cheers for reply ive changed to a diiferent card now.
but nothing happens ive put boot.elf and extracted aad1f_v108.zip to mem card.
ive also heard that black wii dont play copies any way is usb hdd.
Your Wii a 4.1 ?
Is the boot.elf in the root of the sd card along with the private folder, so it should look like this when you open the sd card on yer comp,
Private
boot.elf
Do you have wii connect enabled in the menu if so turn it off.
The screens usually black for a min or so after accepting.
Try another card if that doesnt help, and make sure the card is not locked m8.
the closest i come to is load boot.dol/elf?
(if you paid you were scammed click on yes)
then just goes to black screen waited 10 minutes sometimes. sometimes the wii drive blue light flashes. then i pull lead out and try again
ive formatted and tried files from other forums and sites. what am i supposed to have on sd card. boot.elf and private(folder) this contains wii(folder)title(folder)aktn(folder)
