disney sing it not reconising mic please help
  • pjtaff
    • 212
    i have downloaded disney high school sing it
    and sing it pop stars i think its called any way
    the problem i got is that when i load the game it all looks fine until i have to put the mic in then it dosn't reconise the mic it keeps telling me to insert logitech mic into the usb but i have put the logitech mic in a usb port
    dont know if im the only one with this prob or if it is a comon fault
    or do i need a different mic for each game
    any help would be great
    many thanks
    taf
  • bigboots
    • 106
    no that mic should be fine,have you tred the other usb port.?
    • DiddyDave
      • 213
      many thanks
      taf
      Hi make sure that the mic is in the wright USB slot. Looking from behind put it in the left side and if you are using it USB loader the ext HDD should be in the right side.
      • pjtaff
        • 212
        ive tried it in both the usb slots and still no joy dont think its the download
        i am running the game of a disc if this helps
        • bigboots
          • 106
          there is a update for to get the wii drums to work on usb google it that will help you find it, give that ago,
          • pjtaff
            • 212
            is that for the game to load through usb or for the attachment to work
            cause if its the game i only load through disc
            cheers taf
            • bigboots
              • 106
              no the game loads ok, it was for the usb to work prop with the drums on usb
              • middlewingnut
                • 55
                Ditto the comments above, you need to upgrade an ios, but I forget which one, sorry. I upgraded by backup loader to neogamma's latest version and it works perfectly, both using dvd-rs and the usb hard drive.
                • DiddyDave
                  • 213
                  The ios is the Rev 14 look for this and that should sore the usb issue out for you.
                  Since installing this my self the only battle is the error 002 and 001 and this is bypassed most of the time by running the game in Herms 222 mode instead of 249
                  • pjtaff
                    • 212
                    i know im going to sound like a right divvy but how do i instal the ios rev 14 and where do i get it from
                    please give me a step by step idiots guide as im not that great on this softmodding yet
                    im running on the first bannerbomb if this helps also my wii is not connected to the internet
                    also i got a m8 who has a hd for his wii got set up by someone he knows,
                    my question is can i plug this hd into a pc and copy all its contents onto another hd so i can use the hard drive on my wii or is it not as simple as that
                    many thanks
                    taf
