wii softmad doing my head in.
  • oldman77
    • 17
    I have tried for 9hrs over three days to get my wii firmware v4.2e to be softmodded but with all the files i can find it wont help.
    I have formatted my sd card 512mb/ 128mb lots of times and put the relivent files onto them and not once does it work or load but it does freeze on a few of the private files.. where have i been going wrong pls help i would love to get this sorted otherwie my wii is going to be traded in for an xbox or something else.
  • dell_xps
    • 2558
    Have you tried the tutorial I posted m8 ?
    Try another memory card first see how you get on.
    • oldman77
      • 17
      tried both sd cards and neither work and also tried to do the tutorial and that didn't work either anything else i could try.
      • dell_xps
        • 2558
        What is the file structure on your card ?
        root folder etc etc
        • cgscott
          • 3513
          Are you using the auto installer to foramt and install the card?
          Patience is a virtue.
          • oldman77
            • 17
            root folder is as shown in bannerbomb and mii file is imported and drag and drop, when i wipe card clean i use fat file to delete all files everytime i put new files on it.
            • dell_xps
              • 2558
              Wouldn't worry too much about boot mii, try getting the homebrew channel on first.
              Are you using the v2 bannerbomb ?
              bannerbomb
              If one doesnt work there are a few other files to try there m8.
              Whats the serial of yer wii ?
              Number 3 is wrong, it's already renamed.
              • cgscott
                • 3513
                Uploading a file now to downloads for you.
                Auto format and install for 4.2.
                • oldman77
                  • 17
                  serial number of wii is LEH23900411 why is their any problem with some systems with sertain s/num's
                  • oldman77
                    • 17
                    GSSCOTT is this softmodding 4 dummies as i have tried that but will try this and if no good will let you knoe ok.
                    • oldman77
                      • 17
                      cgscott tried the link of banner bomb, new info you dont have to go threw all the options on ur wii to get it to open or start downloading from sdcard you just click on sdcard on main wii page. Yes it does start with download bannerbomb or the boot.dol file then you click yes then yes again then it freezes no info on screen just black nothing at all, more help pls.
                      • oldman77
                        • 17
                        got it working at last had to take boot.dol file off and worked strate away cheers budey
                        • dell_xps
                          • 2558
                          M8 when you click on your SD card in your computer do you see the following,
                          Private
                          boot.elf
                          Inside the private folder should be Wii folder,inside the wii folder is a title folder, inside the title folder there should be an aktn folder,then inside the aktn folder should be a content.bin
                          If your SD card does not read like this change it then put it in your Wii, then click on the SD card at the bottom left of the Wii to start the homebrew channel install.
                          • oldman77
                            • 17
                            All i need now is how to burn wii games onto disk can i use nero or is there any prefered burning tool that i might need to d/load.
                            • dell_xps
                              • 2558
                              Have you got the homebrew channel on now?
                              Are these downloaded games or bought games you are trying to copy m8 ?
