softmodding wii 4.2 and freezes on wad manager
  • johno316
    • Feb 2010
    wii modding 4.2
    i had wii brew on my wii for a lower version i think maybe 4. i stupidly let it updat and now cannot get it basck on no matter what i try. in some cases the files are not on the card ie the will has a quetstion mark on it or it freezes on me. any advice as im tearing my hair out over it.
    • ck-ok
      • 2592
      #17
      your gonna have to remod it try this http://www.digital-kaos.co.uk/forums...w-guide-67927/
      • newandy
        • Feb 2010
        Will this work with and Wii SN unit with 4.2 firmware or are there some unit SN's that don't work?
        • avsky
          • Feb 2010
          I was having the same issues - freezing during Wad Manager. Tried Method B listed here, worked like a charm.
          Many thanks for the redirect (:
          • jead5148
            • Feb 2010
            i am having the sam issue
            cant get any programs to start up from homebrew
            • dragonsoul84
              • Feb 2010
              also freezing
              mine is freezing too. the link to the fix works, but their link to the files needed is broken. does anyone have the files they had linked?
              • killbill
                • Mar 2010
                new cios38rev18
                this fixes any issues with wad manger
                • irhxcbcziuzxs
                  • Mar 2010
                  Just wanted to let everyone know, you don't have to follow the directions to get the mod manager that is included in the link to work. That one seems to work on 4.2 either way.
                  • m1sniper
                    • Apr 2010
                    am having the same proble wad manager, csios installer, geogamma, all not working
                    • abbsy3
                      • Apr 2010
                      v4.2 Wii
                      I have tried aal things, but still get the freeze and the wii remote goes dead. Any ideas?
                      • ck-ok
                        • 2592
                        #26
                        try this swap it for the wad manager in your apps folder Digital Kaos - Downloads - wad manager 1.4
                        • short360uk
                          • 313
                          #27
                          do tihis in DOP-MII
                          a) Load and Homebrew Channel and run DOP-Mii, on the IOS Selection Screen, select 'Install An iOS w/ fakesign' by pressing down on the d-pad then A on the wiimote. You should now be in the trucha bug restorer portion of DOP-Mii. Load IOS36 and select Downgrade IOS15. Each time it asks, select 'Download from NUS'
                          Make sure you get no errors. If Loading IOS36 doesn't work for this step, press B for no IOS reload when asked to load IOS. Although It should do these steps almost automatically, I'll just include the info.
                          b) In the fakesign installation, once iOS15 is downgraded, it should begin patching iOS36.. Make sure to install the patched IOS36 with all these patches selected (Just Say Yes to All of the ones that come up)
                          Install IOS to slot (36)
                          Hash Check (trucha) Yes
                          ES_Identify Yes
                          NAND Permissions Yes
                          Then Press A on Install Patched IOS36. Again, everytime it asks, choose 'Download from NUS'
                          c) On the same fakesign installation. Load IOS36 and select Restore IOS15. Each time it asks, select 'Download from NUS'
                          Once done,
                          a)Re-run Homebrew Channel and Load DOP-Mii again. Choose the first option by pressing A (iOS:36), You should now be taken to a menu with three options: iOS, BC, mIOS. Select iOS by pressing A. Go to iOS249. Under currently installed, you should unisntall then go back to homebrew channel then reinstall whatever cios rev 17 or whatever ur using then run wad manager again
                          • kiritani
                            4.2U
                            Does this work on 4.2U as well?? coz i've tried... and it freezes over and over and i have to power it over and over... big pain in the arse...
                            • renke_uk
                              • 53
                              #29
                              what seems to be the problem here, what steps are you all up to?
                              SoftMod Essentials:- Dop-Mii V12 --- CFG USB Loader FAT32 --- Wii Game Manager
                              • crztazman
                                yes this does work . I had joined just a few days ago and this 4.2 rar file helped me out when i had no other option. It does worrrrrk.
