Menu 4.3E (v514)
      Priiloader installed
      Drive date: 2008.07.14
      Homebrew Channel 1.1.0 running on IOS58
      HomebrewFilter ist nicht installiert
      Hollywood v0x11
      Console ID: 41808588
      Boot2 v4
      Found 148 titles.
      Found 47 IOS on this console. 7 of them are stub.
      IOS4 (rev 65280): Stub
      IOS9 (rev 1034): No Patches
      IOS10 (rev 768): Stub
      IOS11 (rev 256): Stub
      IOS12 (rev 526): No Patches
      IOS13 (rev 1032): No Patches
      IOS14 (rev 1032): No Patches
      IOS15 (rev 1032): No Patches
      IOS16 (rev 54321): Trucha Bug ES Identify Flash Access NAND Access
      IOS17 (rev 1032): No Patches
      IOS20 (rev 256): Stub
      IOS21 (rev 1039): No Patches
      IOS22 (rev 1294): No Patches
      IOS28 (rev 1807): No Patches
      IOS30 (rev 54321): Trucha Bug
      IOS31 (rev 3608): No Patches
      IOS33 (rev 3608): No Patches
      IOS34 (rev 3608): No Patches
      IOS35 (rev 3608): No Patches
      IOS36 (rev 54321): Trucha Bug ES Identify NAND Access
      IOS37 (rev 5663): No Patches
      IOS38 (rev 3867): No Patches
      IOS40 (rev 3072): Stub
      IOS41 (rev 3607): No Patches
      IOS43 (rev 3607): No Patches
      IOS45 (rev 3607): No Patches
      IOS46 (rev 3607): No Patches
      IOS48 (rev 4124): No Patches
      IOS50 (rev 54321): Trucha Bug
      IOS51 (rev 4864): Stub
      IOS52 (rev 5888): Stub
      IOS53 (rev 5406): No Patches
      IOS55 (rev 5663): No Patches
      IOS56 (rev 5662): No Patches
      IOS57 (rev 5919): No Patches
      IOS58 (rev 6176): USB 2.0
      IOS60 (rev 54321): Trucha Bug
      IOS61 (rev 5662): No Patches
      IOS70 (rev 54321): Trucha Bug
      IOS80 (rev 54321): Trucha Bug
      IOS202[38] (rev 4 Info: hermes-v4.0): Trucha Bug ES Identify NAND Access USB 2.0
      IOS222[38] (rev 4 Info: hermes-v4.0): Trucha Bug ES Identify NAND Access USB 2.0
      IOS223[38] (rev 4 Info: hermes-v4.0): Trucha Bug ES Identify NAND Access USB 2.0
      IOS236 (rev 54321): Trucha Bug ES Identify NAND Access
      IOS249[57] (rev 19 Info: rev 19): Trucha Bug NAND Access USB 2.0
      IOS250 (rev 65535): Trucha Bug NAND Access USB 2.0
      IOS254 (rev 65281): BootMii
      BC v6
      MIOS v10
      • Keithuk
        • Aug 2010
        • 2264
        As I've said you need ModMii that will download any missing wad files, You have a few IOS's that are stub IOS11, ISO20, ISO40, IOS52 and you also need to download d2x v8 Final wad pack and put these in the wad folder on the SD card, install all 7 wads when you install the other wads.
        Put the SD card back in the Wii and run Homebrew. You already have IOS236 but it won't hurt to install it again. Run IOS236 Installer v5 Mod first before you install any other wads. Multi Mod Manager (MMM) should be the first app listed select it and load it. Once running scroll down to WAD Manager and press 'A' that will default to all wads in the wad folder. If you want to install all wads shown just press 1 that will list all wads you want to install press 'A' again to install them all.
        Watch for the Installed OK message after each one. If any don't say that message make a note of the wad name and back out. Scroll down to the wad that didn't install and press the + button the put a green + next to it then press 'A' to see that wads name listed then press 'A' to install again.
        I have USB Loader GX, CFG USB Loader, WiiFlow and they all work but I always use USB Loader GX as its the best. Some games need to be tweaked in the settings.
        Keith
        2010 Golf GTD (170)
        • mirage99max
          • Feb 2014
          Hi Keith, Ok let me try that tonight, I forgot to mention that I already ran ModMii against the syscheck but was waiting for a thumbs up before proceeding. Now I will try this and let you know what happens! Thanks again!
          • 12345guy12345
            • Nov 2012
            • 162
            If you want to playonline with some games even though nintendo disscontinued its servers check out wiimmfi project.You patch the iso with new server details
            Sent from my SM-G900F using Tapatalk
            • objence
              • Oct 2018
              • 19
              HomeBrew Working but not all games do you know the fix
              popular nintendo/wii games are mainly mario, pokemon and zelda. i know there are other popular titles, but nintendo should focus more on these three
