Restore To Stock ?
  • acestu
    • 269
    Restore To Stock ?
    Hi Guys, does anybody know how i can restore my Wii to stock ?
    Acestu
    If my post Helps, then Please Click the THANKS Button ,as i will do for you.
    The Acestu Corporation.... More Powerfull Than You Could Possibly Imagine !!.........sigpic
  • cgscott
    • 3513
    What you mean stock?
    You want to downgrade version or just remove the homebrew?
    Patience is a virtue.
    • MetalKettle
      V.I.P.P.T. Member
      • 797
      If you have boot mii and have created a backup before you tinkered with anything then use this to restore your wii to pre-softmod.
      If you have no back up....
      Format the wii in settings.
      Use hackmii installer with bannerbomb to uninstall bootmii for true virgin wii. (this doesn't install anything, there's no trace left on system that this happened). Thats nearly viginised (some cios will remain) but not noticable.
      Full virgin...
      Get a list of IOSs for the version you have on your wii, then use NUSD to get packed wads from the IOSs and the system menu you have installed currently. Install them all with a wad manager. Uninstall homebrew channel wads etc, Delete every IOS past the 200s (e.g 202/222/223/249/250/254) and job done.
      But be carefully what you are doing!!! This can be a risky option.
      XBMC/KODI Developer
      • acestu
        • 269
        Taa
        Thanks Fellas, i have used the softmod for dummies on here which installs everything you need onto your sd card via a dos batch file, i followed all the instructions to a t , however i cannot get it to play backups, i have installed the nanoloader and set 002# error to on which is the fault that i was getting, but now i get a 001# error which says unauthorised device detected, now could this be a bad backup because i have burnt it on a tesco dvd-r, i am hopefully getting some verbatims tomorrow so if that dosent work i dont know what to do, as there is no app that will check your backups, Is this the best software for my wii or is there a newer software, my menu is 4.1E....
        thanks again
        Acestu
