dvd read error 1101
  • pedrohell
    • 5
    dvd read error 1101
    Hi, finally I was able to softmod my Wii (4.0E).
    Bannerbomb v1, hackmii as IOS , copy of nand, Trucha bug restorer, waninkokos cIOS 38 rev14, dop-ios v8, wad manager 1.5 and neo gamma r7.
    Everything ok, not a single error.
    I tried a backup game through neo gamma, it starts reading the disk and gives the error DVD READ ERROR 1101, I also tried the Softchip and same thing.
    I burned a verbantim dvd-r, imgburn 4x speed.
    Any idea where is the problem?
    Thanks in advance.
  • ukjimmy31
    • Oct 2008
    • 36
    yeah i have the same prolem, any guys got any ideas please thanks
    • crouchingllama
      neogamma error 1101 solution
      Hi All.
      I recently upgraded to v4.2 after almost bricking my system on a previous version. I'm new at this and my system is pal. I am also using neogamma R7 IOS249 rev14 through the HBC and using Imgburn on the slowest speed setting and using Memorex dvd-r. I copied 5 PAL games + 1 scrubbed over the last couple of days and they work great. I only had the problem with the scrubbed 1 in neogamma when i got this 1101 error. I burned the scrubbed 1 on my laptop and the rest on my pc. I tried burning the scrubbed 1 again on my pc. Turns out the first disc was dodgy. Second time around the same error happened. In neogamma i went to Region Options to Force Video and changed that from Disc to PAL480i now it works good for me. You can change it to a few different settings if the PAL480i doesn't work for you. If this was any help to you HOORAY!
      • kinkyjo2002
        tried everything crouchingllama said and still dvd read error 1101 aarrghh help pleasseeee!!
        • ck-ok
          • 2592
          ok error 1101 is dvd read error which means a bad burn or bad media try verbatim discs at x4 burning with imgburn,if error persists the you might have a d2-3 chip which cant read backups check your serial number here Nintendo-Scene Wii Serial Tracker
