Bricked Wii Help please
  • spellman
    • 15
    Hi I was running 3.2e and wanted to update to 4.1/4.0 to use wii loader. Could not load 4.1 even loaded cios 36 and 38. Decided to run 4.0, all installed ok as per instructions but when I finished I just get blue screen. Cant turn Wii off (I have to do it by the wall). Does anyone have any ideas????
  • spellman
    • 15
    Not sure if this is the reason why but it asked me to update IOS60. Anyone else had this problem or is aware of a remedy?? Otherwise could be new motherboard/Wii?
    • tango
      • Aug 2008
      • 1033
      if u have changed ios 60 (installed a custom version) then u need to reinstall the upto date version.
      where abouts are u?
      its not an easy task to redo i had 1 other day that did same ony went green screen not blue
      • spellman
        • 15
        I am led to believe it already had ios60 installed and this has caused the conflict. I am in Liverpool with a wife giving me daggers for messing about.
        • tango
          • Aug 2008
          • 1033
          u need ios60 for the console to run its a main ios m8
          what sounds to have happened is u have replaced it with a customized ios60 and the console dont like it.
          u need to reinstall the original ios60
          • spellman
            • 15
            How do i reinstall original ios60. The wii is still showing blue screen I dont even know of a way to get the wii homebrew screen on to load a cios from sd card. Do you have any ideas
            • tango
              • Aug 2008
              • 1033
              is it blue screening as soon has u turn it on?
              if so then not sure what u can do m8
              i can make u an sdcard up that will let u reinstall ios60 but will only work if u can run from sdcard (no need for hbc)
              • spellman
                • 15
                The blue screen appears as soon as I turn on the console. If you could make up a SD card I will give it a try. Thanks for your help.
                • tango
                  • Aug 2008
                  • 1033
                  not sure if this will work from a blue screen m8 but no harm in trying.
                  • spellman
                    • 15
                    Thanks for the file - I keep getting corrupt file on iso38-64v3610. Have you used this file before? Also will the Wii boot from the SD card I am unsure if it will see the SD card untill it completes booting up.
                    • Serial7
                      Thx for the tips.
                      • kLiNiKaL
                        • 21
                        if you used Waninkoko's 4.1 updater fella then ya abit ****ed unless you have bootmii or preloader
                        since its out of date now and grabs a stub IOS60 from NUSD(Ninty Server) hence the brick
