I have softmodded my wii 3.4E everything ok then i installed something that the backup games play on the propper disc channel (all new games work including NSMB). Now my sister wants hers doin same version 3.4E done it but i cant remember what i installed so you can play games through the disc channel can anybody help?
Can Anybody Help Me
was it the preloader channel? did mine awhile back and ckecking in the appliance folder and tutorial i used its the only thing that sticks out
14) From Homebrew Channel Load PreLoader .28. Read the warning and press 1 to install.
After install your Wii should reboot and load the preloader menu, if it does not power your Wii down and then turn it back on, as soon as you press power to turn it back on hold down reset to load the preloader menu.
15) Select ?Systemenu hacks." Enable all the hacks you would like, Skip Disc Update is required for proper backup loading from disc channel. DO NOT add or enable any region hacks as they are already in place thanks to the Any Region Changer Hacks, enabling these twice will cause compatibility issues with games.
We recommend that you only enable Skip Disc Update Check, Remove Diagnostic Disk Check, Move Disc Channel, and No Menu BGM (Background Menu Music).
16) Select "save settings" and wait for confirmation message to display ?Settings Saved." Then press B to return to the preloader menu.
17) Enter Settings and set "auto boot: System" (using the D-Pad Arrows), Then select save settings. Press B to return to main preloader menu
18) Return to the system menu by selecting ?Load System Menu?Attached Files -
