Error #002
  • acestu
    • 269
    Error #002
    Hi Guys, I have just installed the softmod onto my 3 series menu wii, now when i try and load a backup i get the blue screen #002 error, i have done some reading on here and it appears that i need to install the Neogamma loader, ok i have downloaded this from here which is 3 files in a folder, i have put that in my apps folder on the sd card, i have then gone to the wad installer on the homebrew channel which tells me that there are 2 c****** whatever files on the sd card, but i am stuck there , could somebody help me please as i would be most appreciative....
    UPDATE
    Ok , I have now found the Neogamma loader in the homebrew channel but when i try and load my gamethescreen flashes a few times and then comes up with ERROR #001 Unauthoriseddevice
    Soi guess something is not installed correctly
    Acestu
    If my post Helps, then Please Click the THANKS Button ,as i will do for you.
    The Acestu Corporation.... More Powerfull Than You Could Possibly Imagine !!.........sigpic
  • dell_xps
    • 2558
    Ok open up Neogamma, go to options, then select 002 fix to on, save settings then launch DVD.
    If this doesnt work you'll need something like, cIOS38_rev13b installed.
    I've got a Wii to softmod later on tonight, it's a 4.2E, so I'll maybe have a bit more information once I've done it.
    give that above a go anyway.
    PS The three files you have need to be run from the homebrew channel via yer SD card, the channel installs through Wad Manager but you need the wad file (posted in the tutorial I posted), then you can run it via the Wii menu, no need for an SD card.
    HTH m8.
    • acestu
      • 269
      Dazed and Confused
      Thanks dell,i will give this a go, it made me wonder if i had burnt my iso properley though, is there something similar to ABGX for the Wii that you can check your backups with ? , i did my first one the other day but after i had downloaded it i just ran it through wii brick blocker first , but there is another app called Wii Iso patcher so do i need to use this first ? ....
      thanks for all your help
      Acestu
