Homebrew settings not showing up?
  • pokeyourface
    • 4
    How do I get the config settings to show up in the homebrew section on my wii? On my SD card there is a ton of files, apps folder, wad folder bootmii is also a folder in the root (contains the config file, but cant get it to load from my wii so i can change them)
  • dell_xps
    • 2558
    Not sure what your question is m8, but open up the homebrew channel and press home button on your controller see if that brings up config options.
    • pokeyourface
      • 4
      I'm just trying to access and change the config settings so I can have it boot to the wii menu instead of the bootmii page.
      I cannot find access to the config section anywhere, it doesn't show when I hold the home button, all the opens there is go to bootmii, return to wii menu, restart wii etc
      • dell_xps
        • 2558
        Waht firmware version are you running and what tut did you use m8 ?
        Try resetting it, switch it off leave it off for a min or two see if that helps.
        • deesenpeter
          ja lekker verhaal ik snap hier niks van
          • pokeyourface
            • 4
            Seems I can fix my problem by removing bootmii from the root directory XD thanks anyway
